Hi need help just put my sim back into my Xperia SP after using an iPhone for a while the screen just has like a keypad and emergency calls below I've tried the sim pin I was using before and on the iPhone and it just says wrong pin won't give me the forgotten pin option but receives calls and text fine so now I'm confused
