has1981
HT ZF9
Hi guys.
Just purchased the ZF9 and it seems to be working fine. 1 small problem. Everytime i press the different sound mode buttons or vertical surround button nothing seems to happen and display message reads ' not use ' any ideas ?
Thanks
6 REPLIES 6
EdwinaU
Moderator
Hi there,
Welcome to the community.
We'll look into this and let you know what we find out.
In the meantime, some of our members may be able to advise you.
Best wishes,
Ed
Vanilla_
Hi has1981,
Congrats on your new purchase! I believe this could be related to the limitations of using the sound mode functions. Let us know how you normally use the soundbar. Is it connected via Bluetooth to other devices? Do you use Amazon Alexa or ChromCast?
Cheers,
Vanilla_
profile.country.HR.title
zelenooq
hi,
can you plase try this video and tell me do you hear subwoofer and rear speakers if it is connected with bluetooth?
https://www.youtube.com/watch?v=eL9-sIZRDHg
Thank You
Dts hd master sound check 5.1.The original file (827mb,m2ts,5.1ch) https://drive.google.com/file/d/0B4nYAKUiVpepY1NuQW5ER3l3SXc/view?usp=drivesdk&resourcekey=0-p07nar3wkEpdsYkawD2qcg
LightFoot
Specialist
@zelenooq wrote:
hi,
Thank You
Hi @zelenooq   I tried your 2009 file and I think it is deeply flawed. Whereas perfect sound for the introductory and ending music on all speakers, the white noise tests were rubbish. Tried from iPad Bluetooth and KD-55XE9305 YouTube with the same results. I think you need to find an up-to-date test to try. HT-ZF9 & SA-Z9R.
zelenooq
ok, i found out where is the problem.
i have windows 10 pro and i want to be connected to soundbar with bluetooth
but when i am connected, windows 10 shows only stereo sounds
how to setup windows to get 5.1 sound over bluetooth?
even better, how to get dolby atmos over bluetooth with windows?
zelenooq
I also read that HT-ZF9 supports DLNA, is it true?
