My sony Xperia U is restarting automatically
naveen_kandakur
Hi All,
I bought new sony xperia U 15 days back phone is good but i am facing following problems  please help me in this regard
problems:
1) My phone get restarts automatically some times
2) Some times Data traffic symbol(H) will not disappear even datatrafic is disabled
   - when this issue appears i am not able to access internet  event after enabling data traffic also
   - Issue resoles after restart of the phone its irritating to reastart phone again and again
18 REPLIES 18
angelasruthi
and changing a sim needs means a lot to me. as i have to update many things with my new number which is a long process.
Uliwooly
I've seen issues like that and it's all bc of the SIM card
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
angelasruthi
and i forgot to mention , it is often showing ".com.android..bla bla .." is not responding would you want to force to close it or wait ..some thing like this.  this is clue less.
this beahves as if i am using it for ages. i didnt use it properly for even one day. and i am sorry to say that this is totally annoying . i paid 15K and bought problems instead of a mobile..
Uliwooly
1st remove the sim card
2ndrepair your phone with SUS
3rd do NOT restore anything, not settings, apps, etc
4th remove mcafee
see if the problem it's gone
mtahaalam
Hi there,
Those who are suggesting to change the sim are completely pathetic advices. Sims are based on particular standards and Phone Resets have nothing to do with it.
You are requested to observe your Applications that are always running. Remove the unwanted application and check for FREE RAM (CLICK IT ON BOTTOM LEFT WHEN CLICKING RUNNING APP) and clear the cache memory there aswell.
Also if you still have mcafee, uninstall that aswell. Remove the apps that pops in advertisements and do not download apps from UNKNOWN resources.
Hope this solves the mystery! 😃
Regards,
Taha
Uliwooly
lol seriously?
make sure the phone it's on > remove the SIM card (while the phone it's on) what happen when you do so?
keep in mind forum rules for your next posts
Arnab
Enthusiast
boooooooooooootlooooooooooooooopssssssssssss...10 points to Gryffindor.......
Please mark Correct and Helpful answers and you can also visit my blog at:arnabghosal1989's Blog
bernet
where to get those things pcc,SUS repairing tool
bernet
no it is about that since i changed the sim card and put a new one still does the same ,,but now i went to update ,,still updating,, let me waiting and see
