Help ! My Xperia PLAY screen is all fuzzy like a TV
Not applicable
The screen has totally froze no movement at all.Like a white background with millions of different dot colours.
Reminds be abit of fuzzy on TV but still
Tried switching on/off remove battery etc but still same
Any ideas?
you can try Update Service to repair your phone
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
know that it will delete everything on your  phone
8 REPLIES 8
take the battery out, and w/o the battery press and hold the Power button for few seconds, then try again
Not applicable
Thank you for your swift reply.
I have done that just but sadly the problem still exists....its like a mosiac filling the whole screen.
One minute the phone was working the next complete blank out
for future reference
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Not applicable
I have the same issue on my experia play, and none of the mentioned here fixes are working for me just a ststic, fuzzy screen. Dose any one have any more ideas on how to get the display up and running again?
it might be a hardware problem more than a software glitch
if you want to contact SE
http://www.sonyericsson.com/cws/common/contact?cc=gb&lc=en
Not applicable
So this is for anyone that has this problem and seeks out help like I did. I was playing around with my phone while looking up ways to fix its static screen and stuff. I fixed it by holding down the power button for a moment until i knew the screen would normally have the phone options onscreen, then i just tapped the screen attempting to hit where these options would be and when i hit one, i think it was "silent mode" my screen flashed back to normal. I hope this can help someone with this terrifying problem.
Wave_Shock
This is many many years later but this worked wonderfully for my old Xperia Play that I'm nostalgic towards. Thank you! You're a gentleman and a scholar Slightly_smiling_Face
