my xperia j shows Unfortunately, the process com.android.phone has stopped in every 3 seconds....
please help me!
I cant call or text anyone due to this...
Please Help me!
I am now trying to update it to see if it gets fixed!
My phone Sony xperia shows Unfortunately, the process com.android.phone has stopped in every 3 seconds....
please help me!
I've tried everything to fix it but I am failing
Process.com.android.phone has stopped IN MY SONY XPERIA E3 PHONE.
PLEASE SOLVE THE PROBLEM.
I'd suggest that you perform a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Don't forget to backup using Xperia Companion, but preferably without adding apps or settings to the backup. If the phone keeps hanging and won't allow you to backup, then, unfortunately, you will lose any data stored on the internal memory.
Follow the steps given in blue links, and keep us updated.
Нажаль com.android.phone припинив роботу.
Unfortunately com.android.phone has stopped working.
gt
no Process.com.android.phone has stopped
