i m facing a mejor problem with my Live With Walkman phone when i tried to open bluetooth connection the OS crashed(ICS 4.04 buiid number 4.1.B.587 & unlocked boot loader & unrooted) it is restarting over & over again after the walkman LOGO appeared. it happened 4 times with my phone all the time I iupdated it by SONY Update Service. i think SONY expert team should think about this problem & fix the problem as early as possible and should launch an update by fixing this BUGS. thats it. thankz to everyone.I am from Bangladesh.
Hi Yasin,
Same prob. Just repair your phone using:
1. Sony PC Companion
OR
2. Sony Update Service (SUS)
Search this forum for download link.
Good luck........
can you connect to the sony pc companion eventhough your xperia live with walkman is off?
