Network Unlock 0 tries left
Gunworm
Hi there,
I have a network locked (Drei  Austria) xperia V. As I switched to another network provider (Telering Austria) I wanted to unlock the phone. Stupid enough I tried the new PIN and PUK as unlock codes (I found out later that I wasted my 5 tries by doing that). I purchased an unlock key for 40 Euros but I can not use it because I have no tries left.
Is it possible to reset the counter somehow or enter the unlock code direclty using ADB & Fastboot commands?
10 REPLIES 10
profile.country.RO.title
_alexdon_
If the counter shows 0,as far as I know there is nothing you can do.
alexdon
Uliwooly
I agree with Alexdon, you won't be able to unlock it
Jake-SonyXperia
Champion
Hi Gunworm,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You will need to get the device to a service agent to have this reset. Please contact Sony Xperia Care within your region.
http://www.sonymobile.com/global-en/support/contact-us/
I apologize for the inconvenience this may cause.
Gunworm
Got on touch with Sony Care and received a solution a few hours later.
Insert old/original SIm card and enter the following in the dialer
*#7465625*99*NCK#
NCK needs to be replaced with the unlock key from the network provider.
Unfortunatly this solution did NOT work for me (invalid MMI entered). Maybe because the original phone number/SIM is no longer active. An other active SIM card from the same provider didn't work either.
I contacted sony care again and wait for an anwer.
Anyway Sony support is great and fast!
ERICCORK
Did you ever resolve this with Sony?
Amir25
there's a service to unlocked Sony Xperia without entering unlocking code, We(business) use that if a cusomter comes with this problem. it cost slilghtly more to unlock but it is possible.
contact :Mobile Exchange ,Macclesfield, UK
if need further help
Jack68
it does not work with original card either. Same problem and can't be done unless I send phone to Sony for a repair but  they can't tell how much it would cost.
robone471
Hi. I have the same problem. Why can't Sony give me the cost of this. I have to send the phone to Sony. Then they will tell me the cost. If it's to expensive then I have to pay £25 just to get the phone back. 😡
ljamal74
il faut un logitiel qui s'appel qunlock tool mais avec un credit qui cout 25 euro pour un telephone
 you need a software called qunlocktool but with a credit that costs 25 euro for a phone
gt
