Emma Flashtool Help For D5102
Sangeeth47
I'm Done Everything, Drivers are installed, Copied Customization.ini in Root folder of emma, Connected Emma with network & My phone connected with Flashmode (Blue Light on ear piece also). But Phone doesn't detecting in App, no changes in emma flashtool.. i can't flash firmware.. Please Help me.
My device Details
Phone : Sony Xperia T3 D5102
15 REPLIES 15
Sangeeth47
I need to know other Think too, Some others says that, After Flashing Firmware Others Phone Stuck at Sony Wave [ Boot loop ].. It is possible to me [ Bootloop ]...? If stuck in Bootloop what will do next? I need to know detail about it. Thanks....
Sangeeth47
I'm Going To Flash my T3 D5102 by Emma Flashtool, Some users says that after flashing Phone Stuck at Booting (at Sony Wave).... It is Possible To me? What will do when happens this?
Tags (1)
Sangeeth47
I need to know one think... I'm done everything for flashing, at the time of connecting my device the app says No available services matched the connected device. Then how to flash firmware for my device?
Some users says that after flashing Firmware Via Emma Flashtool in some phone Stuck in Bootup, at the time of Sony Wave ... If i flash my phone firmware it is possible to bootloop for me (Stuck at Sony Wave).. If my phone bootloop what will do next?
MY DEVICE : SONY XPERIA T3 D5102
Tags (1)
Uliwooly
@Sangeeth47
Why are you using EMMA instead of Flashtool? are you aware of the consequences of unlocking the bootloader?
Sangeeth47
Already Unlocked Bootloader...
Alias4153
help sony D5102 update system
