I believe i was able to fix this BUG.
I have deleted ALL my contacts from SIM Card and the phone seems to works, I have turned on/off at least 20 times in the lasts 4hs and works (The battery is NOT totally charged).... cross your fingers.
BTW, X10 mini can not delete the contacts from SIM card itself, so, I used a VERY OLD phone to do this...
Can someone try this please?
FORGET THIS IT JUST WAS LUCK
I don't know what more to do...
-I have repaired the phone via SEUS
-I have bended the card gently...
-I cleaned the sim with alcohol.
-I did everything I find in internet...
-The service just repaired the phone with seus...
-I have lost all the data twice.
The problem is still the same. Regional support doesn't know when the update to the lastest firmware (two months later) will be available. (My phone is unbranded). My network operator has just ONE SIM model...
I fell, this is the worst purchase I made in my life.
I just got my mini pro 2 days ago and i'm also experiencing the same proble. I have been switching between two sims. I just keep trying until it turns on, but am worried that it takes a lot of effort to turn on the unit.
If you bought two days ago, try to get your money back.
I have changed the SIM card twice, I have repaired the phone 3 times, I cleaned the card... in Summary I did everything you can imagine and I was not able to fix this HUGE BUG.
I was trying differents thinks and I found this that works to me:
1- The phone turns on if the battery charge is 90 or above.
2- If the battery charge is less than 90 it doen't turn on, you need to connect the phone via USB and hold the back key until the red light appears.
Can someone confirm this?
Hello! I'm from Russia and also I have a problem!
Phone does not start with the sim card (((
Help please!
The service centers can not solve the problem (((
New firmware: "Androyd 2.1" will help solve the problem?
I hope to answer a specialist from SE! ))
Check this out, and tell us if it applies to you:
Yes! I have the same problem with x10 mini ((((
Excuse me, little speak English
I don't speak english natively either, so don't worry.
The question is... what firmware version do you have?
firmware 1.1.A.0.8
