How to disable developer option
ROZWIĄZANE
samrocks
Początkujący
By mistake i clicked thrice on the build number and the developer option appeared on my settings menu
After that my battery is draining very quickly and even in idle mode when m not using the phone..
Can anyone plz tell me how to disable it from the settings menu
Plz help
Tagi (1)
1 ZAAKCEPTOWANE ROZWIĄZANIE
Zaakceptowane rozwiązania
profile.country.RO.title
_alexdon_
If you clear data for the settings app in settings-apps-all-scroll down to settings,you will not lose much,but if you reset to factory settings,you will lose internal memory.
alexdon
Wyświetl rozwiązanie w oryginalnym poście
19 ODPOW. 19
Danial-mach1
Pasjonat
on top of developer option screen  you have slider..you can turn develoer option on or off
Thommo
I don't think you can - There is a toggle when you open Developer options but it won't remove the option from settings
_alexdon_
Actually,settings-apps-all-settings,clear data should help.
alexdon
Thommo
Just tried that and no luck still the same on my phone running 4.3 - However every app I disabled got re-enabled so I won't be doing that again
_alexdon_
Sorry,but I suggested this to someone before and it worked.
alexdon
dm84
Doradca
reflash the ftf file and it will disappear
Thommo
Apologies to Alex it does work
As Alex said but when you get to all don't choose the Settings icon scroll down the list untill you see Settings then tap Clear data
_alexdon_
Yes,that is what I meant,scroll down to settings app.Anyway,glad I could help.No problem,Thommo.
alexdon
Hi samrocks,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
With the information currently available to me, I can advise that the only way to hide the developer options is to perform a Factory Reset.
I hope this helps.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
