hi
i forgot my password and now i can not log in to my xperia p!!
i can not use PCC because i needs to be unlocked(that is not!!)
how can i reset or remove the password??
or how can i hard reset my xperia p??
i used pressing up volume key + power button but i didnt work!!
pls help me 😞
really thanks
hi man i have the same problem how did u did it?:smileyworried:
You need sony update service.
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
My phone switch on message unfortunately experya not support
