Possible to do wake on HDMI on STR-DN1060?
m0rt3n
Is it possible to wake up the STR-DN1060 for example when it receives a signal from a HDMI?
Would be nice if could power up whenever the TV gets turned on or something else from the other connected HDMIs.
1 REPLY 1
Anonymous
Not applicable
Hi there
Yes it is.  I do not know what TV you have, but as long as it supports HDMI-CEC functions, then it should work.
I have a STR-DH820, with a KDL-43W805C, when i turn my TV on, my AV Receiver turns on as well.  There is a delay of about 5 seconds though.
Oh and it works vice verse too.  Turn on a device connected to the av receiver (i.e. PS4) and it will turn on the AV Reciever and then the TV.
So enable Control for HDMI and check your settings.
