am unable to lock other than Pattern, Pin, and password. Other lock shows like disabled by administrator? Please help me to get those
Some security softwares and company policies can disable these options. Go to Setting -> Security -> Device administrators to see what administrators you have in the phone. If you disable the administrator you'll be able to select for example Swipe but the software/account that added the administrator will probably stop working.
Issue resolved by clearing credentials in setting-> security
