downloadfile dot bin files
amit_rocking87
Hi can any one tell me what is "downloadfile.bin" which my phone automatically downloading??
I am not able to view for which software or system it is getting downloaded?
thomasacquins
I think it's Google play store app data backup
13 REPLIES 13
Thommo
Download avast to your phone and run a scan - Do not connect your phone to your Pc
amit_rocking87
Done but nothing wrong found
Thommo
Also try Malwarebytes and if nothing is found then you probably have an app installed that is causing this but I do know that not so long ago something with the same name popped up which was an Android virus - However you could try performing a system repair, see below for details
This will factory reset your phone
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
s4alon
I also got the same issue this morning
Suddenly downloading .bin file out of nowhere
Tried to tap it and redirect me to playstore at "my apps" menu
Is it possible from SONY or what ?
I never install anything out of playstore
Would be good if Sony staff could provide explanation
amit_rocking87
Exactly as soon as u click it..  It directs u to playstore but u cant see for which ap or system it is downloading.
I am scanning with malwarebytes now let see
thomasacquins
amit_rocking87
Done scanning with malwarebytes and nothing found..  Now more curious
amit_rocking87
I was just checking on internet for more detail..  Some of htc user also experienced the same file but no one know for which software or app it is..
thomasacquins
If back up and automatic restore is enabled in backup and reset settings then phones settings and apps settings everything is backed up to Google account. If you reset or change your mobile then those settings are automatically restored. That's the reason ' .bin ' file is shown every time.In Kitkat devices it is shown background. When I was using Xperia L it was not showing.
