Incoming call: no alert - After upgrade to Kernel 3.0.08+ build 6.1.1.B.1.54 incoming calls don't give any sound. I can manage to get the 'Vibrte on Ring' working but no alert sound ! Hence I miss many incoming calls. Silent mode = 'Off' Please help.
If I select a different ringtone using Sound Picker - the 'music' doesn't play neither.
Please help
I have the same problem after I have selected my own tune in Set Up - Notifications & Sound. Strangely, calls from land lines didn't ring, no matter whether I have set special ringtone for the contact or not, but calls from mobile phones did ring.
However, it worked again after I did the following, which you can try:
Go to the Music app instead of Set Up, pick a tune you want, select Set As Ringtone. After that, all calls ring!
I am using Sony Xperia z3, even I faced the same issue after upgrading to Android 6.0.1.
First what I did is in settings-->sound & notification-->phone ringtone and selected a song , but it didnot work.
So , I went to music app and selected a song and set as ringtone .... it worked.
I don't know the root cause but anyway now I am getting sound for incoming calls.
Hope it works for you.
I dont what happened ,just this morning I found out that there was no incoming call sound.please help me.
