keypad problems
brianprsa3_gmai
keypad problems
I have a problem with the text buttons on phone they are out of sequence or do not work at all
10 REPLIES 10
Sam
Legend
Legend
Try this: Main Menu > Settings > Apps > All > Xperia keyboard (assuming this is the one you are using) > Clear Data.
What are your thoughts about this forum? Let us know by doing this short survey.
brianprsa3_gmai
settings button not working,same with keyboard only some buttons responding
Buvleen
My keypad decides to ignore what I type sometimes. It registers that I'm typing but the words don't appear in the text box. Helpful.
Anyone else have this problem?
Rickard
Master
If this happens in all apps, try clearing data for the keyboard as explained by Sam. If it's in a certain app then it might be a problem with that app and not the keyboard.
If it happens in all apps and clearing data for the keyboard doesn't help i recommend that you try updating the phone using PC Companion. You can also try using another keyboard (SwiftKey or similar) to see if it's a problem with the phones keyboard or some other problem with the phone.
girlygirl
yeah! it worked!
loong_15DG
Thank you for the forum and reply. Very helpful. It's worked. Once cleared the data of keyboard, Yes can use back..TQ..TQ..TQ...
Tags (1)
MBLRC
MY keypad is slow and letter q, 1, @, space bar not responds and my left side no Responses. What Should I do ?
Lynne-byn
Thanks Sam I've my keypad numbers back again, well they've disappeared but at least can use them, it's definitely that part of phone as letters don't work there either
Mik5
I. Tried to type what's wrong with my phone but it deleted it so I'm just gonna keep it short, it presses buttons and holds them, I've tried repair via companion app and clear keyboard data but still not working, I'm going to order a Samsung I think
