If you clear data for the settings app in settings-apps-all-scroll down to settings,you will not lose much,but if you reset to factory settings,you will lose internal memory.
on top of developer option screen you have slider..you can turn develoer option on or off
I don't think you can - There is a toggle when you open Developer options but it won't remove the option from settings
Actually,settings-apps-all-settings,clear data should help.
Just tried that and no luck still the same on my phone running 4.3 - However every app I disabled got re-enabled so I won't be doing that again
Sorry,but I suggested this to someone before and it worked.
reflash the ftf file and it will disappear
Apologies to Alex it does work
As Alex said but when you get to all don't choose the Settings icon scroll down the list untill you see Settings then tap Clear data
Yes,that is what I meant,scroll down to settings app.Anyway,glad I could help.No problem,Thommo.
Hi samrocks,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
With the information currently available to me, I can advise that the only way to hide the developer options is to perform a Factory Reset.
I hope this helps.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
