Hey guys...
I have a Xperia Neo V, with ICS 4.0.3 Nordic...
And today my phone was working correctly and i did put it in my backpack
Few minutes ago when i took it from my backpack, the screen was with a strange bar on the top and it shows:
P: 0/1 | dX: 0.0 | dY: 0.0 |Yv: 0.0 | Prs: 0.13 | Size: 0.15 |
And when i touch the screen, these values changes acordding to the localization where i touch and it makes like a DRAW where i touch with a crosshair where my finger is...
I really dont know what happend and i would be very great if someone could help me
Thanks
Paulo Oliveira
its not a strange bar
u have activated the Pointer location of ur pone
to deactivate it
just go in the "settings menu"
then "developers options" and in developers options
uncheck the "Pointer location"
ur prblm will be solved
it just tells u ur current touch data
can you take a screenshot?
press and hold both Power button & Volume up
How can i post here? i'm newbie
have you tried to turn off/on the phone, take the battery out wait few seconds then check again.
once you take the pictures click on reply -> click on the camera and add them (send the pictures to your email or trasnfer them to your computer)
Nice to know, thanx for the info
my pleasure:smileyhappy:
Thanks, I had this problem too... Its a pain in the to deal with but easy to fix thanks to karen
