I'm on T-Mobile (UK) and can't send picture messages. I've gon through all the help on the t-mobile site but nothing has worked. Does anyone know how to fix this problem?
Thanks
are you aware that you need 2 APN settings?
Don't forget to mark the Correct Answers & Helpful Answers
Have you tried to set up the MMS service manually?
I've followed instructions from the t-mobile website to add an APN but that hasn't helped. I can send pictures when I'm connceted to wi-fi but can't send when only on mobile signal
Picture Messages (MMS) MUST go through your network not wifi, so you do need a data plan.
I do have a data plan with T-mobile it covers everything
and are you certain that you have the correct APN settings, your data it's on and that it's working?
Yes used the settings they gave me on the t-mobile site and the plan is up and running
settings -> wireless & networks -> mobile networks -> access point names -> MENU -> add New
APN: general.t-mobile.co.uk
Proxy:
Port:
Username: t-mobile
Password: tm
Server:
MMSC: http://mmsc.t-mobile.co.uk:8002/
MMS proxy: 149.254.201.135
MMS port: 8080
MMS protocol: WAP 2.0
MCC: 234
MNC: 30
APN type: * (Just has an * in the field)
Proxy:
Port:
Username: user
Password: *** (Don't know password but it has 3 *'s in the field)
Server:
MMS port: 8080
MCC: 234
MNC: 30
APN type: mms
Menu > save
repeat
at the moment I have 5 apns for Tomile MMS
