My xperia x10 mini won't turn on!
Not applicable
180 REPLIES 180
Not applicable
Hi to all, I am experiencing some problems with my xperia x10 Mini (E10a), the issue started like this "the phone starts giving me an error message on the screen while I was using the Internet navigator so I turn off the phone but when I turn it back on the operating system won´t work" I already try repair it whith PC companion but it gaves me a message that the is no software updates for my phone.
  • I try this procedure with PC companion (lateast version)
  • PC suite
  • And Update service (2.11.6.14)
But I´m still recieving the same message.
¿Do you know if I can intall the software manually using an other interface or application?
Regards.
Peter.
gwhispererz
Champion
Hi, if you have tried all methods stated in this thread, then you have no choice but to send phone to the nearest SE Service Centre.
Not applicable
To be honest, we know there is a very important problem with this cell phone and we should take all them back but is too expensive for our company and our public image could be damaged. So to our client we say : It's normal, the battery sometimes need to be charged 30 minutes before you can use phone, if your phone is charging since 3 days, contact your shop, they will change it and maybe the next will do the same error after the end of guaranty !
Not applicable
Don't worry it's not your fault, the problem is just between your hands :smileywink:. Welcome with us... in H*ell. Don't worry after this one, you won't buy any SE cell phone.
Not applicable
I bet they tell you you broke it
Not applicable
It seems like i have found a fix different than you guys, so please give it a try.
take out the battery, and hold down the power button for a sec or two before putting the battery into the phone again.
the phone has to be conected to the charger trough this entire prossess.
the simcards that are faulty i have been making work by having it halfway in the slot, and shoving it in right before placing battery back, in the prossess explained above.
hope this helps!
Not applicable
i've tried the method and it's work.. thanks..
Not applicable
please help me i tried to change rom but my phone crashed i doesnt respond to any command i give it plssssss help the rom was cyanogenmod 6 i realy dont wana lose it if you can help me please reply
gwhispererz
Champion
Hi, if the above suggestions didn't work out for you, you have no choice but to send it in for repair.
A point to note .... you might have void your warranty (if phone is still within the warranty period).
Good luck.
Not applicable
hi! well i am faceing a different kind of aproblem, well i was updateing my software (sony ericson pc companion 2.0) but during the update electricity went off, and after that my phone is showing an exlimation sign in the middle of a triangle and it just doesnt start and dies out,
pls pls pls if any one can help me... pls do!
:'( its really bad....
