Folder in application page?
RÉSOLU
Non applicable
can i create something like a folder to group my apps into games, utility and ect????
1 SOLUTION APPROUVÉE
Solutions approuvées
Uliwooly
it seems that you have a lot of questions
long press anywhere or press menu (add) on your homescreen -> tap on folder -> then just drag the apps there
another cool way to do it, put an app/icon on your homescreen, then drag another app that you want in the same folder, the phone will ask you which type of folder you want to create
Voir la solution dans l'envoi d'origine
9 RÉPONSES 9
Uliwooly
Dr_Chris
Héros
http://talk.sonyericsson.com/message/22126#22126 You might want to see Sushidushi's suggestions from this thread.
Non applicable
well... thanks for answering all my questions then=) still new to the phone u see=) luckily i found out this forum and helpful ppl like u. XD
Non applicable
thanks dr chris! her suggestions are great=)
Uliwooly
anytime
Dr_Chris
Héros
Good stuff!
Non applicable
thanks again uliwooly=)
Uliwooly
Slightly_smiling_Face
