This morning, I clicked on bluetooth widget by mistake which rebooted the phone. Since then it was continously on boot loop and keeps on rebooting itself after the XPERIA logo.
It got turned on once in afternoon after which i did a factory reset and it was working fine. In eve I tried to turn the bluetooth on and it is around 4-5 hours my phone is still rebooting continously.
It is Android 4.0.4 and never rooted, minimum apps, all are from PlayStore only. Please help.
I would advise running a repair to reload the firmware in this case:
1. Before you start you have to download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
What are your thoughts about this forum? Let us know by doing this short survey.
5. Start.
6. Repair Phone
7. Continue
9. Next
11. Select Phone
Hello Sam,
Thanks for your assistance on this. I did the repair phone option and it has fixed the issue for me.
Just curious if there is any known bug for crash when bluetooth is turned on. If so, what is the fix? And under which circumstances it can re-occur??
Anyways thanks again for your help!
One more thing, with this failure this time and a lot of troubles, I think this release doesn't seems much stable for xperia mini pro.
I feel to use some customer Roms now to taste other releases like JB, on my phone.
From sony developers website, I got the root software - Emma, but seems it is only for a couple of xperia devices.
Is there any other official flashtool for other xperia devices or to be precise for Xperia Mini Pro (SK17i)?
-Thanks
It fails again & again! There seems to be a Software/Hardware Bug! It happens in my SK17i too, which has ICS 4.0.4(not yet rooted). I tired to find a way to do a hard-reset without connecting it to PC, but I found none except repairing the phone using Update Service or PC Companion. Hard reset would be the best way, if there is any, to restore SK17i to factory defaults when we're away from home! Hope the Xperia Team take a look into this strange/frustrating issue/bug!
Thanks!
Same issue here, my phone was running like a charm since month this morning it just started to reboot in an endless loop.
The proposed solution with PC companion does not work, since the phone reboots to fast and PC companion does not have any chance to detect it.
I had the devlopper option activated and i could extract a log :
?:??: W/?(?): --------- beginning of /dev/log/main
01-06 01:44:39.502: D/kernel(140): [ 5.966033] APPS : 00000000 00000000 00000000
01-06 01:44:39.502: D/kernel(140): [ 5.966033] ROW : 00000000 00000000
01-06 01:44:39.502: D/kernel(140): [ 5.966094] Disabled VREG "gp3"
01-06 01:44:39.502: D/kernel(140): [ 5.966125] Disabled VREG "gp5"
01-06 01:44:39.502: D/kernel(140): [ 5.966186] acpu_clock_init()
01-06 01:44:39.502: D/kernel(140): [ 5.966552] ACPU running at 768000 KHz
01-06 01:44:39.502: D/kernel(140): [ 5.967193] ACPU init done, clock rate now : 1024000
01-06 01:44:39.502: D/kernel(140): [ 5.968414] ram_console: got buffer at 4ffe0000, size 20000
01-06 01:44:39.502: D/kernel(140): [ 5.968414] ram_console: found existing buffer, size 57485, start 57485
01-06 01:44:39.502: D/kernel(140): [ 5.969116] console [ram-1] enabled
01-06 01:44:39.502: D/kernel(140): [ 5.969726] snddev_poweramp_gpio_init
01-06 01:44:39.502: D/kernel(140): [ 5.971466] aux_pcm_gpio_init
01-06 01:44:39.502: D/kernel(140): [ 5.972045] Enabled VREG "gp13" at 3050 mV
01-06 01:44:39.502: D/kernel(140): [ 5.972503] Enabled VREG "gp4" at 2600 mV
01-06 01:44:39.502: D/kernel(140): [ 5.972930] Enabled VREG "gp6" at 2900 mV
01-06 01:44:39.502: D/kernel(140): [ 5.973388] Enabled VREG "gp7" at 1800 mV
01-06 01:44:39.502: D/kernel(140): [ 5.973541] Vibrator: enable voltage 2700(mV)
01-06 01:44:39.502: D/kernel(140): [ 5.973999] Enabled VREG "gp7" at 1800 mV
01-06 01:44:39.502: D/kernel(140): [ 5.974365] Enabled VREG "gp6" at 2850 mV
01-06 01:44:39.502: I/kernel(140): [ 6.008483] pm8058_init: i2c_add_driver: rc = 0
01-06 01:44:39.502: D/kernel(140): [ 6.008941] pm8058_probe: PMIC revision: E3
01-06 01:44:39.502: D/kernel(140): [ 6.010253] pm8058_gpio_probe: gpiochip_add(): rc=0
01-06 01:44:39.502: D/kernel(140): [ 6.010559] pm8058_mpp_probe: gpiochip_add(): rc=0
01-06 01:44:39.502: W/kernel(140): [ 6.015838] bio: create slab
01-06 01:44:39.502: I/kernel(140): [ 6.016510] SCSI subsystem initialized
01-06 01:44:39.502: D/kernel(140): [ 6.016754] usbcore: registered new interface driver usbfs
01-06 01:44:39.502: D/kernel(140): [ 6.016815] usbcore: registered new interface driver hub
01-06 01:44:39.502: D/kernel(140): [ 6.016876] usbcore: registered new device driver usb
01-06 01:44:39.502: D/kernel(140): [ 6.016967] msm_i2c_probe
01-06 01:44:39.502: D/kernel(140): [ 6.017059] msm_i2c_probe: clk_ctl 35d, 100000 Hz
01-06 01:44:39.502: D/kernel(140): [ 6.017608] msm_i2c_probe
01-06 01:44:39.502: D/kernel(140): [ 6.017669] msm_i2c_probe: clk_ctl 35d, 100000 Hz
01-06 01:44:39.502: D/kernel(140): [ 6.018371] Bluetooth: Core ver 2.15
01-06 01:44:39.502: D/kernel(140): [ 6.018463] NET: Registered protocol family 31
01-06 01:44:39.502: D/kernel(140): [ 6.018463] Bluetooth: HCI device and connection manager initialized
01-06 01:44:39.502: D/kernel(140): [ 6.018493] Bluetooth: HCI socket layer initialized
01-06 01:44:39.502: D/kernel(140): [ 6.018585] Switching to clocksource gp_timer
01-06 01:44:39.502: D/kernel(140): [ 6.021820] NET: Registered protocol family 2
01-06 01:44:39.502: D/kernel(140): [ 6.021942] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
01-06 01:44:39.502: D/kernel(140): [ 6.022186] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
01-06 01:44:39.502: D/kernel(140): [ 6.022460] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
01-06 01:44:39.502: D/kernel(140): [ 6.022583] TCP: Hash tables configured (established 16384 bind 16384)
01-06 01:44:39.502: D/kernel(140): [ 6.022583] TCP reno registered
01-06 01:44:39.502: D/kernel(140): [ 6.022674] NET: Registered protocol family 1
01-06 01:44:39.502: D/kernel(140): [ 6.022888] RPC: Registered udp transport module.
01-06 01:44:39.502: D/kernel(140): [ 6.022888] RPC: Registered tcp transport module.
01-06 01:44:39.502: D/kernel(140): [ 6.022918] RPC: Registered tcp NFSv4.1 backchannel transport module.
01-06 01:44:39.502: D/kernel(140): [ 6.023040] Trying to unpack rootfs image as initramfs...
01-06 01:44:39.502: D/kernel(140): [ 6.069305] Freeing initrd memory: 952K
01-06 01:44:39.502: D/kernel(140): [ 6.070159] smd probe
01-06 01:44:39.502: D/kernel(140): [ 6.070159] smd_core_init()
01-06 01:44:39.502: D/kernel(140): [ 6.070220] smd_core_init() done
01-06 01:44:39.502: D/kernel(140): [ 6.070220] smd_alloc_loopback_channel: 'local_loopback' cid=100
01-06 01:44:39.502: D/kernel(140): [ 6.070404] last_amsslog: Log not present
01-06 01:44:39.502: D/kernel(140): [ 6.070678] smd_alloc_channel() 'DS' cid=0
01-06 01:44:39.502: D/kernel(140): [ 6.070739] smd_alloc_channel() 'DIAG' cid=1
01-06 01:44:39.502: D/kernel(140): [ 6.070800] smd_alloc_channel() 'RPCCALL' cid=2
01-06 01:44:39.502: D/kernel(140): [ 6.070861] smd_alloc_channel() 'DATA1' cid=7
01-06 01:44:39.502: D/kernel(140): [ 6.070922] smd_alloc_channel() 'DATA2' cid=8
01-06 01:44:39.502: D/kernel(140): [ 6.070983] smd_alloc_channel() 'DATA3' cid=9
01-06 01:44:39.502: D/kernel(140): [ 6.071044] smd_alloc_channel() 'DATA4' cid=10
01-06 01:44:39.502: D/kernel(140): [ 6.071105] smd_alloc_channel() 'DATA5' cid=11
01-06 01:44:39.502: D/kernel(140): [ 6.071136] smd_alloc_channel() 'DATA6' cid=12
01-06 01:44:39.502: D/kernel(140): [ 6.071197] smd_alloc_channel() 'DATA7' cid=13
01-06 01:44:39.502: D/kernel(140): [ 6.071258] smd_alloc_channel() 'DATA8' cid=14
01-06 01:44:39.502: D/kernel(140): [ 6.071319] smd_alloc_channel() 'DATA9' cid=15
01-06 01:44:39.502: D/kernel(140): [ 6.071380] smd_alloc_channel() 'DATA11' cid=17
01-06 01:44:39.502: D/kernel(140): [ 6.071441] smd_alloc_channel() 'DATA12' cid=18
01-06 01:44:39.502: D/kernel(140): [ 6.071502] smd_alloc_channel() 'BRG_1' cid=28
01-06 01:44:39.502: D/kernel(140): [ 6.071563] smd_alloc_channel() 'DAL00' cid=38
01-06 01:44:39.502: D/kernel(140): [ 6.071624] smd_alloc_channel() 'BRG_0' cid=39
01-06 01:44:39.502: D/kernel(140): [ 6.071685] smd_alloc_channel() 'DATA5_CNTL' cid=40
01-06 01:44:39.502: D/kernel(140): [ 6.071746] smd_alloc_channel() 'DATA6_CNTL' cid=41
01-06 01:44:39.502: D/kernel(140): [ 6.071807] smd_alloc_channel() 'DATA7_CNTL' cid=42
01-06 01:44:39.502: D/kernel(140): [ 6.071838] smd_alloc_channel() 'DATA8_CNTL' cid=43
01-06 01:44:39.502: D/kernel(140): [ 6.071899] smd_alloc_channel() 'DATA9_CNTL' cid=44
01-06 01:44:39.502: D/kernel(140): [ 6.071960] smd_alloc_channel() 'DATA12_CNTL' cid=45
01-06 01:44:39.502: D/kernel(140): [ 6.073486] SMD Packet Port Driver Initialized.
01-06 01:44:39.502: E/kernel(140): [ 6.073608] Notify: smsm init
01-06 01:44:39.502: E/kernel(140): [ 6.073760] Notify: general
01-06 01:44:39.502: E/kernel(140): [ 6.073791] Notify: general
01-06 01:44:39.502: E/kernel(140): [ 6.073822] Notify: general
01-06 01:44:39.502: D/kernel(140): [ 6.074127] SMD: ch 2 0 -> 1
01-06 01:44:39.502: D/kernel(140): [ 6.074371] SMD: ch 2 1 -> 2
01-06 01:44:39.502: D/kernel(140): [ 6.074432] [afe.c:afe_init] AFE driver init
01-06 01:44:39.502: D/kernel(140): [ 6.075195] [audpp.c:audpp_probe] Number of decoder supported 5
01-06 01:44:39.502: D/kernel(140): [ 6.075195] [audpp.c:audpp_probe] Number of concurrency supported 7
01-06 01:44:39.502: D/kernel(140): [ 6.075195] [audpp.c:audpp_probe] module_name:AUDPLAY4TASK
01-06 01:44:39.502: D/kernel(140): [ 6.075225] [audpp.c:audpp_probe] queueid:17
01-06 01:44:39.502: D/kernel(140): [ 6.075225] [audpp.c:audpp_probe] decid:4
01-06 01:44:39.502: D/kernel(140): [ 6.075225] [audpp.c:audpp_probe] nr_codec_support:1
01-06 01:44:39.502: D/kernel(140): [ 6.075256] [audpp.c:audpp_probe] module_name:AUDPLAY3TASK
01-06 01:44:39.502: D/kernel(140): [ 6.075256] [audpp.c:audpp_probe] queueid:16
01-06 01:44:39.502: D/kernel(140): [ 6.075256] [audpp.c:audpp_probe] decid:3
01-06 01:44:39.502: D/kernel(140): [ 6.075256] [audpp.c:audpp_probe] nr_codec_support:11
01-06 01:44:39.502: D/kernel(140): [ 6.075286] [audpp.c:audpp_probe] module_name:AUDPLAY2TASK
01-06 01:44:39.502: D/kernel(140): [ 6.075286] [audpp.c:audpp_probe] queueid:15
01-06 01:44:39.502: D/kernel(140): [ 6.075286] [audpp.c:audpp_probe] decid:2
01-06 01:44:39.502: D/kernel(140): [ 6.075286] [audpp.c:audpp_probe] nr_codec_support:11
01-06 01:44:39.502: D/kernel(140): [ 6.075317] [audpp.c:audpp_probe] module_name:AUDPLAY1TASK
01-06 01:44:39.502: D/kernel(140): [ 6.075317] [audpp.c:audpp_probe] queueid:14
01-06 01:44:39.502: D/kernel(140): [ 6.075317] [audpp.c:audpp_probe] decid:1
01-06 01:44:39.502: D/kernel(140): [ 6.075347] [audpp.c:audpp_probe] nr_codec_support:11
01-06 01:44:39.502: D/kernel(140): [ 6.075347] [audpp.c:audpp_probe] module_name:AUDPLAY0TASK
01-06 01:44:39.502: D/kernel(140): [ 6.075347] [audpp.c:audpp_probe] queueid:13
01-06 01:44:39.502: D/kernel(140): [ 6.075347] [audpp.c:audpp_probe] decid:0
01-06 01:44:39.502: D/kernel(140): [ 6.075378] [audpp.c:audpp_probe] nr_codec_support:11
01-06 01:44:39.502: D/kernel(140): [ 6.075897] [snddev_ecodec.c:snddev_ecodec_init] snddev_ecodec_init
01-06 01:44:39.502: D/kernel(140): [ 6.078704] SMD: ch 38 0 -> 1
01-06 01:44:39.502: D/kernel(140): [ 6.078796] SMD: ch 38 1 -> 2
01-06 01:44:39.502: E/kernel(140): [ 6.080810] rpcrouter: Server create rejected, version = 0, program = 3000001f
01-06 01:44:39.502: D/kernel(140): [ 6.086944] [adsp.c:adsp_rtos_mtoa_cb] INIT_INFO Event
01-06 01:44:39.502: D/kernel(140): [ 6.087036] [adsp.c:adsp_init] msm_adsp -- 0
01-06 01:44:39.502: D/kernel(140): [ 6.087280] [lpa.c:lpa_probe] lpa probe
01-06 01:44:39.502: D/kernel(140): [ 6.087463] audio_mvs_init:
01-06 01:44:39.502: D/kernel(140): [ 6.087768] input: cyttsp_key as /devices/virtual/input/input0
01-06 01:44:39.502: D/kernel(140): [ 6.087890] input: msm_pmic_pwr_key as /devices/virtual/input/input1
01-06 01:44:39.502: E/kernel(140): [ 6.088287] rmt_storage_init_ramfs: No RAMFS table in SMEM
01-06 01:44:39.502: W/kernel(140): [ 6.088317] rs300000a7: probe of rs300000a7.65536 failed with error -2
01-06 01:44:39.502: D/kernel(140): [ 6.088378] semc_battery_data semc_battery_data: probe
01-06 01:44:39.502: D/kernel(140): [ 6.088806] simple_remote_pf simple_remote_pf.0: Successfully registered
01-06 01:44:39.502: D/kernel(140): [ 6.089599] ashmem: initialized
01-06 01:44:39.502: V/kernel(140): [ 6.090515] yaffs: yaffs built Jul 13 2012 21:23:05 Installing.
01-06 01:44:39.502: D/kernel(140): [ 6.090545] msgmni has been set to 679
01-06 01:44:39.502: D/kernel(140): [ 6.090606] audio_mvs_thread:
01-06 01:44:39.502: D/kernel(140): [ 6.092712] alg: No test for stdrng (krng)
01-06 01:44:39.502: D/kernel(140): [ 6.092742] io scheduler noop registered
01-06 01:44:39.502: D/kernel(140): [ 6.092773] io scheduler deadline registered (default)
01-06 01:44:39.502: D/kernel(140): [ 6.094299] Registered led device: lcd-backlight
01-06 01:44:39.502: D/kernel(140): [ 6.094360] Registered led device: button-backlight
01-06 01:44:39.502: D/kernel(140): [ 6.094421] Registered led device: keyboard-backlight
01-06 01:44:39.502: D/kernel(140): [ 6.094482] Registered led device: red
01-06 01:44:39.502: D/kernel(140): [ 6.094543] Registered led device: green
01-06 01:44:39.502: D/kernel(140): [ 6.094604] Registered led device: blue
01-06 01:44:39.502: D/kernel(140): [ 6.116912] msm_fb_probe: phy_Addr = 0x2eef000 virt = 0xd0800000
01-06 01:44:39.502: D/kernel(140): [ 6.117279] MDP HW Base phy_Address = 0xa3f00000 virt = 0xd0100000
01-06 01:44:39.502: D/kernel(140): [ 6.117431] mdp_clk: mdp_clk=192000000
01-06 01:44:39.502: D/kernel(140): [ 6.117431] mdp_hw_version: mdp_hw_revision=1
01-06 01:44:39.502: D/kernel(140): [ 6.119689] mdp4_fetch_cfg: dmap=47 vg=c7
01-06 01:44:39.502: D/kernel(140): [ 6.120117] mddi_clk init rate is 92160000
01-06 01:44:39.502: D/kernel(140): [ 6.120239] primary mddi base phy_addr = 0xad600000 virt = 0xd003c000
01-06 01:44:39.502: W/kernel(140): [ 6.130462] mddi_sony_lcd_init (ver:0x3) [0]
01-06 01:44:39.502: W/kernel(140): [ 6.130462] msm_mddi_semc_mogami_display_init
01-06 01:44:39.502: W/kernel(140): [ 6.130523] mddi_sony_lcd_probe [0]
01-06 01:44:39.502: W/kernel(140): [ 6.130706] MDDI: SONY HVGA: Found display with module ID = 0x4, revision ID = 0x3, driver IC ID = 0xf0, driver ID = 0x3
01-06 01:44:39.502: D/kernel(140): [ 6.131103] mdp4_display_intf_sel: 0xa
01-06 01:44:39.502: D/kernel(140): [ 6.134063] FrameBuffer[0] 320x480 size=1359872 bytes is registered successfully!
01-06 01:44:39.502: W/kernel(140): [ 6.158752] mddi_sony_ic_on_panel_off [1]
01-06 01:44:39.502: W/kernel(140): [ 6.158752] sony_lcd_driver_init [1]
01-06 01:44:39.502: W/kernel(140): [ 6.159149] sony_lcd_exit_sleep [1]
01-06 01:44:39.502: W/kernel(140): [ 6.279052] sony_lcd_dbc_on [1]
01-06 01:44:39.502: W/kernel(140): [ 6.279052] dbc_ctrl = 1
01-06 01:44:39.502: D/kernel(140): [ 6.279113] mdp4_overlay_pipe_alloc: pipe=8077a060 ndx=1
01-06 01:44:39.502: W/kernel(140): [ 6.291015] mddi_sony_ic_on_panel_on [2]
01-06 01:44:39.502: W/kernel(140): [ 6.291015] sony_lcd_display_on [2]
01-06 01:44:39.502: W/kernel(140): [ 6.291137] lcd_attribute_register [3]
01-06 01:44:39.502: E/kernel(140): [ 6.291412] mddi_hitachi_hvga: Detected a non-Hitachi display
01-06 01:44:39.502: E/kernel(140): [ 6.291564] mddi_sii_hvga: Detected a non-Sii display
01-06 01:44:39.502: D/kernel(140): [ 6.292114]
01-06 01:44:39.502: D/kernel(140): [ 6.292114] msm_vidc_dec: Inside vid_dec_init()
01-06 01:44:39.502: D/kernel(140): [ 6.292266]
01-06 01:44:39.502: D/kernel(140): [ 6.292266] msm_vidc_dec: Inside vid_dec_vcd_init()
01-06 01:44:39.502: D/kernel(140): [ 6.292297]
01-06 01:44:39.502: D/kernel(140): [ 6.292297] msm_vidc_enc: Inside vid_enc_init()
01-06 01:44:39.502: D/kernel(140): [ 6.292419]
01-06 01:44:39.502: D/kernel(140): [ 6.292419] msm_vidc_enc: Inside vid_enc_vcd_init()
01-06 01:44:39.502: E/kernel(140): [ 6.292449]
01-06 01:44:39.502: E/kernel(140): [ 6.292449] err: Device config mismatch
01-06 01:44:39.502: D/kernel(140): [ 6.296112] diagfwd initializing ..
01-06 01:44:39.502: D/kernel(140): [ 6.296386] SMD: ch 1 0 -> 1
01-06 01:44:39.502: D/kernel(140): [ 6.296386] diag opened SMD port ; r = 0
01-06 01:44:39.502: D/kernel(140): [ 6.296478] diagchar initializing ..
01-06 01:44:39.502: D/kernel(140): [ 6.296569] SMD: ch 1 1 -> 2
01-06 01:44:39.502: D/kernel(140): [ 6.296630] diagchar initialized
01-06 01:44:39.502: D/kernel(140): [ 6.300445] kgsl kgsl-3d0: |kgsl_gpummu_init| MMU type set for device is GPUMMU
01-06 01:44:39.502: D/kernel(140): [ 6.301086] kgsl kgsl-2d0: |kgsl_gpummu_init| MMU type set for device is GPUMMU
01-06 01:44:39.502: D/kernel(140): [ 6.301330] msm_serial: detected port #2
01-06 01:44:39.502: D/kernel(140): [ 6.301391] msm_serial.2: ttyMSM2 at MMIO 0xacc00000 (irq = 71) is a MSM
01-06 01:44:39.502: D/kernel(140): [ 6.301574] msm_serial: console setup on port #2
01-06 01:44:39.502: D/kernel(140): [ 7.447296] console [ttyMSM2] enabled
01-06 01:44:39.502: D/kernel(140): [ 7.451141] msm_serial: driver initialized
01-06 01:44:39.502: D/kernel(140): [ 7.455200] msm_serial_hs.0: ttyHS0 at MMIO 0xa3300000 (irq = 73) is a MSM HS UART
01-06 01:44:39.502: D/kernel(140): [ 7.462860] msm_serial_hs module loaded
01-06 01:44:39.502: D/kernel(140): [ 7.467864] brd: module loaded
01-06 01:44:39.502: D/kernel(140): [ 7.470855] loop: module loaded
01-06 01:44:39.502: D/kernel(140): [ 7.472595] pmem: Initializing pmem (user-space) as cached
01-06 01:44:39.502: D/kernel(140): [ 7.478546] pmem: Initializing pmem_kernel_ebi1 (in-kernel)
01-06 01:44:39.502: D/kernel(140): [ 7.483612] pmem: Initializing pmem_adsp (user-space) as non-cached
01-06 01:44:39.502: D/kernel(140): [ 7.490173] pmem: Initializing pmem_camera (user-space) as cached
01-06 01:44:39.502: I/kernel(140): [ 7.496826] pmic8058_nfc_probe: OK
01-06 01:44:39.502: D/kernel(140): [ 7.501983] lm3561 0-0053: lm3561_probe: loaded
01-06 01:44:39.502: D/kernel(140): [ 7.506561] adie_codec_register_codec_operations: codec type 0
01-06 01:44:39.502: D/kernel(140): [ 7.510375] SCSI Media Changer driver v0.25
01-06 01:44:39.502: D/kernel(140): [ 7.514038] msm_nand_probe: phys addr 0xa0200000
01-06 01:44:39.502: D/kernel(140): [ 7.518524] msm_nand_probe: Dual Nand Ctrl in ping-pong mode
01-06 01:44:39.502: D/kernel(140): [ 7.524200] msm_nand_probe: dmac 0x7
01-06 01:44:39.502: D/kernel(140): [ 7.527740] msm_nand_probe: allocated dma buffer at ffc7a000, dma_addr 4f088000
01-06 01:44:39.502: D/kernel(140): [ 7.535552] status: c00020
01-06 01:44:39.502: D/kernel(140): [ 7.537689] nandid: 55d1b32c maker 2c device b3
01-06 01:44:39.502: D/kernel(140): [ 7.542236] ONFI probe : Found an ONFI compliant device MT29F8G16ADBDAH4 ,
01-06 01:44:39.502: D/kernel(140): [ 7.549346] Found a supported NAND device
01-06 01:44:39.502: D/kernel(140): [ 7.553314] NAND Id : 0x55d1b32c
01-06 01:44:39.502: D/kernel(140): [ 7.556610] Buswidth : 16 Bits
01-06 01:44:39.502: D/kernel(140): [ 7.559753] Density : 1024 MByte
01-06 01:44:39.502: D/kernel(140): [ 7.563049] Pagesize : 2048 Bytes
01-06 01:44:39.502: D/kernel(140): [ 7.566345] Erasesize: 131072 Bytes
01-06 01:44:39.502: D/kernel(140): [ 7.569824] Oobsize : 64 Bytes
01-06 01:44:39.502: D/kernel(140): [ 7.572937] 2nd_bbm : 0
01-06 01:44:39.502: D/kernel(140): [ 7.575469] CFG0 Init : 0xa85408c0
01-06 01:44:39.502: D/kernel(140): [ 7.579010] CFG1 Init : 0x0012745a
01-06 01:44:39.502: D/kernel(140): [ 7.582580] ECCBUFCFG : 0x00000203
01-06 01:44:39.502: I/kernel(140): [ 7.586151] Creating 4 MTD partitions on "msm_nand":
01-06 01:44:39.502: I/kernel(140): [ 7.591094] 0x000005e80000-0x00001ee80000 : "system"
01-06 01:44:39.502: I/kernel(140): [ 7.798492] 0x00001ee80000-0x00001f480000 : "appslog"
01-06 01:44:39.502: I/kernel(140): [ 7.801971] 0x00001f480000-0x000025a00000 : "cache"
01-06 01:44:39.502: I/kernel(140): [ 7.853790] 0x000025a00000-0x00003fe00000 : "userdata"
01-06 01:44:39.502: W/kernel(140): [ 8.067260] spi_qsd spi_qsd.0: msm_spi_probe: DM mode not supported
01-06 01:44:39.502: D/kernel(140): [ 8.068298] PPP generic driver version 2.4.2
01-06 01:44:39.502: D/kernel(140): [ 8.068542] PPP Deflate Compression module registered
01-06 01:44:39.502: D/kernel(140): [ 8.068664] PPP BSD Compression module registered
01-06 01:44:39.502: D/kernel(140): [ 8.069274] PPP MPPE Compression module registered
01-06 01:44:39.502: D/kernel(140): [ 8.069366] NET: Registered protocol family 24
01-06 01:44:39.502: D/kernel(140): [ 8.069458] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
01-06 01:44:39.502: D/kernel(140): [ 8.069641] CSLIP: code copyright 1989 Regents of the University of California.
01-06 01:44:39.502: D/kernel(140): [ 8.070007] tun: Universal TUN/TAP device driver, 1.6
01-06 01:44:39.502: D/kernel(140): [ 8.074127] tun: (C) 1999-2004 Max Krasnyansky <</span>maxk@qualcomm.com
01-06 01:44:39.502: W/kernel(140): [ 8.080688] rmnet_init
01-06 01:44:39.502: D/kernel(140): [ 8.085601] rmnet_init
01-06 01:44:39.502: D/kernel(140): [ 8.087493] msm_otg_probe: rpc_connect(0)
01-06 01:44:39.502: D/kernel(140): [ 8.089660] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
01-06 01:44:39.502: D/kernel(140): [ 8.095550] msm_hsusb_rpc_connect: usb_ep already connected
01-06 01:44:39.502: D/kernel(140): [ 8.101104] host driver registered w/ tranceiver
01-06 01:44:39.502: D/kernel(140): [ 8.105743] usbcore: registered new interface driver usb_ehset_test
01-06 01:44:39.502: D/kernel(140): [ 8.112335] peripheral driver registered w/ tranceiver
01-06 01:44:39.502: D/kernel(140): [ 8.118438] f_diag init
01-06 01:44:39.502: D/kernel(140): [ 8.119689] android_usb gadget: android_usb ready
01-06 01:44:39.502: D/kernel(140): [ 8.124145] msm_hsusb msm_hsusb: registered gadget driver 'android_usb'
01-06 01:44:39.502: D/kernel(140): [ 8.131164] input: pm8058-keypad as /devices/i2c-6/6-0000/pm8058-keypad/input/input2
01-06 01:44:39.502: D/kernel(140): [ 8.139404] usbcore: registered new interface driver xpad
01-06 01:44:39.502: D/kernel(140): [ 8.143829] xpad: X-Box pad driver
01-06 01:44:39.502: D/kernel(140): [ 8.147583] input: cyttsp-spi as /devices/platform/spi_qsd.0/spi0.0/input/input3
01-06 01:44:39.502: D/kernel(140): [ 8.154754] cyttsp-spi spi0.0: cyttsp_core_init: Enable ESD check
01-06 01:44:39.502: D/kernel(140): [ 8.160827] cyttsp_core_init: Successful.
01-06 01:44:39.502: D/kernel(140): [ 8.164672] cyttsp-spi spi0.0: cyttsp_set_bl_mode: ... trying.
01-06 01:44:39.502: D/kernel(140): [ 8.170501] cyttsp-spi spi0.0: cyttsp_reinit_hw: Reinit HW
01-06 01:44:39.502: D/kernel(140): [ 8.175964] cyttsp_xres: 1
01-06 01:44:39.502: D/kernel(140): [ 8.228912] cyttsp-spi spi0.0: cyttsp_set_bl_mode: completed.
01-06 01:44:39.502: D/kernel(140): [ 8.268859] cyttsp-spi spi0.0: appver 3027, appid 0103
01-06 01:44:39.502: D/kernel(140): [ 8.268951] cyttsp-spi spi0.0: cyttsp_exit_bl_mode: trying ....
01-06 01:44:39.502: D/kernel(140): [ 8.269317] cyttsp-spi spi0.0: appver 3027, appid 0103
01-06 01:44:39.502: D/kernel(140): [ 8.738586] cyttsp-spi spi0.0: cyttsp_exit_bl_mode: success.
01-06 01:44:39.502: D/kernel(140): [ 8.738708] cyttsp-spi spi0.0: cyttsp_set_sysinfo_mode: trying ....
01-06 01:44:39.502: D/kernel(140): [ 8.798736] cyttsp-spi spi0.0: cyttsp_set_sysinfo_mode: mode entered.
01-06 01:44:39.502: D/kernel(140): [ 8.829193] cyttsp-spi spi0.0: cyttsp_set_sysinfo_mode: SI2:tts_ver=0x1300 app_id=0x0103 app_ver=0x3027 c_id=0xC0C1C2
01-06 01:44:39.502: D/kernel(140): [ 8.829376] cyttsp-spi spi0.0: cyttsp_set_intrvl_registers: act_intrvl=0x11 tch_tmout=0xFF lp_intrvl=0x0A
01-06 01:44:39.502: D/kernel(140): [ 8.858612] cyttsp-spi spi0.0: cyttsp_power_on: switch back to operational mode
01-06 01:44:39.502: D/kernel(140): [ 8.858734] cyttsp-spi spi0.0: cyttsp_set_operational_mode: trying ....
01-06 01:44:39.502: D/kernel(140): [ 8.918823] cyttsp-spi spi0.0: chg_status_work: Set charger mode to reg: 0x0
01-06 01:44:39.502: D/kernel(140): [ 8.948608] cyttsp-spi spi0.0: cyttsp_set_operational_mode: mode entered.
01-06 01:44:39.502: D/kernel(140): [ 8.948730] cyttsp-spi spi0.0: cyttsp_power_on: Power state is ACTIVE
01-06 01:44:39.502: D/kernel(140): [ 8.948852] cyttsp_spi_probe: Successful registration cyttsp-spi
01-06 01:44:39.502: D/kernel(140): [ 8.949005] cyttsp_spi_init: Cypress TrueTouch(R) Standard Product SPI Touchscreen Driver (Built Jul 13 2012 @ 21:23:36) returned 0
01-06 01:44:39.502: D/kernel(140): [ 8.949371] GPIO Input Driver: Start gpio inputs for slider-mogami in interrupt mode
01-06 01:44:39.502: D/kernel(140): [ 8.949645] input: slider-mogami as /devices/virtual/input/input4
01-06 01:44:39.502: D/kernel(140): [ 8.950958] Enabled VREG "wlan" at 2900 mV
01-06 01:44:39.502: D/kernel(140): [ 8.958404] Disabled VREG "wlan"
01-06 01:44:39.502: D/kernel(140): [ 8.963623] input: apds9702 as /devices/virtual/input/input5
01-06 01:44:39.502: D/kernel(140): [ 8.963989] apds9702_probe: device create ok. I2C address = 54
01-06 01:44:39.502: D/kernel(140): [ 8.967834] simple_remote simple_remote.0: **** Registering (headset) driver
01-06 01:44:39.502: D/kernel(140): [ 8.980010] input: simple_remote as /devices/virtual/input/input6
01-06 01:44:39.502: D/kernel(140): [ 8.981140] input: simple_remote_appkey as /devices/virtual/input/input7
01-06 01:44:39.502: D/kernel(140): [ 8.987518] simple_remote simple_remote.0: ***** Successfully registered
01-06 01:44:39.502: D/kernel(140): [ 9.009094] bma250: detected chip id 3, rev 0x31
01-06 01:44:39.502: D/kernel(140): [ 9.012390] input: bma250 as /devices/virtual/input/input8
01-06 01:44:39.502: V/kernel(140): [ 9.012908] RTC Registering with rs30000048
01-06 01:44:39.502: V/kernel(140): [ 9.013824] msmrtc_rpc_proc_result: RPC client reply for PROC=12 success
01-06 01:44:39.502: D/kernel(140): [ 9.015869] RPC CALL -- TOD TIME UPDATE: ttick = 525575
01-06 01:44:39.502: D/kernel(140): [ 9.015869] stamp=137438986240, freq = 1953849708
01-06 01:44:39.502: V/kernel(140): [ 9.024993] msmrtc_rpc_proc_result: RPC client reply for PROC=17 success
01-06 01:44:39.502: D/kernel(140): [ 9.032012] using rtc device, msm_rtc, for alarms
01-06 01:44:39.502: V/kernel(140): [ 9.036132] msm_rtc: dev (254:0)
01-06 01:44:39.502: D/kernel(140): [ 9.039550] rs30000048 rs30000048.262144: rtc core: registered msm_rtc as rtc0
01-06 01:44:39.502: V/kernel(140): [ 9.046844] msm_rtc_secure: dev (254:1)
01-06 01:44:39.502: D/kernel(140): [ 9.050567] rs30000048 rs30000048.262144: rtc core: registered msm_rtc_secure as rtc1
01-06 01:44:39.502: D/kernel(140): [ 9.058380] i2c /dev entries driver
01-06 01:44:39.502: D/kernel(140): [ 9.062500] AKM8975 compass driver: initialize
01-06 01:44:39.502: D/kernel(140): [ 9.066986] input: compass as /devices/virtual/input/input9
01-06 01:44:39.502: D/kernel(140): [ 9.072021] AKM8975 successfully probed.
01-06 01:44:39.502: D/kernel(140): [ 9.075775] Linux video capture interface: v2.00
01-06 01:44:39.502: V/kernel(140): [ 9.102447] msmrtc_tod_proc_result: 01/06/1980 00:44:34 (06)
01-06 01:44:39.502: D/kernel(140): [ 9.102569] rs30000048 rs30000048.262144: setting system clock to 1980-01-06 00:44:34 UTC (315967474)
01-06 01:44:39.502: D/kernel(140): [ 9.513183] msm_gemini_init gemini: success
01-06 01:44:39.502: D/kernel(140): [ 9.990295] bq27520 0-0055: FW v5.7 (expect v5.7). Golden FW v0.46
01-06 01:44:39.502: E/kernel(140): [ 9.990631] power_supply bq27520: driver failed to report `voltage_now' property
01-06 01:44:39.502: D/kernel(140): [ 9.991363] bq24185 0-006b: Found BQ24185, rev 0x01
01-06 01:44:39.502: W/kernel(140): [ 9.992156] bq24185 0-006b: *** Safety limit could not be set!
01-06 01:44:39.502: W/kernel(140): [ 9.992156] Please check boot accessing charger (want 0x50, got 0xac) ***
01-06 01:44:39.502: D/kernel(140): [ 9.993286] bq24185 0-006b: Charging started by boot
01-06 01:44:39.502: D/kernel(140): [ 9.993713] chargalg chargalg: Registering battery charging algorithm driver
01-06 01:44:39.502: D/kernel(140): [ 9.994781] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
01-06 01:44:39.502: D/kernel(140): [ 9.997222] Bluetooth: HCI UART driver ver 2.2
01-06 01:44:39.502: D/kernel(140): [ 10.001647] Bluetooth: HCI H4 protocol initialized
01-06 01:44:39.502: D/kernel(140): [ 10.006378] Bluetooth: HCILL protocol initialized
01-06 01:44:39.502: D/kernel(140): [ 10.011077] Bluetooth: HCI_IBS protocol initialized
01-06 01:44:39.502: E/kernel(140): [ 10.016815] mmc0: No card detect facilities available
01-06 01:44:39.502: D/kernel(140): [ 10.021240] mmc0: Qualcomm MSM SDCC at 0x00000000a3000000 irq 96,0 dma 8
01-06 01:44:39.502: D/kernel(140): [ 10.027648] mmc0: 8 bit data mode disabled
01-06 01:44:39.502: D/kernel(140): [ 10.031738] mmc0: 4 bit data mode enabled
01-06 01:44:39.502: D/kernel(140): [ 10.035705] mmc0: polling status mode disabled
01-06 01:44:39.502: D/kernel(140): [ 10.040161] mmc0: MMC clock 144000 -> 49152000 Hz, PCLK 96000000 Hz
01-06 01:44:39.502: D/kernel(140): [ 10.046386] mmc0: Slot eject status = 0
01-06 01:44:39.502: D/kernel(140): [ 10.050231] mmc0: Power save feature enable = 1
01-06 01:44:39.502: D/kernel(140): [ 10.054718] mmc0: DM non-cached buffer at ffc7e000, dma_addr 0x4f122000
01-06 01:44:39.502: D/kernel(140): [ 10.061340] mmc0: DM cmd busaddr 0x4f122000, cmdptr busaddr 0x4f122300
01-06 01:44:39.502: D/kernel(140): [ 10.138916] mmc1: Qualcomm MSM SDCC at 0x00000000a3100000 irq 100,523 dma 8
01-06 01:44:39.502: D/kernel(140): [ 10.139038] mmc1: 8 bit data mode disabled
01-06 01:44:39.502: D/kernel(140): [ 10.139129] mmc1: 4 bit data mode enabled
01-06 01:44:39.502: D/kernel(140): [ 10.139190] mmc1: polling status mode disabled
01-06 01:44:39.502: D/kernel(140): [ 10.139282] mmc1: MMC clock 144000 -> 49152000 Hz, PCLK 96000000 Hz
01-06 01:44:39.502: D/kernel(140): [ 10.139404] mmc1: Slot eject status = 0
01-06 01:44:39.502: D/kernel(140): [ 10.139465] mmc1: Power save feature enable = 1
01-06 01:44:39.502: D/kernel(140): [ 10.139556] mmc1: DM non-cached buffer at ffc7f000, dma_addr 0x4f123000
01-06 01:44:39.502: D/kernel(140): [ 10.139678] mmc1: DM cmd busaddr 0x4f123000, cmdptr busaddr 0x4f123300
01-06 01:44:39.502: D/kernel(140): [ 10.141937] usbcore: registered new interface driver usbhid
01-06 01:44:39.502: D/kernel(140): [ 10.147094] usbhid: v2.6:USB HID core driver
01-06 01:44:39.502: D/kernel(140): [ 10.167846] logger: created 64K log 'log_main'
01-06 01:44:39.502: D/kernel(140): [ 10.167999] logger: created 256K log 'log_events'
01-06 01:44:39.502: D/kernel(140): [ 10.168151] logger: created 64K log 'log_radio'
01-06 01:44:39.502: D/kernel(140): [ 10.168304] logger: created 64K log 'log_system'
01-06 01:44:39.502: D/kernel(140): [ 10.169616] zram: num_devices not specified. Using default: 1
01-06 01:44:39.502: D/kernel(140): [ 10.175292] zram: Creating 1 devices ...
01-06 01:44:39.502: D/kernel(140): [ 10.179565] Advanced Linux Sound Architecture Driver Version 1.0.21.
01-06 01:44:39.502: W/kernel(140): [ 10.185882] No device for DAI CODEC_DAI
01-06 01:44:39.502: W/kernel(140): [ 10.189392] No device for DAI CPU_DAI
01-06 01:44:39.502: D/kernel(140): [ 10.193237] msm_soc: create pcms
01-06 01:44:39.502: D/kernel(140): [ 10.196380] asoc: CODEC_DAI <-> CPU_DAI mapping ok
01-06 01:44:39.502: W/kernel(140): [ 10.201599] No device for DAI MVS_CODEC_DAI
01-06 01:44:39.502: W/kernel(140): [ 10.205169] No device for DAI MVS_CPU_DAI
01-06 01:44:39.502: D/kernel(140): [ 10.209472] asoc: MVS_CODEC_DAI <-> MVS_CPU_DAI mapping ok
01-06 01:44:39.502: D/kernel(140): [ 10.214630] ALSA device list:
01-06 01:44:39.502: D/kernel(140): [ 10.217590] #0: msm-audio (MSM-CARD)
01-06 01:44:39.502: W/kernel(140): [ 10.221374] GACT probability NOT on
01-06 01:44:39.502: W/kernel(140): [ 10.224792] Mirror/redirect action on
01-06 01:44:39.502: W/kernel(140): [ 10.228424] u32 classifier
01-06 01:44:39.502: W/kernel(140): [ 10.231140] Actions configured
01-06 01:44:39.502: W/kernel(140): [ 10.234588] Netfilter messages via NETLINK v0.30.
01-06 01:44:39.502: W/kernel(140): [ 10.239318] nf_conntrack version 0.5.0 (5437 buckets, 21748 max)
01-06 01:44:39.502: W/kernel(140): [ 10.245422] CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
01-06 01:44:39.502: W/kernel(140): [ 10.252655] nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
01-06 01:44:39.502: W/kernel(140): [ 10.260559] sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
01-06 01:44:39.502: W/kernel(140): [ 10.266815] ctnetlink v0.93: registering with nfnetlink.
01-06 01:44:39.502: D/kernel(140): [ 10.272064] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
01-06 01:44:39.502: D/kernel(140): [ 10.278961] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
01-06 01:44:39.502: D/kernel(140): [ 10.285064] xt_time: kernel timezone is -0000
01-06 01:44:39.502: D/kernel(140): [ 10.289306] ip_tables: (C) 2000-2006 Netfilter Core Team
01-06 01:44:39.502: D/kernel(140): [ 10.294494] arp_tables: (C) 2002 David S. Miller
01-06 01:44:39.502: D/kernel(140): [ 10.299041] TCP cubic registered
01-06 01:44:39.502: D/kernel(140): [ 10.302398] NET: Registered protocol family 10
01-06 01:44:39.502: D/kernel(140): [ 10.308685] Mobile IPv6
01-06 01:44:39.502: D/kernel(140): [ 10.309112] ip6_tables: (C) 2000-2006 Netfilter Core Team
01-06 01:44:39.502: D/kernel(140): [ 10.314544] IPv6 over IPv4 tunneling driver
01-06 01:44:39.502: D/kernel(140): [ 10.319488] NET: Registered protocol family 17
01-06 01:44:39.502: D/kernel(140): [ 10.323059] NET: Registered protocol family 15
01-06 01:44:39.502: I/kernel(140): [ 10.327545] Bridge firewalling registered
01-06 01:44:39.502: D/kernel(140): [ 10.331512] Bluetooth: L2CAP ver 2.14
01-06 01:44:39.502: D/kernel(140): [ 10.335113] Bluetooth: L2CAP socket layer initialized
01-06 01:44:39.502: D/kernel(140): [ 10.340148] Bluetooth: SCO (Voice Link) ver 0.6
01-06 01:44:39.502: D/kernel(140): [ 10.344665] Bluetooth: SCO socket layer initialized
01-06 01:44:39.502: D/kernel(140): [ 10.349914] Bluetooth: RFCOMM TTY layer initialized
01-06 01:44:39.502: D/kernel(140): [ 10.354400] Bluetooth: RFCOMM socket layer initialized
01-06 01:44:39.502: D/kernel(140): [ 10.359527] Bluetooth: RFCOMM ver 1.11
01-06 01:44:39.502: D/kernel(140): [ 10.363250] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
01-06 01:44:39.502: D/kernel(140): [ 10.368530] Bluetooth: BNEP filters: protocol multicast
01-06 01:44:39.502: D/kernel(140): [ 10.373748] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
01-06 01:44:39.502: D/kernel(140): [ 10.382781] clock_late_init() disabled 27 unused clocks
01-06 01:44:39.502: D/kernel(140): [ 10.385284] [voice.c:voice_init]
01-06 01:44:39.502: D/kernel(140): [ 10.391967] [voice.c:voice_thread] voice_thread() start
01-06 01:44:39.502: W/kernel(140): [ 10.399139] mmc0: card claims to support voltages below the defined range. These will be ignored.
01-06 01:44:39.502: E/kernel(140): [ 10.402435] simple_remote_pf simple_remote_pf.0: simple_remote_pf_button_handler - Button callback not registered
01-06 01:44:39.502: E/kernel(140): [ 10.412628] simple_remote_pf simple_remote_pf.0: simple_remote_pf_button_handler - Button callback not registered
01-06 01:44:39.502: D/kernel(140): [ 10.423095] VFP support v0.3: implementor 51 architecture 64 part 0f variant 1 rev 0
01-06 01:44:39.502: V/kernel(140): [ 10.431518] msmrtc_tod_proc_result: 01/06/1980 00:44:36 (06)
01-06 01:44:39.502: D/kernel(140): [ 10.436126] rs30000048 rs30000048.262144: setting system clock to 1980-01-06 00:44:36 UTC (315967476)
01-06 01:44:39.502: D/kernel(140): [ 10.445281] msm_v4l2: msm_v4l2_init
01-06 01:44:39.502: D/kernel(140): [ 10.449127] Freeing init memory: 184K
01-06 01:44:39.502: V/kernel(140): [ 10.472320] mmc0: queuing CIS tuple 0x91 length 3
01-06 01:44:39.502: D/kernel(140): [ 10.473083] mmc0: new SDIO card at address 0001
01-06 01:44:39.502: D/kernel(140): [ 10.473236] sdio_al mmc0:0001: Probing..
01-06 01:44:39.502: D/kernel(140): [ 10.473327] sdio_al mmc0:0001: ignore card vendor id 0x97, device id 0x4076
01-06 01:44:39.502: D/kernel(140): [ 10.473815] cdcc_pm_gpio_config: uSD power on
01-06 01:44:39.502: D/kernel(140): [ 10.478729] msm_hsusb msm_hsusb: msm72k_udc: OFFLINE -> ONLINE
01-06 01:44:39.502: D/kernel(140): [ 10.540588] bq27520 0-0055: IT Enable confirmed to be set.
01-06 01:44:39.502: E/kernel(140): [ 10.561767] power_supply bq27520: driver failed to report `voltage_now' property
01-06 01:44:39.502: D/kernel(140): [ 10.570892] yaffs: dev is 32505858 name is "mtdblock2" rw
01-06 01:44:39.502: D/kernel(140): [ 10.570983] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 10.571044] yaffs: yaffs: Attempting MTD mount of 31.2,"mtdblock2"
01-06 01:44:39.502: W/kernel(140): [ 10.663513] mmc1: host does not support reading read-only switch. assuming write-enable.
01-06 01:44:39.502: D/kernel(140): [ 10.671386] mmc1: new SDHC card at address e624
01-06 01:44:39.502: D/kernel(140): [ 10.671600] sdio_al mmc1:e624: Probing..
01-06 01:44:39.502: D/kernel(140): [ 10.671875] mmcblk0: mmc1:e624 SU08G 7.40 GiB
01-06 01:44:39.502: D/kernel(140): [ 10.672088] mmcblk0: p1
01-06 01:44:39.502: V/kernel(140): [ 10.791961] yaffs: yaffs_read_super: is_checkpointed 0
01-06 01:44:39.502: D/kernel(140): [ 10.849060] yaffs: dev is 32505856 name is "mtdblock0" rw
01-06 01:44:39.502: D/kernel(140): [ 10.849151] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 10.849243] yaffs: yaffs: Attempting MTD mount of 31.0,"mtdblock0"
01-06 01:44:39.502: V/kernel(140): [ 10.961883] yaffs: yaffs_read_super: is_checkpointed 1
01-06 01:44:39.502: E/kernel(140): [ 11.000061] init: cannot open '/initlogo.rle'
01-06 01:44:39.502: D/kernel(140): [ 11.003326] yaffs: dev is 32505858 name is "mtdblock2" rw
01-06 01:44:39.502: D/kernel(140): [ 11.003417] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 11.003479] yaffs: yaffs: Attempting MTD mount of 31.2,"mtdblock2"
01-06 01:44:39.502: V/kernel(140): [ 11.006134] yaffs: yaffs_read_super: is_checkpointed 1
01-06 01:44:39.502: D/kernel(140): [ 11.139099] yaffs: dev is 32505856 name is "mtdblock0" rw
01-06 01:44:39.502: D/kernel(140): [ 11.139190] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 11.139251] yaffs: yaffs: Attempting MTD mount of 31.0,"mtdblock0"
01-06 01:44:39.502: V/kernel(140): [ 11.251861] yaffs: yaffs_read_super: is_checkpointed 1
01-06 01:44:39.502: D/kernel(140): [ 11.268646] yaffs: dev is 32505859 name is "mtdblock3" rw
01-06 01:44:39.502: D/kernel(140): [ 11.268768] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 11.268829] yaffs: yaffs: Attempting MTD mount of 31.3,"mtdblock3"
01-06 01:44:39.502: D/kernel(140): [ 11.572906] bq27520 0-0055: bq27520_battery_info_setting() type=3 temp=340 status=0
01-06 01:44:39.502: D/kernel(140): [ 12.582733] bq27520 0-0055: bq27520_init_worker(): capacity=88 flags=0x139
01-06 01:44:39.502: V/kernel(140): [ 13.045349] yaffs: yaffs_read_super: is_checkpointed 0
01-06 01:44:39.502: D/kernel(140): [ 13.045593] yaffs: dev is 32505858 name is "mtdblock2" rw
01-06 01:44:39.502: D/kernel(140): [ 13.045684] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 13.045776] yaffs: yaffs: Attempting MTD mount of 31.2,"mtdblock2"
01-06 01:44:39.502: V/kernel(140): [ 13.048400] yaffs: yaffs_read_super: is_checkpointed 1
01-06 01:44:39.502: D/kernel(140): [ 13.058197] yaffs: dev is 32505857 name is "mtdblock1" rw
01-06 01:44:39.502: D/kernel(140): [ 13.058319] yaffs: passed flags ""
01-06 01:44:39.502: V/kernel(140): [ 13.058380] yaffs: yaffs: Attempting MTD mount of 31.1,"mtdblock1"
01-06 01:44:39.502: V/kernel(140): [ 13.106658] yaffs: yaffs_read_super: is_checkpointed 0
01-06 01:44:39.502: E/kernel(140): [ 13.406494] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
01-06 01:44:39.532: E/kernel(140): [ 13.465148] init: cannot find '/system/bin/hdmid', disabling 'hdmid'
01-06 01:44:39.532: E/kernel(140): [ 13.465179] init: cannot find '/system/bin/slidercounter', disabling 'slidercounter'
01-06 01:44:39.532: E/kernel(140): [ 13.465209] init: cannot find '/system/bin/dfdump', disabling 'dfdump'
01-06 01:44:39.532: I/DEBUG(129): debuggerd: Jul 13 2012 21:31:47
01-06 01:44:39.542: I/AKMD2(145): AK8975/B for Android v 2.0.0.---- (Library: v1.2.3.114) started.
01-06 01:44:39.552: I/touchd(150): handling_uevent: event is 0
01-06 01:44:39.572: D/kernel(140): [ 13.503540] cyttsp-spi spi0.0: chg_status_work: Set charger mode to reg: 0x0
01-06 01:44:39.612: D/kernel(140): [ 13.543701] SMD: ch 40 0 -> 1
01-06 01:44:39.612: D/kernel(140): [ 13.543823] SMD: ch 40 1 -> 2
01-06 01:44:39.632: D/kernel(140): [ 13.559936] SMD: ch 41 0 -> 1
01-06 01:44:39.632: D/kernel(140): [ 13.560058] SMD: ch 41 1 -> 2
01-06 01:44:39.632: D/kernel(140): [ 13.560180] SMD: ch 42 0 -> 1
01-06 01:44:39.632: D/kernel(140): [ 13.560424] SMD: ch 42 1 -> 2
01-06 01:44:39.632: D/kernel(140): [ 13.560577] SMD: ch 43 0 -> 1
01-06 01:44:39.632: D/kernel(140): [ 13.560668] SMD: ch 43 1 -> 2
01-06 01:44:39.632: D/kernel(140): [ 13.560791] SMD: ch 44 0 -> 1
01-06 01:44:39.632: D/kernel(140): [ 13.561004] SMD: ch 44 1 -> 2
01-06 01:44:39.632: D/kernel(140): [ 13.561157] SMD: ch 45 0 -> 1
01-06 01:44:39.632: D/kernel(140): [ 13.561218] SMD: ch 45 1 -> 2
01-06 01:44:39.632: E/kernel(140): [ 13.561340] smd_pkt_open: DATA13_CNTL open failed -19
01-06 01:44:39.632: E/kernel(140): [ 13.561370] smd_pkt_open: DATA14_CNTL open failed -19
01-06 01:44:39.632: I/hostapd(167): Checking /data/misc/wifi/hostapd/hostapd.conf ...
01-06 01:44:39.782: V/kernel(140): [ 13.717254] zram: Initialization done!
01-06 01:44:39.782: I//system/bin/zram_start.sh(149): Setting up swapspace version 1, size = 62910464 bytes
01-06 01:44:39.802: I//system/bin/zram_start.sh(149): UUID=920f819c-648b-4688-9c04-be42dbcd352a
01-06 01:44:39.852: V/kernel(140): [ 13.717285] zram: Read before write: sector=0, size=4096
01-06 01:44:39.852: D/kernel(140): [ 13.781738] Compat-wireless backport release: compat-wireless-2011-05-19-2-gfa00a5a
01-06 01:44:39.852: D/kernel(140): [ 13.781738] Backport based on wl12xx.git v2.6.39-1250-g40f5df0
01-06 01:44:39.862: D/kernel(140): [ 13.795227] Adding 61432k swap on /dev/zram0. Priority:-1 extents:1 across:61432k SS
01-06 01:44:39.862: I/ServiceManager(146): Waiting for service drm.drmManager...
01-06 01:44:39.862: I/logwrapper(149): /system/bin/zram_start.sh terminated by exit(0)
01-06 01:44:39.932: I/iddd(138): Starting up...
01-06 01:44:39.942: W/iddd-util(138): Failed to open event file to rescue: No such file or directory
01-06 01:44:39.962: D/kernel(140): [ 13.896728] warning: `rild' uses 32-bit capabilities (legacy support in use)
01-06 01:44:39.962: I/nv_param_loader(158): read_nv: NV value is active. nv_id=60240
01-06 01:44:39.962: I/nv_param_loader(158): main_execution:prox_cal=1
01-06 01:44:39.962: I/nv_param_loader(158): --------- beginning of /dev/log/system
01-06 01:44:39.992: I/Vold(127): Vold 2.1 (the revenge) firing up
01-06 01:44:39.992: D/Vold(127): Volume sdcard state changing -1 (Initializing) -> 0 (No-Media)
01-06 01:44:40.022: I/iddd(138): Ready to serve the world.
01-06 01:44:40.022: D/Vold(127): Volume sdcard state changing 0 (No-Media) -> 2 (Pending)
01-06 01:44:40.022: D/Vold(127): Volume sdcard state changing 2 (Pending) -> 1 (Idle-Unmounted)
01-06 01:44:40.032: I/nv_param_loader(191): read_nv: NV value is active. nv_id=60240
01-06 01:44:40.042: D/kernel(140): [ 13.975616] rmnet_ioctl(): close transport port
01-06 01:44:40.042: D/kernel(140): [ 13.975677] SMD: ch 11 0 -> 1
01-06 01:44:40.042: D/kernel(140): [ 13.975677] rmnet_ioctl(): open transport port
01-06 01:44:40.042: D/kernel(140): [ 13.975738] SMD: ch 11 1 -> 2
01-06 01:44:40.052: I/nv_param_loader(191): main_execution:threshold=5
01-06 01:44:40.082: D/kernel(140): [ 14.013092] Calling CRDA to update world regulatory domain
01-06 01:44:40.092: I/nv_param_loader(201): read_nv: NV value is active. nv_id=60240
01-06 01:44:40.122: I/nv_param_loader(201): main_execution:rfilter=0
01-06 01:44:40.132: I/Netd(128): Netd 1.0 starting
01-06 01:44:40.142: D/kernel(140): [ 14.077484] World regulatory domain updated:
01-06 01:44:40.142: D/kernel(140): [ 14.077484] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
01-06 01:44:40.142: D/kernel(140): [ 14.077514] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:40.142: D/kernel(140): [ 14.077514] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:40.142: D/kernel(140): [ 14.077545] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:40.142: D/kernel(140): [ 14.077545] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:40.142: D/kernel(140): [ 14.077575] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:40.262: V/cyttsp_fw_loader(212): Cypress TTSP FW Loader.
01-06 01:44:40.262: V/cyttsp_fw_loader(212): get_bl_info: tts_ver 0x1300, app_id 0x103, app_ver 0x3027, cid 0xc0c1c2
01-06 01:44:40.272: V/cyttsp_fw_loader(212): New FW from '/system/etc/firmware/touch_mango_sony_type1.hex': tts_ver 0x1300, app_id 0x103, app_ver 0x3027, cid 0xc0c1c2
01-06 01:44:40.272: V/cyttsp_fw_loader(212): Current FW: tts_ver 0x1300, app_id 0x103, app_ver 0x3027, cid 0xc0c1c2
01-06 01:44:40.272: V/cyttsp_fw_loader(212): Firmware update is not required.
01-06 01:44:40.332: V/bq275xx_fwloader(216): TI BQ275xx FW Loader.
01-06 01:44:40.542: D/kernel(140): [ 14.475830] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.475891] SMD: ch 12 0 -> 1
01-06 01:44:40.542: D/kernel(140): [ 14.475891] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.475921] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.475952] SMD: ch 13 0 -> 1
01-06 01:44:40.542: D/kernel(140): [ 14.475952] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.475982] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476013] SMD: ch 14 0 -> 1
01-06 01:44:40.542: D/kernel(140): [ 14.476013] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476043] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476074] SMD: ch 15 0 -> 1
01-06 01:44:40.542: D/kernel(140): [ 14.476074] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476074] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476104] SMD: ch 13 1 -> 2
01-06 01:44:40.542: D/kernel(140): [ 14.476135] SMD: ch 18 0 -> 1
01-06 01:44:40.542: D/kernel(140): [ 14.476135] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476165] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476196] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476196] SMD: ch 12 1 -> 2
01-06 01:44:40.542: D/kernel(140): [ 14.476257] rmnet_ioctl(): close transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476257] rmnet_ioctl(): open transport port
01-06 01:44:40.542: D/kernel(140): [ 14.476287] SMD: ch 18 1 -> 2
01-06 01:44:40.542: D/kernel(140): [ 14.476348] SMD: ch 15 1 -> 2
01-06 01:44:40.542: D/kernel(140): [ 14.476348] SMD: ch 14 1 -> 2
01-06 01:44:40.622: D/kernel(140): [ 14.553161] rmnet_ioctl(): set QMI QOS header disable
01-06 01:44:40.622: D/kernel(140): [ 14.553192] rmnet_ioctl(): set QMI QOS header disable
01-06 01:44:40.622: D/kernel(140): [ 14.553253] rmnet_ioctl(): set QMI QOS header disable
01-06 01:44:40.622: D/kernel(140): [ 14.553283] rmnet_ioctl(): set QMI QOS header disable
01-06 01:44:40.622: D/kernel(140): [ 14.553314] rmnet_ioctl(): set QMI QOS header disable
01-06 01:44:40.622: D/kernel(140): [ 14.553375] rmnet_ioctl(): set QMI QOS header disable
01-06 01:44:40.862: I/ServiceManager(146): Waiting for service drm.drmManager...
01-06 01:44:40.872: I/bq275xx_fwloader(216): File 0x0507 0x0046 mang: Device (0x0507) 0x0507 0x0046 MANG
01-06 01:44:40.872: I/bq275xx_fwloader(216): Latest version is used
01-06 01:44:40.912: I/(133): ServiceManager: 0x18c70
01-06 01:44:41.272: D/kernel(140): [ 15.201202] wl1271_sdio mmc0:0001:2: firmware: requesting ti-connectivity/wl1271-nvs.bin
01-06 01:44:41.292: D/kernel(140): [ 15.219299] wl1271: loaded
01-06 01:44:41.322: D/AndroidRuntime(132): >>>>>> AndroidRuntime START com.android.internal.os.ZygoteInit <<<<<<
01-06 01:44:41.322: D/AndroidRuntime(132): CheckJNI is OFF
01-06 01:44:41.412: E/kernel(140): [ 15.341888] android_usb: already disabled
01-06 01:44:41.422: I/SurfaceFlinger(131): SurfaceFlinger is starting
01-06 01:44:41.442: I/usb(253): usb product id: 6166
01-06 01:44:41.442: I/SurfaceFlinger(131): SurfaceFlinger's main thread ready to run. Initializing graphics H/W...
01-06 01:44:41.452: I/msm7x30.gralloc(131): using (fd=10)
01-06 01:44:41.452: I/msm7x30.gralloc(131): id = msmfb40_1ffff
01-06 01:44:41.452: I/msm7x30.gralloc(131): xres = 320 px
01-06 01:44:41.452: I/msm7x30.gralloc(131): yres = 480 px
01-06 01:44:41.452: I/msm7x30.gralloc(131): xres_virtual = 320 px
01-06 01:44:41.452: I/msm7x30.gralloc(131): yres_virtual = 960 px
01-06 01:44:41.452: I/msm7x30.gralloc(131): bpp = 32
01-06 01:44:41.452: I/msm7x30.gralloc(131): r = 0:8
01-06 01:44:41.452: I/msm7x30.gralloc(131): g = 8:8
01-06 01:44:41.452: I/msm7x30.gralloc(131): b = 16:8
01-06 01:44:41.462: I/msm7x30.gralloc(131): width = 42 mm (193.523804 dpi)
01-06 01:44:41.462: I/msm7x30.gralloc(131): height = 63 mm (193.523804 dpi)
01-06 01:44:41.462: I/msm7x30.gralloc(131): refresh rate = 64.00 Hz
01-06 01:44:41.482: D/libEGL(131): loaded /system/lib/egl/libGLES_android.so
01-06 01:44:41.492: D/libEGL(131): loaded /system/lib/egl/libEGL_adreno200.so
01-06 01:44:41.532: I/usb(256): enabled usb functions: mass_storage,adb
01-06 01:44:41.532: D/libEGL(131): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
01-06 01:44:41.542: D/libEGL(131): loaded /system/lib/egl/libGLESv2_adreno200.so
01-06 01:44:41.542: D/kernel(140): [ 15.471252] adb_bind_config
01-06 01:44:41.542: D/kernel(140): [ 15.474304] msm_hsusb msm_hsusb: suspend
01-06 01:44:41.592: D/kernel(140): [ 15.519287] kgsl kgsl-3d0: firmware: requesting yamato_pm4.fw
01-06 01:44:41.632: D/kernel(140): [ 15.559783] kgsl kgsl-3d0: firmware: requesting yamato_pfp.fw
01-06 01:44:41.762: I/SurfaceFlinger(131): EGL informations:
01-06 01:44:41.762: I/SurfaceFlinger(131): # of configs : 44
01-06 01:44:41.762: I/SurfaceFlinger(131): vendor : Android
01-06 01:44:41.762: I/SurfaceFlinger(131): version : 1.4 Android META-EGL
01-06 01:44:41.762: I/SurfaceFlinger(131): extensions: EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_base EGL_KHR_fence_sync EGL_ANDROID_image_native_buffer EGL_ANDROID_image_native_buffer
01-06 01:44:41.762: I/SurfaceFlinger(131): Client API: OpenGL ES
01-06 01:44:41.762: I/SurfaceFlinger(131): EGLSurface: 8-8-8-8, config=0x3
01-06 01:44:41.762: I/SurfaceFlinger(131): OpenGL informations:
01-06 01:44:41.762: I/SurfaceFlinger(131): vendor : Qualcomm
01-06 01:44:41.762: I/SurfaceFlinger(131): renderer : Adreno (TM) 205
01-06 01:44:41.762: I/SurfaceFlinger(131): version : OpenGL ES-CM 1.1
01-06 01:44:41.762: I/SurfaceFlinger(131): extensions: GL_AMD_compressed_ATC_texture GL_AMD_performance_monitor GL_APPLE_texture_2D_limited_npot GL_ARB_vertex_buffer_object GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_type_2_10_10_10_REV GL_OES_blend_equation_separate GL_OES_blend_func_separate GL_OES_blend_subtract GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_depth_texture GL_OES_depth24 GL_OES_draw_texture GL_OES_EGL_image GL_OES_EGL_image_external GL_OES_framebuffer_object GL_OES_matrix_palette GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_read_format GL_OES_rgb8_rgba8 GL_OES_stencil_wrap GL_OES_texture_cube_map GL_OES_texture_env_crossbar GL_OES_texture_float GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_texture_mirrored_repeat GL_QCOM_binning_control GL_QCOM_extended_get GL_QCOM_tiled_rendering GL_AMD_compressed_3DC_texture
01-06 01:44:41.762: I/SurfaceFlinger(131): GL_MAX_TEXTURE_SIZE = 4096
01-06 01:44:41.762: I/SurfaceFlinger(131): GL_MAX_VIEWPORT_DIMS = 4096 x 4096
01-06 01:44:41.762: I/SurfaceFlinger(131): flags = 00000000
01-06 01:44:41.782: D/kernel(140): [ 15.712585] msm_hsusb msm_hsusb: reset
01-06 01:44:41.782: D/kernel(140): [ 15.714874]
01-06 01:44:41.782: D/kernel(140): [ 15.714874] *********** Charger Type: HOST PC
01-06 01:44:41.862: I/ServiceManager(146): Waiting for service drm.drmManager...
01-06 01:44:41.962: D/kernel(140): [ 15.891632] msm_hsusb msm_hsusb: reset
01-06 01:44:41.962: D/kernel(140): [ 15.891662]
01-06 01:44:41.962: D/kernel(140): [ 15.891662] Charger Type: STD DOWNSTREAM PORT
01-06 01:44:42.082: I/(148): ServiceManager: 0xfc50
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): msm_mixer_open: Opening the device
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): msm_mixer_count:mixer_cnt =53
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): got device_count 42
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 0
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: handset_rx:index = 0,dev_id: 0
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 0
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 1
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: handset_tx:index = 1,dev_id: 1
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 1
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 2
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: headset_stereo_rx:index = 2,dev_id: 2
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 2
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 4
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: headset_mono_tx:index = 4,dev_id: 4
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 4
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 5
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: fmradio_handset_rx:index = 5,dev_id: 5
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 17 for device 5
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 8
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: fmradio_speaker_rx:index = 8,dev_id: 7
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 17 for device 7
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 9
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: fmradio_headset_rx:index = 9,dev_id: 8
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 17 for device 8
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 10
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: handset_dual_mic_endfire_tx:index = 10,dev_id: 9
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 9
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 12
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: speaker_dual_mic_endfire_tx:index = 12,dev_id: 11
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 11
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 13
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: speaker_mono_tx:index = 13,dev_id: 12
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 12
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 14
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: tty_headset_mono_rx:index = 14,dev_id: 13
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 37 for device 13
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 15
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: tty_headset_mono_tx:index = 15,dev_id: 14
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 38 for device 14
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 6
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: speaker_mono_rx:index = 6,dev_id: 15
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 15
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 18
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: headset_speaker_mono_rx:index = 18,dev_id: 16
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 16
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 21
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: ringtone_speaker_mono_rx:index = 21,dev_id: 18
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 18
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 26
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: handset_spkr_hac_rx:index = 26,dev_id: 19
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 19
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 27
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: headphone_mic_tx:index = 27,dev_id: 20
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 20
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 28
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: headphone_mic_endfire_tx:index = 28,dev_id: 22
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 22
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 29
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: speaker_secondary_mic_tx:index = 29,dev_id: 23
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 23
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 30
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: speaker_dual_mic_endfire_tx_real_stereo:index = 30,dev_id: 24
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 24
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 31
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: handset_asr_tx:index = 31,dev_id: 31
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 6 for device 31
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 32
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: xloud_speaker_mono_rx:index = 32,dev_id: 33
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 0,capablity = 5 for device 33
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 16
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: bt_sco_rx:index = 16,dev_id: 34
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 1,capablity = 5 for device 34
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 17
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: bt_sco_tx:index = 17,dev_id: 35
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 1,capablity = 6 for device 35
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 22
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: bt_carkit_rx:index = 22,dev_id: 36
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 1,capablity = 5 for device 36
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 23
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: bt_carkit_tx:index = 23,dev_id: 37
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 1,capablity = 6 for device 37
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 24
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: bt_dsp_sco_rx:index = 24,dev_id: 38
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 1,capablity = 5 for device 38
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 25
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: bt_dsp_sco_tx:index = 25,dev_id: 39
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 1,capablity = 6 for device 39
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 20
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: hdmi_stereo_rx:index = 20,dev_id: 40
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 3,capablity = 1 for device 40
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): index = 19
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Found device: fmradio_stereo_tx:index = 19,dev_id: 41
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): class ID = 2,capablity = 2 for device 41
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:0 dev_id:0 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:1 dev_id:1 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:2 dev_id:2 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:3 dev_id:65535 class_id:0 capability:00000000
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:4 dev_id:4 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:5 dev_id:5 class_id:0 capability:00000011
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:6 dev_id:15 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:7 dev_id:65535 class_id:0 capability:00000000
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:8 dev_id:7 class_id:0 capability:00000011
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:9 dev_id:8 class_id:0 capability:00000011
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:10 dev_id:9 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:11 dev_id:65535 class_id:0 capability:00000000
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:12 dev_id:11 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:13 dev_id:12 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:14 dev_id:13 class_id:0 capability:00000025
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:15 dev_id:14 class_id:0 capability:00000026
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:16 dev_id:34 class_id:1 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:17 dev_id:35 class_id:1 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:18 dev_id:16 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:19 dev_id:41 class_id:2 capability:00000002
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:20 dev_id:40 class_id:3 capability:00000001
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:21 dev_id:18 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:22 dev_id:36 class_id:1 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:23 dev_id:37 class_id:1 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:24 dev_id:38 class_id:1 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:25 dev_id:39 class_id:1 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:26 dev_id:19 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:27 dev_id:20 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:28 dev_id:22 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:29 dev_id:23 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:30 dev_id:24 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:31 dev_id:31 class_id:0 capability:00000006
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): Device index:32 dev_id:33 class_id:0 capability:00000005
01-06 01:44:42.102: D/AudioHardwareMSM7X30(148): get audio config
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): failed to open AUDIO_CONFIG_PATH /system/etc/AudioConfig.csv: No such file or directory (2).
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:0 dev_id:0 class_id:0 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:1 dev_id:1 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:2 dev_id:2 class_id:0 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:3 dev_id:65535 class_id:0 capability:00000000
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:4 dev_id:4 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:5 dev_id:5 class_id:0 capability:00000011
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:6 dev_id:15 class_id:0 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:7 dev_id:65535 class_id:0 capability:00000000
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:8 dev_id:7 class_id:0 capability:00000011
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:9 dev_id:8 class_id:0 capability:00000011
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:10 dev_id:9 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:11 dev_id:65535 class_id:0 capability:00000000
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:12 dev_id:11 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:13 dev_id:12 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:14 dev_id:13 class_id:0 capability:00000025
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:15 dev_id:14 class_id:0 capability:00000026
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:16 dev_id:34 class_id:1 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:17 dev_id:35 class_id:1 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:18 dev_id:16 class_id:0 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:19 dev_id:41 class_id:2 capability:00000002
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:20 dev_id:40 class_id:3 capability:00000001
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:21 dev_id:18 class_id:0 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:22 dev_id:36 class_id:1 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:23 dev_id:37 class_id:1 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:24 dev_id:38 class_id:1 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:25 dev_id:39 class_id:1 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:26 dev_id:19 class_id:0 capability:00000005
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:27 dev_id:20 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:28 dev_id:22 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:29 dev_id:23 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:30 dev_id:24 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:31 dev_id:31 class_id:0 capability:00000006
01-06 01:44:42.112: D/AudioHardwareMSM7X30(148): Device index:32 dev_id:33 class_id:0 capability:00000005
01-06 01:44:42.112: I/AudioFlinger(148): Loaded primary audio interface from LEGACY Audio HW HAL (audio)
01-06 01:44:42.112: I/AudioFlinger(148): Using 'LEGACY Audio HW HAL' (audio.primary) as the primary audio interface
01-06 01:44:42.112: D/AudioHardwareInterface(148): setMode(NORMAL)
01-06 01:44:42.112: I/AudioHardwareMSM7X30(148): Set master volume to 7.
01-06 01:44:42.112: I/CameraService(148): CameraService started (pid=148)
01-06 01:44:42.212: D/kernel(140): [ 16.139038] android_usb gadget: high speed config #1: android
01-06 01:44:42.212: D/kernel(140): [ 16.141357] bq24185 0-006b: Turning on charger. USB-Host mode
01-06 01:44:42.212: D/kernel(140): [ 16.141357] bq24185 0-006b: Set init values
01-06 01:44:42.212: D/kernel(140): [ 16.142150] bq24185 0-006b: Disabling charger
01-06 01:44:42.212: D/kernel(140): [ 16.145355] bq24185 0-006b: Setting input charger current to 500 mA
01-06 01:44:42.212: D/kernel(140): [ 16.146118] bq24185 0-006b: Setting charger voltage to 4200 mV
01-06 01:44:42.212: D/kernel(140): [ 16.147277] bq24185 0-006b: Setting charger current to 850 mA
01-06 01:44:42.212: D/kernel(140): [ 16.148040] bq24185 0-006b: Enabling charger
01-06 01:44:42.232: E/SEMC Camera HAL(148): HAL_getNumberOfCameras: E
01-06 01:44:42.432: D/kernel(140): [ 16.359710] adb_open
01-06 01:44:42.852: D/libEGL(277): loaded /system/lib/egl/libGLES_android.so
01-06 01:44:42.852: D/libEGL(277): loaded /system/lib/egl/libEGL_adreno200.so
01-06 01:44:42.862: D/libEGL(277): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
01-06 01:44:42.862: D/libEGL(277): loaded /system/lib/egl/libGLESv2_adreno200.so
01-06 01:44:43.002: E/SEMC Camera HAL(148): HAL_getNumberOfCameras: E
01-06 01:44:43.062: I/AudioFlinger(148): AudioFlinger's thread 0x31c20 ready to run
01-06 01:44:43.072: E/CMarlinMediator(133): Error : MarlinMediator Failed to get TrustedTime
01-06 01:44:43.082: W/AudioFlinger(148): Thread AudioOut_1 cannot connect to the power manager service
01-06 01:44:43.092: I/AudioHardwareMSM7X30(148): Routing audio to Speakerphone
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): new_rx = 15
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): new_tx = 12
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): updateDeviceInfo: E rx_device 6 and tx_device 13
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): No active voicecall/playback, disabling cur_rx 65535
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): No active voicecall/recording, disabling cur_tx 65535
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): updateDeviceInfo: X cur_rx 6 cur_tx 13
01-06 01:44:43.092: D/AudioHardwareMSM7X30(148): AudioStreamOutMSM72xx::standby()
01-06 01:44:43.102: D/AudioHardwareMSM7X30(148): setVoiceVolume(1.000000)
01-06 01:44:43.102: I/AudioHardwareMSM7X30(148): Setting in-call volume to 100 (available range is 0 to 100)
01-06 01:44:43.102: E/AudioHardwareMSM7X30(148): msm_set_voice_rx_vol(100) failed errno = 1
01-06 01:44:43.102: I/AudioPolicyService(148): Loaded audio policy from LEGACY Audio Policy HAL (audio_policy)
01-06 01:44:43.102: D/BootAnimation(277): persist.sys.boot.sound.volume:66
01-06 01:44:43.102: I/BootAnimation(277): mp3 is null
01-06 01:44:43.352: I/SamplingProfilerIntegration(132): Profiling disabled.
01-06 01:44:43.382: I/Zygote(132): Preloading classes...
01-06 01:44:43.392: D/dalvikvm(132): GC_EXPLICIT freed 36K, 84% free 409K/2560K, paused 0ms+1ms
01-06 01:44:43.412: D/dalvikvm(132): GC_EXPLICIT freed 4K, 82% free 474K/2560K, paused 1ms+1ms
01-06 01:44:43.432: W/Zygote(132): Class not found for preloading: android.animation.ValueAnimator$2
01-06 01:44:43.432: W/Zygote(132): Class not found for preloading: android.animation.ValueAnimator$3
01-06 01:44:43.432: W/Zygote(132): Class not found for preloading: android.animation.ValueAnimator$4
01-06 01:44:43.432: W/Zygote(132): Class not found for preloading: android.animation.ValueAnimator$5
01-06 01:44:43.462: D/dalvikvm(132): GC_EXPLICIT freed 25K, 81% free 509K/2560K, paused 1ms+1ms
01-06 01:44:43.512: D/dalvikvm(132): GC_EXPLICIT freed 27K, 80% free 536K/2560K, paused 0ms+2ms
01-06 01:44:43.552: D/dalvikvm(132): GC_EXPLICIT freed 15K, 78% free 576K/2560K, paused 1ms+0ms
01-06 01:44:43.792: D/dalvikvm(132): GC_EXPLICIT freed 27K, 77% free 603K/2560K, paused 0ms+1ms
01-06 01:44:43.932: D/dalvikvm(132): GC_EXPLICIT freed 30K, 76% free 636K/2560K, paused 1ms+1ms
01-06 01:44:44.042: I/dalvikvm(132): threadid=1: recursive native library load attempt (/system/lib/libmedia_jni.so)
01-06 01:44:44.042: D/MtpDeviceJNI(132): register_android_mtp_MtpDevice
01-06 01:44:44.062: D/dalvikvm(132): GC_EXPLICIT freed 17K, 74% free 674K/2560K, paused 1ms+0ms
01-06 01:44:44.262: D/dalvikvm(132): GC_FOR_ALLOC freed 217K, 63% free 969K/2560K, paused 10ms
01-06 01:44:44.302: D/dalvikvm(132): GC_EXPLICIT freed 42K, 60% free 1025K/2560K, paused 1ms+2ms
01-06 01:44:44.382: D/dalvikvm(132): GC_EXPLICIT freed 24K, 59% free 1056K/2560K, paused 0ms+1ms
01-06 01:44:44.422: D/dalvikvm(132): GC_EXPLICIT freed 11K, 57% free 1108K/2560K, paused 1ms+1ms
01-06 01:44:44.602: D/dalvikvm(132): GC_EXPLICIT freed 25K, 56% free 1148K/2560K, paused 1ms+1ms
01-06 01:44:44.612: I/textrendering(132): SK_SCALAR_IS_FLOAT
01-06 01:44:44.752: D/dalvikvm(132): GC_EXPLICIT freed 27K, 44% free 1450K/2560K, paused 1ms+1ms
01-06 01:44:44.802: D/dalvikvm(132): GC_EXPLICIT freed 32K, 42% free 1488K/2560K, paused 2ms+2ms
01-06 01:44:44.842: D/dalvikvm(132): GC_EXPLICIT freed 31K, 41% free 1510K/2560K, paused 2ms+2ms
01-06 01:44:45.192: I/dalvikvm(132): threadid=1: recursive native library load attempt (/system/lib/libwebcore.so)
01-06 01:44:45.192: D/dalvikvm(132): No JNI_OnLoad found in /system/lib/libchromium_net.so 0x0, skipping init
01-06 01:44:45.252: D/dalvikvm(132): GC_EXPLICIT freed 28K, 40% free 1560K/2560K, paused 1ms+1ms
01-06 01:44:45.392: D/dalvikvm(132): GC_EXPLICIT freed 23K, 38% free 1591K/2560K, paused 2ms+1ms
01-06 01:44:45.442: W/Zygote(132): Class not found for preloading: android.widget.TextView$3
01-06 01:44:45.512: D/dalvikvm(132): GC_EXPLICIT freed 72K, 37% free 1635K/2560K, paused 2ms+1ms
01-06 01:44:45.542: E/PhonePolicy(132): Could not preload class for phone policy: com.android.internal.policy.impl.PhoneWindow$ContextMenuCallback
01-06 01:44:45.592: D/dalvikvm(132): GC_EXPLICIT freed 32K, 36% free 1657K/2560K, paused 2ms+2ms
01-06 01:44:45.652: D/dalvikvm(132): GC_EXPLICIT freed 31K, 35% free 1688K/2560K, paused 1ms+1ms
01-06 01:44:45.702: D/dalvikvm(132): GC_EXPLICIT freed 26K, 33% free 1719K/2560K, paused 2ms+1ms
01-06 01:44:45.732: D/dalvikvm(132): GC_EXPLICIT freed 32K, 32% free 1744K/2560K, paused 2ms+3ms
01-06 01:44:45.772: D/dalvikvm(132): GC_EXPLICIT freed 31K, 31% free 1772K/2560K, paused 1ms+1ms
01-06 01:44:45.812: D/dalvikvm(132): GC_EXPLICIT freed 71K, 29% free 1828K/2560K, paused 2ms+1ms
01-06 01:44:45.852: D/dalvikvm(132): GC_EXPLICIT freed 38K, 28% free 1844K/2560K, paused 3ms+1ms
01-06 01:44:46.362: I/System(132): Loaded time zone names for in 481ms (475ms in ICU)
01-06 01:44:46.702: I/System(132): Loaded time zone names for en_US in 347ms (338ms in ICU)
01-06 01:44:47.052: D/dalvikvm(132): GC_FOR_ALLOC freed 330K, 21% free 2026K/2560K, paused 21ms
01-06 01:44:47.072: I/System(132): Loaded time zone names for fr_FR in 363ms (358ms in ICU)
01-06 01:44:47.092: D/dalvikvm(132): GC_EXPLICIT freed 183K, 22% free 2003K/2560K, paused 2ms+2ms
01-06 01:44:47.122: D/dalvikvm(132): GC_EXPLICIT freed 14K, 20% free 2066K/2560K, paused 2ms+1ms
01-06 01:44:47.192: D/dalvikvm(132): GC_EXPLICIT freed 51K, 19% free 2097K/2560K, paused 2ms+2ms
01-06 01:44:47.232: D/dalvikvm(132): GC_EXPLICIT freed 28K, 17% free 2129K/2560K, paused 4ms+2ms
01-06 01:44:47.272: D/dalvikvm(132): GC_EXPLICIT freed 37K, 17% free 2145K/2560K, paused 2ms+1ms
01-06 01:44:47.322: D/dalvikvm(132): GC_EXPLICIT freed 32K, 16% free 2168K/2560K, paused 2ms+2ms
01-06 01:44:47.332: I/Zygote(132): ...preloaded 2319 classes in 3949ms.
01-06 01:44:47.352: D/dalvikvm(132): GC_EXPLICIT freed 22K, 16% free 2172K/2560K, paused 2ms+2ms
01-06 01:44:47.352: I/Zygote(132): Preloading resources...
01-06 01:44:47.392: D/dalvikvm(132): GC_EXPLICIT freed 1K, 13% free 2228K/2560K, paused 2ms+2ms
01-06 01:44:47.432: D/dalvikvm(132): GC_EXPLICIT freed 1K, 11% free 2279K/2560K, paused 2ms+1ms
01-06 01:44:47.462: D/dalvikvm(132): GC_EXPLICIT freed 3K, 10% free 2325K/2560K, paused 2ms+2ms
01-06 01:44:47.512: D/dalvikvm(132): GC_EXPLICIT freed 3K, 8% free 2373K/2560K, paused 2ms+2ms
01-06 01:44:47.542: D/dalvikvm(132): GC_EXPLICIT freed 4K, 8% free 2421K/2627K, paused 2ms+2ms
01-06 01:44:47.582: D/dalvikvm(132): GC_EXPLICIT freed 5K, 6% free 2473K/2627K, paused 2ms+2ms
01-06 01:44:47.612: D/dalvikvm(132): GC_EXPLICIT freed 4K, 7% free 2520K/2691K, paused 2ms+2ms
01-06 01:44:47.642: D/dalvikvm(132): GC_EXPLICIT freed 5K, 7% free 2565K/2755K, paused 3ms+2ms
01-06 01:44:47.682: D/dalvikvm(132): GC_EXPLICIT freed 4K, 6% free 2613K/2755K, paused 2ms+1ms
01-06 01:44:47.712: D/dalvikvm(132): GC_EXPLICIT freed 4K, 6% free 2663K/2819K, paused 2ms+2ms
01-06 01:44:47.752: D/dalvikvm(132): GC_EXPLICIT freed 5K, 6% free 2717K/2883K, paused 2ms+2ms
01-06 01:44:47.782: D/dalvikvm(132): GC_EXPLICIT freed 2K, 6% free 2780K/2947K, paused 2ms+1ms
01-06 01:44:47.822: D/dalvikvm(132): GC_EXPLICIT freed 3K, 5% free 2826K/2947K, paused 2ms+1ms
01-06 01:44:47.852: D/dalvikvm(132): GC_EXPLICIT freed 5K, 5% free 2871K/3011K, paused 1ms+2ms
01-06 01:44:47.892: D/dalvikvm(132): GC_EXPLICIT freed 7K, 6% free 2919K/3075K, paused 2ms+2ms
01-06 01:44:47.922: D/dalvikvm(132): GC_EXPLICIT freed 6K, 4% free 2967K/3075K, paused 2ms+2ms
01-06 01:44:47.962: D/dalvikvm(132): GC_EXPLICIT freed 5K, 5% free 3014K/3139K, paused 2ms+2ms
01-06 01:44:48.002: D/dalvikvm(132): GC_EXPLICIT freed 10K, 3% free 3061K/3139K, paused 2ms+1ms
01-06 01:44:48.042: D/dalvikvm(132): GC_EXPLICIT freed 6K, 3% free 3119K/3203K, paused 2ms+2ms
01-06 01:44:48.082: D/dalvikvm(132): GC_EXPLICIT freed 5K, 3% free 3170K/3267K, paused 2ms+2ms
01-06 01:44:48.112: D/dalvikvm(132): GC_EXPLICIT freed 4K, 3% free 3235K/3331K, paused 2ms+1ms
01-06 01:44:48.152: D/dalvikvm(132): GC_EXPLICIT freed 6K, 2% free 3287K/3331K, paused 4ms+2ms
01-06 01:44:48.192: D/dalvikvm(132): GC_EXPLICIT freed 3K, 2% free 3334K/3395K, paused 2ms+1ms
01-06 01:44:48.222: D/dalvikvm(132): GC_EXPLICIT freed 3K, 3% free 3504K/3587K, paused 2ms+2ms
01-06 01:44:48.252: D/dalvikvm(132): GC_EXPLICIT freed 5K, 1% free 3555K/3587K, paused 2ms+1ms
01-06 01:44:48.282: D/dalvikvm(132): GC_EXPLICIT freed 2K, 2% free 3605K/3651K, paused 2ms+2ms
01-06 01:44:48.322: D/dalvikvm(132): GC_EXPLICIT freed 5K, 2% free 3654K/3715K, paused 1ms+2ms
01-06 01:44:48.352: D/dalvikvm(132): GC_EXPLICIT freed 4K, 1% free 3828K/3843K, paused 1ms+1ms
01-06 01:44:48.382: D/dalvikvm(132): GC_EXPLICIT freed 3K, 1% free 3875K/3907K, paused 2ms+2ms
01-06 01:44:48.432: D/dalvikvm(132): GC_EXPLICIT freed 5K, 3% free 4935K/5059K, paused 2ms+2ms
01-06 01:44:48.482: D/dalvikvm(132): GC_EXPLICIT freed 5K, 4% free 5956K/6147K, paused 2ms+2ms
01-06 01:44:48.522: D/dalvikvm(132): GC_EXPLICIT freed 4K, 3% free 6005K/6147K, paused 2ms+2ms
01-06 01:44:48.562: D/dalvikvm(132): GC_EXPLICIT freed 7K, 2% free 6049K/6147K, paused 1ms+2ms
01-06 01:44:48.602: D/dalvikvm(132): GC_EXPLICIT freed 6K, 1% free 6096K/6147K, paused 2ms+2ms
01-06 01:44:48.642: D/dalvikvm(132): GC_EXPLICIT freed 5K, 2% free 6144K/6211K, paused 2ms+2ms
01-06 01:44:48.672: D/dalvikvm(132): GC_EXPLICIT freed 2K, 1% free 6196K/6211K, paused 2ms+2ms
01-06 01:44:48.712: D/dalvikvm(132): GC_EXPLICIT freed 4K, 1% free 6244K/6275K, paused 2ms+2ms
01-06 01:44:48.752: D/dalvikvm(132): GC_EXPLICIT freed 6K, 1% free 6305K/6339K, paused 3ms+2ms
01-06 01:44:48.782: D/dalvikvm(132): GC_EXPLICIT freed 3K, 1% free 6370K/6403K, paused 2ms+2ms
01-06 01:44:48.812: I/Zygote(132): ...preloaded 382 resources in 1453ms.
01-06 01:44:48.842: D/dalvikvm(132): GC_EXPLICIT freed 20K, 1% free 6404K/6467K, paused 2ms+2ms
01-06 01:44:48.852: I/Zygote(132): ...preloaded 31 resources in 42ms.
01-06 01:44:48.882: D/dalvikvm(132): GC_EXPLICIT freed 14K, 1% free 6407K/6467K, paused 2ms+2ms
01-06 01:44:48.902: D/dalvikvm(132): GC_EXPLICIT freed 6K, 2% free 6400K/6467K, paused 2ms+2ms
01-06 01:44:48.932: D/dalvikvm(132): GC_EXPLICIT freed <1K, 2% free 6400K/6467K, paused 2ms+2ms
01-06 01:44:48.932: I/dalvikvm(132): System server process 307 has been created
01-06 01:44:48.942: I/Zygote(132): Accepting command socket connections
01-06 01:44:49.082: I/sysproc(307): Entered system_init()
01-06 01:44:49.082: I/sysproc(307): ServiceManager: 0x218e00
01-06 01:44:49.082: D/SensorService(307): nuSensorService starting...
01-06 01:44:49.092: I/AKMD2(145): akmd2 : Compass Opened.
01-06 01:44:49.102: D/kernel(140): [ 23.031280] AKM8975 AKECS_GetOpenStatus returned (1)
01-06 01:44:49.102: D/kernel(140): [ 23.033355] Enabled VREG "wlan" at 2900 mV
01-06 01:44:49.102: D/kernel(140): [ 23.034240] AKM8975 AKECS_GetCloseStatus returned (0)
01-06 01:44:49.102: I/AKMD2(145): akmd2 : Compass Closed.
01-06 01:44:49.102: D/DASH - ak897x(307): ak897x_read_sensor_map: AK8975 Compass: axis map [ 0 1 2]
01-06 01:44:49.102: D/DASH - ak897x(307): ak897x_read_sensor_map: AK8975 Compass: axis sign [ 1 1 -1]
01-06 01:44:49.102: D/DASH - ak897x(307): ak897x_read_sensor_map: AK8975 Compass Raw: axis map [ 0 1 2]
01-06 01:44:49.102: D/DASH - ak897x(307): ak897x_read_sensor_map: AK8975 Compass Raw: axis sign [ 1 1 -1]
01-06 01:44:49.102: D/DASH - ak897x(307): ak897x_read_sensor_map: AK8975 Magnetic Field: axis map [ 0 1 2]
01-06 01:44:49.102: D/DASH - ak897x(307): ak897x_read_sensor_map: AK8975 Magnetic Field: axis sign [ 1 -1 -1]
01-06 01:44:49.112: D/kernel(140): [ 23.039215] Disabled VREG "wlan"
01-06 01:44:49.112: D/kernel(140): [ 23.047058] Enabled VREG "wlan" at 2900 mV
01-06 01:44:49.112: D/DASH-bma250_input(307): bma250_input_request_delay: delay:0
01-06 01:44:49.112: E/DASH - ak897x(307): ak897x_activate: unable to set accelerometer delay!
01-06 01:44:49.112: I/SensorService(307): BMA250 accelerometer
01-06 01:44:49.122: D/kernel(140): [ 23.052917] Disabled VREG "wlan"
01-06 01:44:49.122: I/SensorService(307): AK8975 Compass
01-06 01:44:49.122: I/SensorService(307): AK8975 Compass Raw
01-06 01:44:49.122: I/SensorService(307): AK8975 Magnetic Field
01-06 01:44:49.122: I/SensorService(307): APDS9702 Proximity
01-06 01:44:49.122: I/sysproc(307): System server: starting Android runtime.
01-06 01:44:49.122: I/sysproc(307): System server: starting Android services.
01-06 01:44:49.122: D/SensorService(307): nuSensorService thread starting...
01-06 01:44:49.122: I/sysproc(307): System server: entering thread pool.
01-06 01:44:49.122: I/SystemServer(307): Entered the Android system server!
01-06 01:44:49.122: I/SystemServer(307): Entropy Service
01-06 01:44:49.132: I/SystemServer(307): Power Manager
01-06 01:44:49.142: I/SystemServer(307): Activity Manager
01-06 01:44:49.172: I/ActivityManager(307): Memory class: 48
01-06 01:44:49.202: W/UsageStats(307): Usage stats version changed; dropping
01-06 01:44:49.362: D/dalvikvm(307): GC_CONCURRENT freed 274K, 5% free 6647K/6983K, paused 2ms+3ms
01-06 01:44:49.382: I/SystemServer(307): Telephony Registry
01-06 01:44:49.382: I/SystemServer(307): Package Manager
01-06 01:44:49.482: D/dalvikvm(307): GC_CONCURRENT freed 400K, 8% free 6701K/7239K, paused 3ms+2ms
01-06 01:44:49.522: D/dalvikvm(307): GC_FOR_ALLOC freed 404K, 9% free 6695K/7303K, paused 19ms
01-06 01:44:49.582: D/dalvikvm(307): GC_CONCURRENT freed 369K, 8% free 6737K/7303K, paused 3ms+2ms
01-06 01:44:49.742: D/dalvikvm(307): GC_CONCURRENT freed 385K, 7% free 6847K/7303K, paused 2ms+2ms
01-06 01:44:50.022: D/dalvikvm(307): GC_CONCURRENT freed 228K, 5% free 7045K/7367K, paused 2ms+2ms
01-06 01:44:50.372: W/PackageManager(307): Library not found: /system/framework/com.sonyericsson.android.socialphonebook.jar
01-06 01:44:50.492: D/dalvikvm(307): GC_CONCURRENT freed 310K, 6% free 7157K/7559K, paused 2ms+3ms
01-06 01:44:50.642: I/PackageManager(307): /system/framework/SemcGenericUxpRes.apk changed; collecting certs
01-06 01:44:50.732: D/dalvikvm(307): GC_CONCURRENT freed 187K, 4% free 7505K/7751K, paused 2ms+6ms
01-06 01:44:50.762: W/PackageManager(307): Application package com.sonyericsson.uxp already installed. Skipping duplicate.
01-06 01:44:51.252: W/PackageParser(307): No actions in intent filter at /system/app/textinput-tng.apk Binary XML file line #37
01-06 01:44:51.332: D/dalvikvm(307): GC_CONCURRENT freed 265K, 5% free 7695K/8071K, paused 2ms+7ms
01-06 01:44:51.462: W/ResourceType(307): Failure getting entry for 0x7f020000 (t=1 e=0) in package 0 (error -75)
01-06 01:44:51.572: W/PackageParser(307): No actions in intent filter at /system/app/Bluetooth.apk Binary XML file line #114
01-06 01:44:51.602: W/PackageParser(307): /system/app/OemCryptoReceiver.apk (at Binary XML file line #16):
01-06 01:44:51.762: W/PackageManager(307): Package com.sonyericsson.infiniteview desires unavailable shared library com.sonyericsson.nfc.handover; ignoring!
01-06 01:44:51.862: D/dalvikvm(307): GC_CONCURRENT freed 472K, 7% free 7700K/8263K, paused 2ms+3ms
01-06 01:44:51.932: W/PackageParser(307): Unknown element under
01-06 01:44:52.552: D/dalvikvm(307): GC_CONCURRENT freed 272K, 5% free 7899K/8263K, paused 1ms+5ms
01-06 01:44:52.642: W/PackageParser(307): Unknown element under
01-06 01:44:52.652: W/PackageParser(307): No readPermission or writePermssion for
01-06 01:44:53.032: W/PackageParser(307): No actions in intent filter at /system/app/SemcSnpStore.apk Binary XML file line #150
01-06 01:44:53.032: W/PackageParser(307): No actions in intent filter at /system/app/SemcSnpStore.apk Binary XML file line #238
01-06 01:44:53.032: W/PackageParser(307): No actions in intent filter at /system/app/SemcSnpStore.apk Binary XML file line #247
01-06 01:44:53.032: W/PackageParser(307): No actions in intent filter at /system/app/SemcSnpStore.apk Binary XML file line #279
01-06 01:44:53.132: I/PackageManager(307): Package com.mobisystems.office at /system/app/officesuite.apk ignored: updated version 1010 better than this 357
01-06 01:44:53.192: I/PackageManager(307): Package com.google.android.street at /system/app/Street.apk ignored: updated version 18102 better than this 17200
01-06 01:44:53.232: D/dalvikvm(307): GC_CONCURRENT freed 281K, 5% free 8114K/8519K, paused 1ms+3ms
01-06 01:44:53.292: I/PackageManager(307): Package com.adobe.reader at /system/app/com.adobe.reader.apk ignored: updated version 69805 better than this 52926
01-06 01:44:53.302: I/PackageManager(307): Package com.dsi.ant.service.socket at /system/app/antradioservice.apk ignored: updated version 20801 better than this 22
01-06 01:44:53.392: W/ResourceType(307): Failure getting entry for 0x7f02004b (t=1 e=75) in package 0 (error -75)
01-06 01:44:53.572: W/ResourceType(307): Failure getting entry for 0x7f0d001e (t=12 e=30) in package 0 (error -75)
01-06 01:44:53.582: I/PackageManager(307): Package com.google.android.youtube at /system/app/YouTube.apk ignored: updated version 4216 better than this 3505
01-06 01:44:53.772: D/dalvikvm(307): GC_CONCURRENT freed 279K, 4% free 8364K/8711K, paused 3ms+5ms
01-06 01:44:53.792: I/PackageManager(307): Package com.google.android.apps.maps at /system/app/GMS_Maps.apk ignored: updated version 614020501 better than this 606001401
01-06 01:44:53.982: I/PackageManager(307): Package com.sonyericsson.extras.liveware at /system/app/livewaremanager.apk ignored: updated version 50012 better than this 30308
01-06 01:44:54.082: I/PackageManager(307): Package com.android.vending at /system/app/Phonesky.apk ignored: updated version 8016010 better than this 8011016
01-06 01:44:54.272: W/ResourceType(307): Failure getting entry for 0x7f02000a (t=1 e=10) in package 0 (error -75)
01-06 01:44:54.272: W/ResourceType(307): Failure getting entry for 0x7f030008 (t=2 e=8) in package 0 (error -75)
01-06 01:44:54.272: W/PackageParser(307): Unknown element under
01-06 01:44:54.282: D/dalvikvm(307): GC_CONCURRENT freed 475K, 7% free 8350K/8903K, paused 2ms+4ms
01-06 01:44:54.472: I/PackageManager(307): Package com.facebook.katana at /system/app/facebook.apk ignored: updated version 107431 better than this 9581
01-06 01:44:54.822: W/PackageManager(307): Permission com.google.android.googleapps.permission.GOOGLE_MAIL_SWITCH from package com.google.android.gsf.login ignored: original from com.google.android.gsf
01-06 01:44:54.822: W/PackageManager(307): Permission com.google.android.googleapps.permission.ACCESS_GOOGLE_PASSWORD from package com.google.android.gsf.login ignored: original from com.google.android.gsf
01-06 01:44:54.922: I/PackageManager(307): Package com.google.android.gm at /system/app/Gmail.apk ignored: updated version 615 better than this 330
01-06 01:44:54.982: D/dalvikvm(307): GC_CONCURRENT freed 305K, 5% free 8536K/8903K, paused 2ms+4ms
01-06 01:44:55.252: W/ResourceType(307): Failure getting entry for 0x7f020000 (t=1 e=0) in package 0 (error -75)
01-06 01:44:55.662: D/PackageManager(307): No files in app dir /vendor/app
01-06 01:44:55.662: I/installd(135): new connection
01-06 01:44:55.662: I/Installer(307): connecting...
01-06 01:44:55.702: D/dalvikvm(307): GC_CONCURRENT freed 295K, 5% free 8726K/9095K, paused 2ms+6ms
01-06 01:44:56.022: I/PackageParser(307): com.example.android.BluetoothChat: compat added android.permission.WRITE_EXTERNAL_STORAGE android.permission.READ_PHONE_STATE
01-06 01:44:56.112: W/PackageParser(307): No actions in intent filter at /data/app/com.eclipsim.gpsstatus2-1.apk Binary XML file line #46
01-06 01:44:56.402: D/dalvikvm(307): GC_CONCURRENT freed 286K, 4% free 8995K/9351K, paused 2ms+5ms
01-06 01:44:56.532: W/Resources(307): Converting to boolean: TypedValue{t=0x3/d=0x518 "true" a=3 r=0x7f0b0000}
01-06 01:44:56.582: I/PackageParser(307): com.sony.snei.mu.phone: compat added android.permission.WRITE_EXTERNAL_STORAGE android.permission.READ_PHONE_STATE
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2274
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2292
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2305
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2327
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2337
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2347
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2357
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2367
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2377
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2387
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2397
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2407
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2417
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2427
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2437
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2447
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2460
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2468
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2476
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2495
01-06 01:44:56.882: W/PackageParser(307): No actions in intent filter at /data/app/com.quoord.tapatalkpro.activity-1.apk Binary XML file line #2529
01-06 01:44:56.952: D/dalvikvm(307): GC_CONCURRENT freed 275K, 4% free 9373K/9735K, paused 2ms+6ms
01-06 01:44:57.482: D/dalvikvm(307): GC_CONCURRENT freed 195K, 3% free 9827K/10119K, paused 2ms+7ms
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #187
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #194
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #199
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #204
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #211
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #217
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #222
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #227
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #232
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #239
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #245
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #251
01-06 01:44:57.502: W/PackageParser(307): No actions in intent filter at /data/app/com.sonyericsson.extras.liveware-1.apk Binary XML file line #257
01-06 01:44:57.562: I/PackageParser(307): com.sonyericsson.xhs: compat added android.permission.WRITE_EXTERNAL_STORAGE android.permission.READ_PHONE_STATE
01-06 01:44:57.562: I/PackageManager(307): Time to scan packages: 7.279 seconds
01-06 01:44:57.562: W/PackageManager(307): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.needom.recorder
01-06 01:44:57.562: W/PackageManager(307): Unknown permission android.permission.ADD_SYSTEM_SERVICE in package com.android.phone
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.facebook.proxylogin
01-06 01:44:57.572: W/PackageManager(307): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.browser (protectionLevel=2 flags=0x9be45)
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.sonyericsson.android.permission.FACERECOGNITION_SERVICE in package com.sonyericsson.android.camera3d
01-06 01:44:57.572: W/PackageManager(307): Unknown permission android.permission.READ_OWNER_DATA in package com.google.android.setupwizard
01-06 01:44:57.572: W/PackageManager(307): Unknown permission android.permission.WRITE_OWNER_DATA in package com.google.android.setupwizard
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.android.settings
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.android.settings
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.sonyericsson.android.permission.SEMC_PLUGIN_ACCESS in package com.sonyericsson.widget.text2action
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.widget.text2action
01-06 01:44:57.572: W/PackageManager(307): Unknown permission com.facebook.orca.provider.ACCESS in package com.facebook.katana
01-06 01:44:57.582: W/PackageManager(307): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package fr.banquepopulaire.cyberplus
01-06 01:44:57.582: W/PackageManager(307): Unknown permission android.permission.ACCESS_LOCATION in package com.sonyericsson.android.servicemenu
01-06 01:44:57.582: W/PackageManager(307): Unknown permission android.permission.ACCESS_GPS in package com.sonyericsson.android.servicemenu
01-06 01:44:57.582: W/PackageManager(307): Unknown permission android.permission.ACCESS_WAKE_LOCK in package com.sonyericsson.android.servicemenu
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.sonyericsson.servicemenu.permission.ACCESS_SERVICE_MENU in package com.sonyericsson.android.servicemenu
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.android.providers.im.permission.READ_ONLY in package com.google.android.apps.maps
01-06 01:44:57.582: W/PackageManager(307): Not granting permission com.sonyericsson.permission.BLACKLISTED_USB_DEVICE to package com.sonyericsson.extras.liveware (protectionLevel=3 flags=0x8bec5)
01-06 01:44:57.582: W/PackageManager(307): Not granting permission android.permission.WRITE_SECURE_SETTINGS to package com.sonyericsson.extras.liveware (protectionLevel=3 flags=0x8bec5)
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.sonyericsson.music.permission.MUSICSERVICE in package com.sonyericsson.extras.liveware
01-06 01:44:57.582: W/PackageManager(307): Not granting permission com.sonyericsson.phone.permission.DATA_TRAFFIC_SWITCH to package com.sonyericsson.extras.liveware (protectionLevel=3 flags=0x8bec5)
01-06 01:44:57.582: W/PackageManager(307): Not granting permission com.sonyericsson.permission.VENDOR_BUTTON to package com.sonyericsson.extras.liveware (protectionLevel=3 flags=0x8bec5)
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.smartslidersettings
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.sonyericsson.playnowstore.v1.permission.INSTALL_APPLICATION in package de.arvatomobile.sonyericsson.playnow.android
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.android.launcher.permission.READ_SETTINGS in package com.google.android.onetimeinitializer
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.android.launcher.permission.WRITE_SETTINGS in package com.google.android.onetimeinitializer
01-06 01:44:57.582: W/PackageManager(307): Unknown permission com.google.android.apps.googlevoice.permission.AUTO_SEND in package com.google.android.voicesearch
01-06 01:44:57.582: W/PackageManager(307): Unknown permission android.permission.LISTEN_SERVICE_STATE in package fr.freemobile.android.mobileconfig
01-06 01:44:57.582: W/PackageManager(307): Not granting permission android.permission.MODIFY_PHONE_STATE to package fr.freemobile.android.mobileconfig (protectionLevel=3 flags=0xbe44)
01-06 01:44:57.582: W/PackageManager(307): Not granting permission android.permission.WRITE_APN_SETTINGS to package fr.freemobile.android.mobileconfig (protectionLevel=3 flags=0xbe44)
01-06 01:44:57.582: W/PackageManager(307): Not granting permission com.google.android.gm.permission.READ_GMAIL to package com.google.android.apps.uploader (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.592: W/PackageManager(307): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.android.vending
01-06 01:44:57.592: W/PackageManager(307): Not granting permission android.permission.CHANGE_COMPONENT_ENABLED_STATE to package com.android.vending (protectionLevel=3 flags=0xabec5)
01-06 01:44:57.592: W/PackageManager(307): Not granting permission android.permission.SEND_DOWNLOAD_COMPLETED_INTENTS to package com.android.vending (protectionLevel=2 flags=0xabec5)
01-06 01:44:57.592: W/PackageManager(307): Not granting permission android.permission.SEND_SMS_NO_CONFIRMATION to package com.android.vending (protectionLevel=3 flags=0xabec5)
01-06 01:44:57.592: W/PackageManager(307): Not granting permission android.permission.STATUS_BAR to package com.android.vending (protectionLevel=3 flags=0xabec5)
01-06 01:44:57.592: W/PackageManager(307): Not granting permission android.permission.PACKAGE_USAGE_STATS to package com.android.vending (protectionLevel=3 flags=0xabec5)
01-06 01:44:57.592: W/PackageManager(307): Not granting permission android.permission.PACKAGE_VERIFICATION_AGENT to package com.android.vending (protectionLevel=3 flags=0xabec5)
01-06 01:44:57.592: W/PackageManager(307): Unknown permission android.permission.MANAGE_USERS in package com.android.vending
01-06 01:44:57.592: W/PackageManager(307): Unknown permission android.permission.INTERACT_ACROSS_USERS in package com.android.vending
01-06 01:44:57.592: W/PackageManager(307): Unknown permission com.sonyericsson.permission.IDD in package com.sonyericsson.crashmonitor
01-06 01:44:57.592: W/PackageManager(307): Unknown permission com.sonyericsson.permission.IDD_PRIVATE in package com.sonyericsson.crashmonitor
01-06 01:44:57.592: W/PackageManager(307): Unknown permission android.Manifest.permission.READ_LOGS in package com.sonyericsson.crashmonitor
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.androidapp.retaildemo
01-06 01:44:57.602: W/PackageManager(307): Not granting permission android.permission.CLEAR_APP_USER_DATA to package com.sonyericsson.androidapp.retaildemo (protectionLevel=2 flags=0xbe45)
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.android.vending.billing.IBillingAccountService.BIND2 in package com.google.android.gsf.login
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CONTACTS_PICK_CONVERSATIONS_TARGET in package com.sonyericsson.conversations
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.sonyericsson.permission.ACCESS_PROTECTED_CONTACTS in package com.sonyericsson.conversations
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.textinput.uxp
01-06 01:44:57.602: W/PackageManager(307): Unknown permission android.permission.RAISED_THREAD_PRIORITY in package com.mcafee.vsm.se
01-06 01:44:57.602: W/PackageManager(307): Not granting permission android.permission.DELETE_PACKAGES to package com.mcafee.vsm.se (protectionLevel=3 flags=0x2000ae44)
01-06 01:44:57.602: I/PackageManager(307): Un-granting permission android.permission.DUMP from package com.google.android.gms (protectionLevel=3 flags=0x8be44)
01-06 01:44:57.602: W/PackageManager(307): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.google.android.gms
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.appshare
01-06 01:44:57.602: W/PackageManager(307): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.gallery
01-06 01:44:57.602: W/PackageManager(307): Unknown permission android.webkit.permission.PLUGIN in package com.adobe.flashplayer
01-06 01:44:57.612: W/PackageManager(307): Not granting permission com.google.android.gm.permission.READ_GMAIL to package com.sonyericsson.music (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.android.pobox
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.facebook.permission.AUTHORIZE_SERVICE in package com.sonyericsson.androidapp.fbcalendarsync
01-06 01:44:57.612: W/PackageManager(307): Unknown permission android.permission.READ_EXTERNAL_STORAGE in package com.lachainemeteo.androidapp
01-06 01:44:57.612: W/PackageManager(307): Not granting permission android.permission.DEVICE_POWER to package com.sonyericsson.android.socialphonebook (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.612: W/PackageManager(307): Not granting permission android.permission.ACCESS_DRM to package com.sonyericsson.android.socialphonebook (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.android.email.permission.ACCESS_GAL_PROVIDER in package com.sonyericsson.android.socialphonebook
01-06 01:44:57.612: W/PackageManager(307): Not granting permission com.sonyericsson.permission.CONVERSATIONS_SETTINGS_PROVIDER to package com.sonyericsson.android.socialphonebook (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.google.android.providers.gmail.permission.READ_GMAIL in package com.mobisystems.office
01-06 01:44:57.612: W/PackageManager(307): Not granting permission android.permission.WRITE_SECURE_SETTINGS to package com.whatsapp (protectionLevel=3 flags=0xbe44)
01-06 01:44:57.612: W/PackageManager(307): Not granting permission android.permission.ACCOUNT_MANAGER to package com.moxier.sonyericsson.mail (protectionLevel=2 flags=0x8be44)
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.permission.HANDOVER_SERVICE in package com.sonyericsson.infiniteview
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CONTACTS_PICK_CONVERSATIONS_TARGET in package com.sonyericsson.infiniteview
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.permission.RENREN in package com.sonyericsson.infiniteview
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.permission.USERAGENT in package com.sonyericsson.trackid3.client
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.trackid3.client
01-06 01:44:57.612: W/PackageManager(307): Unknown permission com.sonyericsson.timescape.permission.TIMESCAPE_SETTINGS in package com.sonyericsson.setupwizard
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.sonyericsson.shutdownservice.permission.SHUTDOWNSERVICE in package com.sonyericsson.setupwizard
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.setupwizard
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.sonyericsson.timescape.permission.TIMESCAPE_SETTINGS in package com.sonyericsson.settings
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.sonyericsson.android.permission.SEMC_PLUGIN_ACCESS in package com.sonyericsson.solsplayer
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.sonyericsson.permission.PICKER in package com.sonyericsson.sync.ui
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.sonyericsson.permission.CUSTOMIZATION in package com.sonyericsson.android.support
01-06 01:44:57.622: W/PackageManager(307): Unknown permission android.permission.READ_OWNER_DATA in package com.sonyericsson.android.support
01-06 01:44:57.622: W/PackageManager(307): Unknown permission com.estrongs.android.pop.PERMISSION in package com.estrongs.android.pop
01-06 01:44:57.622: W/PackageManager(307): Not granting permission android.permission.DEVICE_POWER to package com.android.deskclock (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.622: W/PackageManager(307): Not granting permission android.permission.DEVICE_POWER to package com.android.facelock (protectionLevel=2 flags=0x8be45)
01-06 01:44:57.622: W/PackageManager(307): Unknown permission andriod.permission.MANAGE_USB in package com.sonyericsson.usbux
01-06 01:44:57.832: D/dalvikvm(307): GC_CONCURRENT freed 674K, 7% free 10022K/10759K, paused 2ms+4ms
01-06 01:44:57.952: D/dalvikvm(307): GC_EXPLICIT freed 208K, 9% free 9896K/10823K, paused 2ms+5ms
01-06 01:44:57.962: I/SystemServer(307): Account Manager
01-06 01:44:57.992: D/PackageManager(307): generateServicesMap(android.accounts.AccountAuthenticator): 12 services unchanged
01-06 01:44:58.022: I/SystemServer(307): Content Manager
01-06 01:44:58.112: D/PackageManager(307): generateServicesMap(android.content.SyncAdapter): 26 services unchanged
01-06 01:44:58.122: I/ActivityThread(307): Pub settings: com.android.providers.settings.SettingsProvider
01-06 01:44:58.122: I/SystemServer(307): System Content Providers
01-06 01:44:58.182: D/SettingsProvider(307): cache for settings table 'secure' rows=129; fullycached=true
01-06 01:44:58.202: D/SettingsProvider(307): cache for settings table 'system' rows=75; fullycached=true
01-06 01:44:58.232: D/lights(307): open_lights: open=backlight
01-06 01:44:58.232: D/lights(307): open_lights: open=keyboard
01-06 01:44:58.232: D/lights(307): open_lights: open=buttons
01-06 01:44:58.232: D/lights(307): open_lights: open=battery
01-06 01:44:58.232: D/lights(307): open_lights: open=notifications
01-06 01:44:58.232: D/lights(307): open_lights: open=attention
01-06 01:44:58.232: D/lights(307): open_lights: open=bluetooth
01-06 01:44:58.232: I/SystemServer(307): Lights Service
01-06 01:44:58.242: D/lights(307): open_lights: open=wifi
01-06 01:44:58.242: D/lights(307): set_light_battery: color=0xffff3000, mode=0
01-06 01:44:58.242: I/SystemServer(307): Battery Service
01-06 01:44:58.242: I/SystemServer(307): Vibrator Service
01-06 01:44:58.252: D/kernel(140): [ 32.185485] __msm_rpc_connect: server not found 30000061:30001
01-06 01:44:58.252: D/kernel(140): [ 32.185485] init vib rpc version 196609 failed!
01-06 01:44:58.252: D/kernel(140): [ 32.185516] __msm_rpc_connect: server not found 30000061:30002
01-06 01:44:58.252: D/kernel(140): [ 32.185516] init vib rpc version 196610 failed!
01-06 01:44:58.252: D/kernel(140): [ 32.185516] __msm_rpc_connect: server not found 30000061:30003
01-06 01:44:58.252: D/kernel(140): [ 32.185546] init vib rpc version 196611 failed!
01-06 01:44:58.252: D/kernel(140): [ 32.185546] __msm_rpc_connect: server not found 30000061:30004
01-06 01:44:58.252: D/kernel(140): [ 32.185546] init vib rpc version 196612 failed!
01-06 01:44:58.272: D/lights(307): set_light_backlight: brightness=0
01-06 01:44:58.272: I/power(307): *** set_screen_state 1
01-06 01:44:58.272: D/lights(307): set_light_buttons: brightness=255
01-06 01:44:58.282: D/kernel(140): [ 32.217010] request_suspend_state: wakeup (3->0) at 26508425383 (1980-01-06 00:44:58.280883814 UTC)
01-06 01:44:58.292: D/lights(307): set_light_backlight: brightness=182
01-06 01:44:58.292: D/AlarmManagerService(307): Kernel timezone updated to -60 minutes west of GMT
01-06 01:44:58.292: I/SystemServer(307): Alarm Manager
01-06 01:44:58.302: I/SystemServer(307): Init Watchdog
01-06 01:44:58.302: I/SystemServer(307): Window Manager
01-06 01:44:58.332: I/InputManager(307): Initializing input manager
01-06 01:44:58.352: W/StatusBarManager(307): warning: no STATUS_BAR_SERVICE
01-06 01:44:58.392: D/dalvikvm(307): GC_CONCURRENT freed 639K, 7% free 10164K/10887K, paused 6ms+9ms
01-06 01:44:58.392: E/CMarlinMediator(133): Error : MarlinMediator Failed to get TrustedTime
01-06 01:44:58.412: D/DASH - select(307): sensors_select_callback: select canceled by request
01-06 01:44:58.412: D/DASH-bma250_input(307): bma250_input_config_delay: rate:200000000
01-06 01:44:58.412: D/DASH-bma250_input(307): bma250_input_config_delay: rate:66667000
01-06 01:44:58.422: I/InputManager(307): Starting input manager
01-06 01:44:58.422: I/SystemServer(307): Bluetooth Service
01-06 01:44:58.432: D/EventHub(307): No input device configuration file found for device 'pm8058-keypad'.
01-06 01:44:58.452: I/EventHub(307): New device: id=1, fd=74, path='/dev/input/event2', name='pm8058-keypad', classes=0x3, configuration='', keyLayout='/system/usr/keylayout/pm8058-keypad.kl', keyCharacterMap='/system/usr/keychars/pm8058-keypad.kcm', builtinKeyboard=true
01-06 01:44:58.462: I/AKMD2(145): akmd2 : Compass Opened.
01-06 01:44:58.462: D/EventHub(307): No input device configuration file found for device 'compass'.
01-06 01:44:58.462: D/EventHub(307): No input device configuration file found for device 'bma250'.
01-06 01:44:58.462: I/EventHub(307): ignoring event id /dev/input/event7 driver simple_remote_appkey
01-06 01:44:58.462: D/EventHub(307): No input device configuration file found for device 'simple_remote'.
01-06 01:44:58.472: D/kernel(140): [ 32.398773] AKM8975 AKECS_GetOpenStatus returned (1)
01-06 01:44:58.472: D/kernel(140): [ 32.407379] AKM8975 AKECS_GetCloseStatus returned (0)
01-06 01:44:58.472: I/AKMD2(145): akmd2 : Compass Closed.
01-06 01:44:58.472: I/EventHub(307): New device: id=4, fd=80, path='/dev/input/event6', name='simple_remote', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/simple_remote.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false
01-06 01:44:58.482: D/kernel(140): [ 32.418487] Enabled VREG "wlan" at 2900 mV
01-06 01:44:58.482: D/EventHub(307): No input device configuration file found for device 'apds9702'.
01-06 01:44:58.482: I/BluetoothProfileState(307): Message:Entering Stable State
01-06 01:44:58.492: D/kernel(140): [ 32.426544] Disabled VREG "wlan"
01-06 01:44:58.492: D/EventHub(307): No input device configuration file found for device 'slider-mogami'.
01-06 01:44:58.492: I/EventHub(307): New device: id=6, fd=81, path='/dev/input/event4', name='slider-mogami', classes=0x80, configuration='', keyLayout='', keyCharacterMap='', builtinKeyboard=false
01-06 01:44:58.492: D/EventHub(307): No input device configuration file found for device 'msm_pmic_pwr_key'.
01-06 01:44:58.492: I/EventHub(307): New device: id=7, fd=85, path='/dev/input/event1', name='msm_pmic_pwr_key', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/msm_pmic_pwr_key.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false
01-06 01:44:58.492: D/EventHub(307): No input device configuration file found for device 'cyttsp_key'.
01-06 01:44:58.502: I/BluetoothProfileState(307): Message:Entering Stable State
01-06 01:44:58.512: I/EventHub(307): New device: id=8, fd=89, path='/dev/input/event0', name='cyttsp_key', classes=0x1, configuration='', keyLayout='/system/usr/keylayout/cyttsp_key.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false
01-06 01:44:58.512: I/EventHub(307): New device: id=9, fd=131, path='/dev/input/event3', name='cyttsp-spi', classes=0x14, configuration='/system/usr/idc/cyttsp-spi.idc', keyLayout='', keyCharacterMap='', builtinKeyboard=false
01-06 01:44:58.512: I/InputReader(307): Touch device 'cyttsp-spi' could not query the properties of its associated display 0. The device will be inoperable until the display size becomes available.
01-06 01:44:58.522: I/InputReader(307): Device added: id=9, name='cyttsp-spi', sources=0x00001002
01-06 01:44:58.522: I/InputReader(307): Device added: id=8, name='cyttsp_key', sources=0x00000101
01-06 01:44:58.522: I/InputReader(307): Device added: id=7, name='msm_pmic_pwr_key', sources=0x00000101
01-06 01:44:58.522: I/InputReader(307): Device added: id=6, name='slider-mogami', sources=0x80000000
01-06 01:44:58.522: I/InputReader(307): Device added: id=4, name='simple_remote', sources=0x00000101
01-06 01:44:58.522: I/InputReader(307): Device added: id=0, name='pm8058-keypad', sources=0x00000101
01-06 01:44:58.522: I/SystemServer(307): Input Method Service
01-06 01:44:58.532: D/BluetoothAdapterStateMachine(307): PowerOff process message: 1
01-06 01:44:58.532: D/BluetoothAdapterStateMachine(307): Bluetooth state 10 -> 11
01-06 01:44:58.532: W/InputManagerService(307): Couldn't create dir.: /data/system/inputmethod
01-06 01:44:58.542: I/bluedroid(307): Starting hciattach daemon
01-06 01:44:58.542: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:58.552: E/CMarlinMediator(133): Error : MarlinMediator Failed to get TrustedTime
01-06 01:44:58.622: I/SystemServer(307): Accessibility Manager
01-06 01:44:58.632: I/InputReader(307): Reconfiguring input devices. changes=0x00000004
01-06 01:44:58.632: I/InputReader(307): Device reconfigured: id=9, name='cyttsp-spi', surface size is now 320x480, mode is 1
01-06 01:44:58.632: I/ActivityManager(307): Config changed: {1.0 0mcc0mnc fr_FR layoutdir=0 sw320dp w320dp h455dp nrml port ?uimode ?night finger qwerty/v/h -nav/h theme=ComponentInfo{/} s.2}
01-06 01:44:58.642: D/PermissionCache(131): checking android.permission.ACCESS_SURFACE_FLINGER for uid=1000 => granted (1007 us)
01-06 01:44:58.642: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:58.642: I/SystemServer(307): Device Policy
01-06 01:44:58.652: I/SystemServer(307): Status Bar
01-06 01:44:58.662: I/SystemServer(307): Clipboard Service
01-06 01:44:58.662: I/SystemServer(307): NetworkManagement Service
01-06 01:44:58.682: I/SystemServer(307): Text Service Manager Service
01-06 01:44:58.682: W/TextServicesManagerService(307): no available spell checker services found
01-06 01:44:58.682: I/SystemServer(307): NetworkStats Service
01-06 01:44:58.692: I/SystemServer(307): NetworkPolicy Service
01-06 01:44:58.702: I/SystemServer(307): Wi-Fi P2pService
01-06 01:44:58.712: I/SystemServer(307): Wi-Fi Service
01-06 01:44:58.742: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:58.742: I/SystemServer(307): Connectivity Service
01-06 01:44:58.752: D/ConnectivityService(307): ConnectivityService starting up
01-06 01:44:58.762: E/MobileDataStateTracker(307): default: Ignoring feature request because could not acquire PhoneService
01-06 01:44:58.762: E/MobileDataStateTracker(307): default: Could not enable APN type "default"
01-06 01:44:58.762: D/NetworkManagementService(307): Registering observer
01-06 01:44:58.762: I/WifiService(307): WifiService starting up with Wi-Fi enabled
01-06 01:44:58.772: D/NetworkManagementService(307): rsp <213 84:00:d2:22:33:a7 0.0.0.0 0 [down broadcast multicast]>
01-06 01:44:58.772: D/NetworkManagementService(307): flags <[down broadcast multicast]>
01-06 01:44:58.782: D/CommandListener(128): Setting iface cfg
01-06 01:44:58.782: D/CommandListener(128): Trying to bring down wlan0
01-06 01:44:58.782: D/CommandListener(128): broadcast flag ignored
01-06 01:44:58.782: D/CommandListener(128): multicast flag ignored
01-06 01:44:58.782: I/SystemServer(307): Throttle Service
01-06 01:44:58.792: I/SystemServer(307): Mount Service
01-06 01:44:58.792: D/MountService(307): got storage path: /mnt/sdcard description: Carte SD primary: true removable: true emulated: false mtpReserve: 0 allowMassStorage: true maxFileSize: 0
01-06 01:44:58.802: I/SystemServer(307): Notification Manager
01-06 01:44:58.812: I/SystemServer(307): Device Storage Monitor
01-06 01:44:58.812: I/SystemServer(307): Location Manager
01-06 01:44:58.812: I/PackageManager(307): Updating external media status from unmounted to unmounted
01-06 01:44:58.812: D/VoldCmdListener(127): volume list
01-06 01:44:58.812: D/MountService(307): volume state changed for /mnt/sdcard (null -> unmounted)
01-06 01:44:58.822: D/kernel(140): [ 32.750366] Calling CRDA for country: US
01-06 01:44:58.822: I/SystemServer(307): Country Detector
01-06 01:44:58.822: I/SystemServer(307): Search Service
01-06 01:44:58.822: I/SystemServer(307): DropBox Service
01-06 01:44:58.832: I/SystemServer(307): Wallpaper Service
01-06 01:44:58.832: I/SystemServer(307): Audio Service
01-06 01:44:58.842: D/wpa_supplicant(374): wpa_supplicant v0.8.x
01-06 01:44:58.842: D/wpa_supplicant(374): Initializing interface 'wlan0' conf '/data/misc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
01-06 01:44:58.842: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:58.842: D/wpa_supplicant(374): Configuration file '/data/misc/wifi/wpa_supplicant.conf' -> '/data/misc/wifi/wpa_supplicant.conf'
01-06 01:44:58.852: D/kernel(140): [ 32.781555] Regulatory domain changed to country: US
01-06 01:44:58.852: D/kernel(140): [ 32.781585] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
01-06 01:44:58.852: D/kernel(140): [ 32.781585] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
01-06 01:44:58.852: D/kernel(140): [ 32.781585] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
01-06 01:44:58.852: D/kernel(140): [ 32.781616] (5250000 KHz - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:58.852: D/kernel(140): [ 32.781616] (5490000 KHz - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:58.852: D/kernel(140): [ 32.781646] (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
01-06 01:44:58.852: D/kernel(140): [ 32.781646] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
01-06 01:44:58.852: D/wpa_supplicant(374): Reading configuration file '/data/misc/wifi/wpa_supplicant.conf'
01-06 01:44:58.852: D/wpa_supplicant(374): ctrl_interface='wlan0'
01-06 01:44:58.852: D/wpa_supplicant(374): update_config=1
01-06 01:44:58.852: D/wpa_supplicant(374): Line: 5 - start of a new network block
01-06 01:44:58.852: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:44:58.852: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:44:58.852: D/wpa_supplicant(374): priority=87 (0x57)
01-06 01:44:58.892: I/AudioService(307): Remote Control registerMediaButtonIntent() for PendingIntent{2bcf9b48: PendingIntentRecord{2bf81f78 android broadcastIntent}}
01-06 01:44:58.902: I/SystemServer(307): Dock Observer
01-06 01:44:58.902: W/DockObserver(307): This kernel does not have dock station support
01-06 01:44:58.902: I/SystemServer(307): Wired Accessory Observer
01-06 01:44:58.902: I/SystemServer(307): USB Service
01-06 01:44:58.922: I/SystemServer(307): UI Mode Manager Service
01-06 01:44:58.922: I/SystemServer(307): Backup Service
01-06 01:44:58.932: D/kernel(140): [ 32.860046] acc_open
01-06 01:44:58.932: D/kernel(140): [ 32.860076] acc_release
01-06 01:44:58.932: V/BackupManagerService(307): Initializing package tracking
01-06 01:44:58.942: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.042: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.112: D/wpa_supplicant(374): Line: 13 - start of a new network block
01-06 01:44:59.112: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:44:59.112: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:44:59.112: D/wpa_supplicant(374): priority=170 (0xaa)
01-06 01:44:59.142: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.152: D/dalvikvm(307): GC_CONCURRENT freed 408K, 5% free 10721K/11207K, paused 2ms+5ms
01-06 01:44:59.202: V/BackupManagerService(307): addPackageParticipantsLocked: all
01-06 01:44:59.202: V/BackupManagerService(307): Registering transport android/com.android.internal.backup.LocalTransport = com.android.internal.backup.LocalTransport@2bf2f4c8
01-06 01:44:59.202: V/BackupManagerService(307): Starting with transport android/com.android.internal.backup.LocalTransport
01-06 01:44:59.202: V/BackupManagerService(307): Binding to Google transport
01-06 01:44:59.212: I/BackupManagerService(307): Backup enabled => true
01-06 01:44:59.212: I/SystemServer(307): AppWidget Service
01-06 01:44:59.212: I/SystemServer(307): Recognition Service
01-06 01:44:59.212: I/SystemServer(307): DiskStats Service
01-06 01:44:59.212: I/SystemServer(307): SamplingProfiler Service
01-06 01:44:59.222: I/SystemServer(307): NetworkTimeUpdateService
01-06 01:44:59.222: I/WindowManager(307): SAFE MODE not enabled
01-06 01:44:59.222: D/dalvikvm(307): JIT started for system_server
01-06 01:44:59.232: D/PowerManagerService(307): system ready!
01-06 01:44:59.232: I/ActivityManager(307): System now ready
01-06 01:44:59.242: I/startupflag(387): Started
01-06 01:44:59.242: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.252: I/SystemServer(307): Making services ready
01-06 01:44:59.252: D/SystemServer(307): Starting service: Intent { cmp=com.android.systemui/.SystemUIService }
01-06 01:44:59.262: I/startupflag(387): Option: bootcomplete (3)
01-06 01:44:59.272: I/Zygote(307): Process: zygote socket opened
01-06 01:44:59.302: I/startupflag(387): Read value of MiscTA 2227: 0x55
01-06 01:44:59.302: I/startupflag(387): Startupflag return success.
01-06 01:44:59.312: I/ActivityManager(307): Start proc com.android.systemui for service com.android.systemui/.SystemUIService: pid=394 uid=1000 gids={1015, 3002, 3001, 3003, 3007}
01-06 01:44:59.312: D/NetworkManagementService(307): enabling bandwidth control
01-06 01:44:59.322: D/kernel(140): [ 33.251281] input: atdaemon as /devices/virtual/input/input10
01-06 01:44:59.322: D/EventHub(307): No input device configuration file found for device 'atdaemon'.
01-06 01:44:59.332: I/EventHub(307): New device: id=10, fd=197, path='/dev/input/event10', name='atdaemon', classes=0x80000005, configuration='', keyLayout='/system/usr/keylayout/atdaemon.kl', keyCharacterMap='/system/usr/keychars/Generic.kcm', builtinKeyboard=false
01-06 01:44:59.342: I/InputReader(307): Device reconfigured: id=10, name='atdaemon', surface size is now 320x480, mode is 3
01-06 01:44:59.342: I/InputReader(307): Device added: id=10, name='atdaemon', sources=0x00002103
01-06 01:44:59.342: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.382: D/PhoneLockJNI(307): miscta_read_ta_phone_lock() = 1
01-06 01:44:59.412: D/PhoneLockJNI(307): miscta_read_ta_phone_lock() = 1
01-06 01:44:59.412: D/UnlockScreen(307): portrait mode
01-06 01:44:59.452: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.522: D/wpa_supplicant(374): Line: 21 - start of a new network block
01-06 01:44:59.532: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:44:59.532: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:44:59.532: D/wpa_supplicant(374): priority=168 (0xa8)
01-06 01:44:59.542: V/TransportControlView(307): Create TCV com.android.internal.widget.TransportControlView@2c072648
01-06 01:44:59.552: I/bluedroid(307): bt_enable: ret: -1, errno: 19
01-06 01:44:59.602: D/SystemUIService(394): loading: class com.android.systemui.statusbar.phone.PhoneStatusBar
01-06 01:44:59.602: D/SystemUIService(394): running: com.android.systemui.statusbar.phone.PhoneStatusBar@2bbb0df0
01-06 01:44:59.672: I/ActivityManager(307): Start proc com.google.android.gsf.login for service com.google.android.gsf.login/com.google.android.gsf.loginservice.GoogleLoginService: pid=429 uid=10027 gids={3003, 1015, 2001, 1007, 3006}
01-06 01:44:59.692: I/bluedroid(307): bt_enable: ret: 0, errno: 19
01-06 01:44:59.692: I/bluedroid(307): Starting bluetoothd deamon
01-06 01:44:59.702: D/TextLayoutCache(307): Using debug level: 0 - Debug Enabled: 0
01-06 01:44:59.702: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.712: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.722: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.742: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.752: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.762: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.772: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.782: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.792: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.812: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.822: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.832: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.852: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.872: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.freedesktop.DBus.Error.ServiceUnknown (The name org.bluez was not provided by any .service files)
01-06 01:44:59.952: E/BluetoothEventLoop.cpp(307): get_adapter_path: D-Bus error: org.bluez.Error.NoSuchAdapter (No such adapter)
01-06 01:44:59.952: E/BluetoothEventLoop.cpp(307): failure setting up Event Loop!
01-06 01:45:00.072: I/ActivityManager(307): Start proc com.google.process.gapps for content provider com.google.android.gsf/.gservices.GservicesProvider: pid=455 uid=10027 gids={3003, 1015, 2001, 1007, 3006}
01-06 01:45:00.232: D/dalvikvm(394): GC_CONCURRENT freed 171K, 4% free 6646K/6919K, paused 3ms+75ms
01-06 01:45:00.242: D/wpa_supplicant(374): Line: 29 - start of a new network block
01-06 01:45:00.262: I/ActivityThread(455): Pub com.google.settings: com.google.android.gsf.settings.GoogleSettingsProvider
01-06 01:45:00.272: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:00.272: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:00.272: D/wpa_supplicant(374): priority=33 (0x21)
01-06 01:45:00.272: D/wpa_supplicant(374): Line: 36 - start of a new network block
01-06 01:45:00.272: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:00.272: D/wpa_supplicant(374): priority=35 (0x23)
01-06 01:45:00.302: I/ActivityThread(455): Pub subscribedfeeds: com.google.android.gsf.subscribedfeeds.SubscribedFeedsProvider
01-06 01:45:00.472: D/dalvikvm(307): GC_CONCURRENT freed 756K, 7% free 11078K/11911K, paused 3ms+5ms
01-06 01:45:00.472: I/ActivityThread(455): Pub com.google.contacts.gal.provider: com.google.android.syncadapters.contacts.GalProvider
01-06 01:45:00.482: D/NetworkManagementService(307): Registering observer
01-06 01:45:00.482: I/StatusBarManagerService(307): registerStatusBar bar=com.android.internal.statusbar.IStatusBar$Stub$Proxy@2bdeaa30
01-06 01:45:00.492: D/PhoneStatusBar(394): disable: < EXPAND* icons alerts TICKER* system_info BACK* HOME* RECENT* CLOCK* >
01-06 01:45:00.552: D/BluetoothEventLoop(307): Property Changed: Class : 524812
01-06 01:45:00.562: D/BluetoothEventLoop(307): Property Changed: Pairable : true
01-06 01:45:00.562: D/BluetoothEventLoop(307): Property Changed: Discoverable : false
01-06 01:45:00.572: D/StorageNotification(394): Startup with UMS connection false (media state unmounted)
01-06 01:45:00.572: D/NetworkManagementService(307): Registering observer
01-06 01:45:00.582: I/StorageNotification(394): UMS connection changed to false (media state unmounted)
01-06 01:45:00.592: I/ActivityManager(307): Config changed: {1.0 0mcc0mnc fr_FR layoutdir=0 sw320dp w320dp h455dp nrml port finger qwerty/v/h -nav/h theme=ComponentInfo{com.sonyericsson.defaultruntimethemes/com.sonyericsson.defaultruntimethemes.BlueThemeService} s.3}
01-06 01:45:00.602: D/SystemUIService(394): loading: class com.android.systemui.power.PowerUI
01-06 01:45:00.602: D/SystemUIService(394): running: com.android.systemui.power.PowerUI@2bbe6e50
01-06 01:45:00.612: I/ActivityThread(455): Pub com.google.android.gsf.gservices: com.google.android.gsf.gservices.GservicesProvider
01-06 01:45:00.632: D/BluetoothAdapterStateMachine(307): WarmUp process message: 101
01-06 01:45:00.632: D/BluetoothEventLoop(307): Property Changed: Powered : false
01-06 01:45:00.632: D/BluetoothAdapterStateMachine(307): WarmUp process message: 53
01-06 01:45:00.632: D/BluetoothAdapterStateMachine(307): WarmUp process message: 54
01-06 01:45:00.652: D/BluetoothEventLoop(307): Property Changed: Pairable : false
01-06 01:45:00.652: D/BluetoothEventLoop(307): Property Changed: Discoverable : false
01-06 01:45:00.652: D/BluetoothAdapterStateMachine(307): WarmUp process message: 53
01-06 01:45:00.652: I/GservicesProvider(455): Gservices pushing to system: true; secure: true
01-06 01:45:00.652: I/ActivityThread(455): Pub com.google.android.providers.talk: com.google.android.gsf.talk.TalkProvider
01-06 01:45:00.692: D/TextLayoutCache(394): Using debug level: 0 - Debug Enabled: 0
01-06 01:45:00.692: D/WifiService(307): New client listening to asynchronous messages
01-06 01:45:00.802: D/android.widget.GridLayout(307): vertical constraints: y1 - y0 > 126, y2 - y1 > 0, y3 - y2 > 280, y4 - y3 > 8, y5 - y4 > 48, y5 - y0 < 455 are inconsistent; permanently removing: y5 - y0 < 455.
01-06 01:45:00.832: D/SyncManager(307): setSyncAutomatically: , provider subscribedfeeds -> true
01-06 01:45:00.852: D/SyncManager(307): setSyncAutomatically: already set to true, doing nothing
01-06 01:45:00.872: D/wpa_supplicant(374): Line: 44 - start of a new network block
01-06 01:45:00.882: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:00.882: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:00.882: D/wpa_supplicant(374): priority=167 (0xa7)
01-06 01:45:01.072: W/InputManagerService(307): Ignoring setImeWindowStatus of uid 1000 token: null
01-06 01:45:01.112: I/ActivityManager(307): Start proc com.sonyericsson.textinput.uxp for service com.sonyericsson.textinput.uxp/.glue.InputMethodServiceGlue: pid=481 uid=10107 gids={}
01-06 01:45:01.162: D/NetworkManagementService(307): Registering observer
01-06 01:45:01.282: I/ActivityManager(307): Start proc com.android.phone for added application com.android.phone: pid=498 uid=1001 gids={3002, 3001, 3003, 1015}
01-06 01:45:01.302: W/ThrottleService(307): unable to find stats for iface rmnet0
01-06 01:45:01.322: I/ServiceManager(388): Waiting for service phone...
01-06 01:45:01.332: I/ActivityManager(307): Start proc com.sonyericsson.customization for added application com.sonyericsson.customization: pid=505 uid=10094 gids={}
01-06 01:45:01.342: I/ActivityManager(307): START {act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10000000 cmp=com.sonyericsson.home/.HomeActivity} from pid 0
01-06 01:45:01.382: I/ActivityManager(307): Start proc com.sonyericsson.home for activity com.sonyericsson.home/.HomeActivity: pid=523 uid=10004 gids={3003, 1015}
01-06 01:45:01.572: I/ActivityThread(505): Pub com.sonyericsson.provider.customization: com.sonyericsson.provider.customization.CustomizationProvider
01-06 01:45:01.582: D/wpa_supplicant(374): Line: 52 - start of a new network block
01-06 01:45:01.582: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:01.582: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:01.582: D/wpa_supplicant(374): priority=49 (0x31)
01-06 01:45:01.602: I/ActivityThread(505): Pub com.sonyericsson.provider.useragent: com.sonyericsson.provider.useragent.UserAgentProvider
01-06 01:45:01.692: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.sonyericsson.provider.useragent
01-06 01:45:01.702: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/sonyericsson/provider/useragent/custom_settings.xml
01-06 01:45:01.702: W/UserAgentProvider(505): onCreatejava.io.FileNotFoundException: No such file or directory
01-06 01:45:01.702: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.sonyericsson.textinput.uxp
01-06 01:45:01.702: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/sonyericsson/textinput/uxp/custom_settings.xml
01-06 01:45:01.762: I/ActivityThread(498): Pub telephony: com.android.providers.telephony.TelephonyProvider
01-06 01:45:01.852: W/TelephonyProvider(498): onCreate: confFile=/system/etc/apns-conf.xml oldCheckSum=-1
01-06 01:45:01.892: I/ActivityThread(498): Pub mms-sms: com.android.providers.telephony.SemcMmsSmsProvider
01-06 01:45:01.952: I/ActivityThread(498): Pub icc: com.android.phone.IccProvider
01-06 01:45:01.972: I/ActivityThread(498): Pub icc-cust: com.android.internal.telephony.IccCustProvider
01-06 01:45:01.982: I/ActivityThread(498): Pub com.android.phone.semcrejectmsgprovider: com.android.phone.SemcRejectMsgProvider
01-06 01:45:02.042: I/ActivityThread(498): Pub mms: com.android.providers.telephony.SemcMmsProvider
01-06 01:45:02.052: I/ActivityThread(498): Pub sms: com.android.providers.telephony.SemcSmsProvider
01-06 01:45:02.062: D/dalvikvm(394): GC_CONCURRENT freed 181K, 4% free 6923K/7175K, paused 2ms+11ms
01-06 01:45:02.092: I/PhoneApp(498): Debug level changed: 0
01-06 01:45:02.222: D/wpa_supplicant(374): Line: 60 - start of a new network block
01-06 01:45:02.222: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:02.222: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:02.222: D/wpa_supplicant(374): priority=64 (0x40)
01-06 01:45:02.252: D/dalvikvm(523): GC_CONCURRENT freed 152K, 4% free 6769K/6983K, paused 2ms+34ms
01-06 01:45:02.262: D/NetworkLocationService(455): onCreate com.google.android.location.NetworkLocationService@2bbd3060
01-06 01:45:02.292: D/dalvikvm(498): GC_CONCURRENT freed 205K, 4% free 6657K/6919K, paused 2ms+3ms
01-06 01:45:02.322: I/ServiceManager(388): Waiting for service phone...
01-06 01:45:02.352: D/NetworkLocationClient(455): ANDROID minProtocolVersion 1 maxProtocolVersion 1 releaseVersion -1
01-06 01:45:02.352: D/NetworkLocationClient(455): binding to Intent { act=com.google.android.location.internal.ANDROID_NLP }
01-06 01:45:02.432: W/ActivityManager(307): Unable to start service Intent { act=com.android.internal.telephony.IWapPushManager }: not found
01-06 01:45:02.512: D/(498): [ApnContext] set reason as dataEnabled, for type default,current state IDLE
01-06 01:45:02.522: D/(498): [ApnContext] set reason as dataEnabled, for type mms,current state IDLE
01-06 01:45:02.522: D/NetworkLocationService(455): onBind com.google.android.location.NetworkLocationProvidercom.google.android.location.NetworkLocationService@2bbd3060
01-06 01:45:02.522: D/(498): [ApnContext] set reason as dataEnabled, for type supl,current state IDLE
01-06 01:45:02.522: D/(498): [ApnContext] set reason as dataEnabled, for type dun,current state IDLE
01-06 01:45:02.522: D/(498): [ApnContext] set reason as dataEnabled, for type hipri,current state IDLE
01-06 01:45:02.542: D/(498): [ApnContext] set reason as dataEnabled, for type fota,current state IDLE
01-06 01:45:02.542: D/(498): [ApnContext] set reason as dataEnabled, for type ims,current state IDLE
01-06 01:45:02.542: D/(498): [ApnContext] set reason as dataEnabled, for type cbs,current state IDLE
01-06 01:45:02.572: D/NetworkLocationService(455): onBind com.google.android.location.GeocodeProvidercom.google.android.location.NetworkLocationService@2bbd3060
01-06 01:45:02.592: D/dalvikvm(455): GC_CONCURRENT freed 223K, 5% free 6611K/6919K, paused 2ms+2ms
01-06 01:45:02.612: D/androidInternalNlpService(455): onCreate com.google.android.location.internal.server.NetworkLocationService@2bbcef48
01-06 01:45:02.632: D/CAT(498): CatService: Running CAT service. STK app installed:true
01-06 01:45:02.632: D/CAT(498): CatService: NEW sInstance
01-06 01:45:02.632: D/CallManager(498): registerPhone(GSM Handler (com.android.internal.telephony.PhoneProxy) {2bbe8128})
01-06 01:45:02.652: D/NetworkLocationRealOs(455): NLPv2 file already exists; ignoring any NLPv1 files
01-06 01:45:02.662: D/androidNlpServiceThread(455): ANDROID minProtocolVersion 1 maxProtocolVersion 1 releaseVersion -1
01-06 01:45:02.682: D/NetworkLocationClient(455): onServiceConnected to ComponentInfo{com.google.android.location/com.google.android.location.internal.server.NetworkLocationService}
01-06 01:45:02.682: D/androidNetworkLocationListeners(455): Still have listener com.google.android.location.internal.client.NetworkLocationClient$1@2bbd9178
01-06 01:45:02.692: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:02.692: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:02.732: D/dalvikvm(523): GC_CONCURRENT freed 358K, 7% free 6888K/7367K, paused 2ms+2ms
01-06 01:45:02.752: I/ActivityManager(307): Start proc android.process.acore for content provider com.android.providers.contacts/.SemcCallLogProvider: pid=569 uid=10016 gids={3003, 1015}
01-06 01:45:02.772: D/BluetoothEventLoop(307): Property Changed: UUIDs : 6
01-06 01:45:02.772: E/BluetoothService.cpp(307): setBluetoothTetheringNative true
01-06 01:45:02.772: I/StorageNotification(394): UMS connection changed to true (media state unmounted)
01-06 01:45:02.802: V/BackupManagerService(307): Connected to Google transport
01-06 01:45:02.802: V/BackupManagerService(307): Registering transport com.google.android.backup/.BackupTransportService = com.google.android.backup.BackupTransportService$1@2bb86d68
01-06 01:45:02.832: D/BluetoothEventLoop(307): Property Changed: UUIDs : 7
01-06 01:45:02.862: D/BluetoothEventLoop(307): Property Changed: UUIDs : 8
01-06 01:45:02.902: D/BluetoothEventLoop(307): Property Changed: UUIDs : 9
01-06 01:45:02.902: D/BluetoothEventLoop(307): Property Changed: UUIDs : 10
01-06 01:45:02.962: D/BluetoothAdapterStateMachine(307): WarmUp process message: 51
01-06 01:45:02.962: D/BluetoothAdapterStateMachine(307): HotOff process message: 101
01-06 01:45:03.002: D/BluetoothEventLoop(307): Property Changed: Class : 1573388
01-06 01:45:03.002: I/ActivityManager(307): Start proc android.process.media for broadcast com.android.providers.media/.UsbReceiver: pid=582 uid=10021 gids={1015, 1023, 1024, 2001, 3003, 3007}
01-06 01:45:03.012: D/BluetoothEventLoop(307): Property Changed: Class : 5898764
01-06 01:45:03.022: D/BluetoothEventLoop(307): Property Changed: Pairable : true
01-06 01:45:03.022: D/BluetoothEventLoop(307): Property Changed: Discoverable : false
01-06 01:45:03.022: D/BluetoothAdapterStateMachine(307): Switching process message: 53
01-06 01:45:03.042: D/BluetoothBondState(307): found 9 bonded devices
01-06 01:45:03.072: D/wpa_supplicant(374): Line: 68 - start of a new network block
01-06 01:45:03.102: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:03.102: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:03.102: D/wpa_supplicant(374): priority=67 (0x43)
01-06 01:45:03.102: D/wpa_supplicant(374): Line: 75 - start of a new network block
01-06 01:45:03.102: D/wpa_supplicant(374): priority=68 (0x44)
01-06 01:45:03.102: D/wpa_supplicant(374): Line: 82 - start of a new network block
01-06 01:45:03.102: D/wpa_supplicant(374): priority=69 (0x45)
01-06 01:45:03.102: D/wpa_supplicant(374): Line: 89 - start of a new network block
01-06 01:45:03.102: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:03.102: D/wpa_supplicant(374): priority=72 (0x48)
01-06 01:45:03.172: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.192: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.202: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.222: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.232: D/dalvikvm(132): GC_EXPLICIT freed 34K, 5% free 6413K/6723K, paused 2ms+10ms
01-06 01:45:03.262: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.282: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.282: I/ActivityThread(569): Pub call_log: com.android.providers.contacts.SemcCallLogProvider
01-06 01:45:03.322: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.332: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.352: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:03.352: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:03.352: I/BluetoothDeviceProfileState(307): Entering ACL Connected state with: -2
01-06 01:45:03.372: D/BluetoothAdapterStateMachine(307): Bluetooth state 11 -> 12
01-06 01:45:03.392: I/ActivityThread(582): Pub downloads: com.android.providers.downloads.DownloadProvider
01-06 01:45:03.442: D/BluetoothService(307): updateDeviceServiceChannelCache(00:14:09:30:EE:63)
01-06 01:45:03.442: D/BluetoothService(307): uuid(system): 0000111e-0000-1000-8000-00805f9b34fb 4
01-06 01:45:03.452: D/BluetoothService(307): uuid(system): 00001105-0000-1000-8000-00805f9b34fb 1
01-06 01:45:03.472: D/BluetoothService(307): updateDeviceServiceChannelCache(00:14:09:08:28:25)
01-06 01:45:03.492: D/UUSParserFactory(498): UUSParserFactory
01-06 01:45:03.492: D/UUSParserFactory(498): registering UUSParsers
01-06 01:45:03.492: D/UUSParserFactory(498): number of uusparsers : 0
01-06 01:45:03.492: D/BluetoothService(307): uuid(system): 0000111e-0000-1000-8000-00805f9b34fb 4
01-06 01:45:03.502: D/BluetoothService(307): uuid(system): 00001105-0000-1000-8000-00805f9b34fb 1
01-06 01:45:03.522: D/BluetoothService(307): updateDeviceServiceChannelCache(8C:64:22:C2:13:88)
01-06 01:45:03.542: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:03.542: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:03.552: D/BluetoothService(307): uuid(system): 0000111e-0000-1000-8000-00805f9b34fb 2
01-06 01:45:03.552: D/BluetoothService(307): uuid(system): 00001108-0000-1000-8000-00805f9b34fb 1
01-06 01:45:03.572: D/dalvikvm(394): GC_FOR_ALLOC freed 62K, 5% free 6952K/7303K, paused 275ms
01-06 01:45:03.582: D/BluetoothService(307): updateDeviceServiceChannelCache(00:1A:6B:BE:BC:73)
01-06 01:45:03.612: D/BluetoothService(307): uuid(system): 00001108-0000-1000-8000-00805f9b34fb 5
01-06 01:45:03.612: D/BluetoothService(307): uuid(system): 00001105-0000-1000-8000-00805f9b34fb 2
01-06 01:45:03.622: I/dalvikvm-heap(394): Grow heap (frag case) to 8.020MB for 1228816-byte allocation
01-06 01:45:03.652: D/BluetoothService(307): updateDeviceServiceChannelCache(00:11:11:13:70:04)
01-06 01:45:03.662: D/dalvikvm(132): GC_EXPLICIT freed <1K, 5% free 6412K/6723K, paused 1ms+20ms
01-06 01:45:03.672: D/dalvikvm(455): GC_CONCURRENT freed 189K, 4% free 6987K/7239K, paused 1ms+67ms
01-06 01:45:03.722: I/ActivityThread(569): Pub contacts;com.android.contacts: com.android.providers.contacts.SemcContactsProvider2
01-06 01:45:03.792: D/dalvikvm(394): GC_FOR_ALLOC freed <1K, 5% free 8151K/8519K, paused 146ms
01-06 01:45:03.922: D/dalvikvm(132): GC_EXPLICIT freed <1K, 5% free 6412K/6723K, paused 7ms+28ms
01-06 01:45:03.972: D/dalvikvm(394): GC_CONCURRENT freed <1K, 5% free 8152K/8519K, paused 2ms+39ms
01-06 01:45:04.032: D/dalvikvm(523): GC_FOR_ALLOC freed 117K, 5% free 7182K/7495K, paused 136ms
01-06 01:45:04.122: D/dalvikvm(307): GC_CONCURRENT freed 849K, 8% free 11439K/12359K, paused 3ms+43ms
01-06 01:45:04.162: W/AccountManagerService(307): insertAccountIntoDatabase: Account {name=Phone contacts, type=com.sonyericsson.localcontacts}, skipping since the account already exists
01-06 01:45:04.262: D/dalvikvm(455): GC_CONCURRENT freed 659K, 10% free 6818K/7559K, paused 2ms+21ms
01-06 01:45:04.282: D/wpa_supplicant(374): Line: 97 - start of a new network block
01-06 01:45:04.282: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:04.282: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:04.282: D/wpa_supplicant(374): priority=74 (0x4a)
01-06 01:45:04.292: D/dalvikvm(569): GC_CONCURRENT freed 230K, 5% free 6653K/6983K, paused 2ms+3ms
01-06 01:45:04.292: D/wpa_supplicant(374): Line: 104 - start of a new network block
01-06 01:45:04.292: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:04.292: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:04.292: D/wpa_supplicant(374): priority=77 (0x4d)
01-06 01:45:04.292: D/wpa_supplicant(374): Line: 111 - start of a new network block
01-06 01:45:04.292: D/wpa_supplicant(374): auth_alg: 0x3
01-06 01:45:04.292: D/wpa_supplicant(374): priority=78 (0x4e)
01-06 01:45:04.292: D/wpa_supplicant(374): Line: 120 - start of a new network block
01-06 01:45:04.292: D/wpa_supplicant(374): priority=82 (0x52)
01-06 01:45:04.292: D/wpa_supplicant(374): Line: 127 - start of a new network block
01-06 01:45:04.292: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:04.292: D/wpa_supplicant(374): priority=91 (0x5b)
01-06 01:45:04.512: D/dalvikvm(307): GC_EXPLICIT freed 54K, 8% free 11391K/12359K, paused 3ms+17ms
01-06 01:45:04.512: D/BluetoothService(307): updateDeviceServiceChannelCache(00:1B:DC:02:6B:41)
01-06 01:45:04.512: D/BluetoothService(307): uuid(system): 00001105-0000-1000-8000-00805f9b34fb 1
01-06 01:45:04.532: D/BluetoothService(307): updateDeviceServiceChannelCache(00:0D:B5:82:AE:98)
01-06 01:45:04.542: D/BluetoothService(307): updateDeviceServiceChannelCache(30:85:A9:E5:6A:F6)
01-06 01:45:04.552: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.sonyericsson.home/custom_settings_global.xml
01-06 01:45:04.552: I/ActivityThread(569): Pub user_dictionary: com.android.providers.userdictionary.UserDictionaryProvider
01-06 01:45:04.552: D/androidNetworkLocationListeners(455): Still have listener com.google.android.location.internal.client.NetworkLocationClient$1@2bbd9178
01-06 01:45:04.562: D/androidNetworkLocationListeners(455): Still have listener com.google.android.location.internal.client.NetworkLocationClient$1@2bbd9178
01-06 01:45:04.572: D/BluetoothService(307): uuid(system): 00001105-0000-1000-8000-00805f9b34fb 12
01-06 01:45:04.582: D/NetworkLocator(455): null cell state delivered
01-06 01:45:04.592: D/NetworkLocator(455): null cell state delivered
01-06 01:45:04.602: D/NetworkLocator(455): null cell state delivered
01-06 01:45:04.622: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:04.632: W/dalvikvm(307): threadid=11: thread exiting with uncaught exception (group=0x2b542210)
01-06 01:45:04.632: I/ActivityThread(582): Pub drm: com.android.providers.drm.DrmProvider
01-06 01:45:04.632: I/DownloadManager(582): in removeSpuriousFiles
01-06 01:45:04.642: D/NetworkLocator(455): null cell state delivered
01-06 01:45:04.662: I/ActivityThread(569): Pub com.android.voicemail: com.android.providers.contacts.SemcVoicemailContentProvider
01-06 01:45:04.662: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:04.672: I/AudioHardwareMSM7X30(148): DualMike feature Enabled
01-06 01:45:04.672: I/AudioHardwareMSM7X30(148): Routing audio to Speakerphone
01-06 01:45:04.672: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:04.672: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:04.682: D/BluetoothA2dpService(307): connectSink(8C:64:22:C2:13:88)
01-06 01:45:04.682: I/BluetoothProfileState(307): Message:Entering PendingCommandState State
01-06 01:45:04.682: I/BluetoothDeviceProfileState(307): Entering OutgoingA2dp state with: 3
01-06 01:45:04.692: E/AndroidRuntime(307): *** FATAL EXCEPTION IN SYSTEM PROCESS: android.server.ServerThread
01-06 01:45:04.692: E/AndroidRuntime(307): java.lang.RuntimeException: Error receiving broadcast Intent { act=android.bluetooth.adapter.action.STATE_CHANGED flg=0x10000010 (has extras) } in android.server.BluetoothA2dpService$1@2bfbecc0
01-06 01:45:04.692: E/AndroidRuntime(307): at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:737)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.os.Handler.handleCallback(Handler.java:605)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.os.Handler.dispatchMessage(Handler.java:92)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.os.Looper.loop(Looper.java:137)
01-06 01:45:04.692: E/AndroidRuntime(307): at com.android.server.ServerThread.run(SystemServer.java:748)
01-06 01:45:04.692: E/AndroidRuntime(307): Caused by: java.lang.ArrayIndexOutOfBoundsException: length=37; index=37
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothDeviceProperties.addProperties(BluetoothDeviceProperties.java:70)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothDeviceProperties.updateCache(BluetoothDeviceProperties.java:136)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothDeviceProperties.getProperty(BluetoothDeviceProperties.java:123)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothService.getUuidFromCache(BluetoothService.java:1254)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothService.getRemoteUuids(BluetoothService.java:1250)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothA2dpService.onBluetoothEnable(BluetoothA2dpService.java:208)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothA2dpService.access$000(BluetoothA2dpService.java:51)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.server.BluetoothA2dpService$1.onReceive(BluetoothA2dpService.java:85)
01-06 01:45:04.692: E/AndroidRuntime(307): at android.app.LoadedApk$ReceiverDispatcher$Args.run(LoadedApk.java:728)
01-06 01:45:04.692: E/AndroidRuntime(307): ... 4 more
01-06 01:45:04.702: D/BluetoothA2dpService(307): A2DP state : device: 8C:64:22:C2:13:88 State:0->1
01-06 01:45:04.712: I/ActivityThread(582): Pub media: com.android.providers.media.MediaProvider
01-06 01:45:04.712: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:04.712: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:04.722: D/BluetoothService(307): CONNECTION_STATE_CHANGE: 8C:64:22:C2:13:88: 0 -> 1
01-06 01:45:04.722: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/sonyericsson/home/custom_settings_global.xml
01-06 01:45:04.722: D/BluetoothA2dpService(307): A2DP: onSinkPropertyChanged newState is: 1mPlayingA2dpDevice: null
01-06 01:45:04.742: D/TextLayoutCache(523): Using debug level: 0 - Debug Enabled: 0
01-06 01:45:04.772: D/libEGL(523): loaded /system/lib/egl/libGLES_android.so
01-06 01:45:04.782: D/libEGL(523): loaded /system/lib/egl/libEGL_adreno200.so
01-06 01:45:04.782: D/libEGL(523): loaded /system/lib/egl/libGLESv1_CM_adreno200.so
01-06 01:45:04.782: D/libEGL(523): loaded /system/lib/egl/libGLESv2_adreno200.so
01-06 01:45:04.912: D/wpa_supplicant(374): Line: 135 - start of a new network block
01-06 01:45:04.922: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:04.922: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:04.922: D/wpa_supplicant(374): priority=92 (0x5c)
01-06 01:45:04.922: D/wpa_supplicant(374): Line: 142 - start of a new network block
01-06 01:45:04.922: D/wpa_supplicant(374): priority=95 (0x5f)
01-06 01:45:04.922: D/wpa_supplicant(374): Line: 149 - start of a new network block
01-06 01:45:04.922: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:04.922: D/wpa_supplicant(374): priority=103 (0x67)
01-06 01:45:04.932: D/OpenGLRenderer(523): Enabling debug mode 0
01-06 01:45:05.032: D/dalvikvm(523): GC_FOR_ALLOC freed 155K, 5% free 7281K/7623K, paused 63ms
01-06 01:45:05.042: I/dalvikvm-heap(523): Grow heap (frag case) to 7.725MB for 582416-byte allocation
01-06 01:45:05.102: D/dalvikvm(523): GC_FOR_ALLOC freed 4K, 5% free 7845K/8199K, paused 48ms
01-06 01:45:05.182: I/ActivityThread(569): Pub com.android.social: com.android.providers.contacts.SocialProvider
01-06 01:45:05.182: I/ActivityThread(569): Pub applications: com.android.providers.applications.ApplicationsProvider
01-06 01:45:05.222: D/dalvikvm(523): GC_CONCURRENT freed <1K, 5% free 7849K/8199K, paused 2ms+7ms
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 157 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:05.302: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:05.302: D/wpa_supplicant(374): priority=104 (0x68)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 164 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=105 (0x69)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 171 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=106 (0x6a)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 178 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=107 (0x6b)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 185 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=108 (0x6c)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 192 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=118 (0x76)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 199 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=124 (0x7c)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 206 - start of a new network block
01-06 01:45:05.302: D/wpa_supplicant(374): priority=127 (0x7f)
01-06 01:45:05.302: D/wpa_supplicant(374): Line: 213 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=131 (0x83)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 220 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:05.312: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:05.312: D/wpa_supplicant(374): priority=132 (0x84)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 227 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=133 (0x85)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 234 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=134 (0x86)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 241 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=136 (0x88)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 248 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=137 (0x89)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 255 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=138 (0x8a)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 262 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=140 (0x8c)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 269 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=143 (0x8f)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 276 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=144 (0x90)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 283 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=145 (0x91)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 290 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=157 (0x9d)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 297 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): priority=158 (0x9e)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 304 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): auth_alg: 0x3
01-06 01:45:05.312: D/wpa_supplicant(374): priority=159 (0x9f)
01-06 01:45:05.312: D/wpa_supplicant(374): Line: 313 - start of a new network block
01-06 01:45:05.312: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:05.312: D/wpa_supplicant(374): priority=165 (0xa5)
01-06 01:45:05.512: I/DownloadManager(582): in removeSpuriousFiles, preserving file /cache/2546465966.pkg
01-06 01:45:05.512: I/DownloadManager(582): in removeSpuriousFiles, preserving file /mnt/sdcard/Download/FTM-350_Series_Operating_Manual_EH033M202.pdf
01-06 01:45:05.512: I/DownloadManager(582): in removeSpuriousFiles, preserving file /mnt/sdcard/Download/FTM-350_Series_Operating_Manual_EH033M202-1.pdf
01-06 01:45:05.512: I/DownloadManager(582): deleting spurious file /cache/backup
01-06 01:45:05.692: I/ActivityManager(307): Start proc com.sonyericsson.usbux for broadcast com.sonyericsson.usbux/.service.UsbServiceReceiver: pid=622 uid=1000 gids={1015, 3002, 3001, 3003, 3007}
01-06 01:45:05.742: E/ResourceLoader(523): Error loading resource
01-06 01:45:05.742: E/ResourceLoader(523): android.content.pm.PackageManager$NameNotFoundException: com.pagesjaunes
01-06 01:45:05.742: E/ResourceLoader(523): at android.app.ApplicationPackageManager.getApplicationInfo(ApplicationPackageManager.java:208)
01-06 01:45:05.742: E/ResourceLoader(523): at android.app.ApplicationPackageManager.getResourcesForApplication(ApplicationPackageManager.java:700)
01-06 01:45:05.742: E/ResourceLoader(523): at com.sonyericsson.home.resourceload.ResourceLoader$LoadTask.execute(ResourceLoader.java:281)
01-06 01:45:05.742: E/ResourceLoader(523): at com.sonyericsson.util.Worker$1.run(Worker.java:202)
01-06 01:45:05.742: E/ResourceLoader(523): at android.os.Handler.handleCallback(Handler.java:605)
01-06 01:45:05.742: E/ResourceLoader(523): at android.os.Handler.dispatchMessage(Handler.java:92)
01-06 01:45:05.742: E/ResourceLoader(523): at android.os.Looper.loop(Looper.java:137)
01-06 01:45:05.742: E/ResourceLoader(523): at android.os.HandlerThread.run(HandlerThread.java:60)
01-06 01:45:05.752: D/kernel(140): [ 39.685821] CPUFREQ: Per core ondemand sysfs interface is deprecated - up_threshold
01-06 01:45:05.752: D/kernel(140): [ 39.685882] CPUFREQ: Per core ondemand sysfs interface is deprecated - sampling_rate
01-06 01:45:05.782: D/wpa_supplicant(374): Line: 321 - start of a new network block
01-06 01:45:05.812: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:05.812: D/wpa_supplicant(374): key_mgmt: 0x2
01-06 01:45:05.842: I/SurfaceFlinger(131): Boot is finished (24421 ms)
01-06 01:45:05.852: D/SurfaceFlinger(131): Release buffer at 0x4aca8
01-06 01:45:06.042: D/dalvikvm(498): GC_CONCURRENT freed 278K, 6% free 6774K/7175K, paused 2ms+2ms
01-06 01:45:06.062: D/dalvikvm(569): GC_CONCURRENT freed 315K, 7% free 6742K/7175K, paused 3ms+2ms
01-06 01:45:06.082: D/dalvikvm(498): GC_FOR_ALLOC freed <1K, 6% free 6774K/7175K, paused 37ms
01-06 01:45:06.082: I/dalvikvm-heap(498): Grow heap (frag case) to 6.968MB for 307216-byte allocation
01-06 01:45:06.152: D/dalvikvm(498): GC_FOR_ALLOC freed 0K, 6% free 7074K/7495K, paused 60ms
01-06 01:45:06.242: I/ActivityManager(307): Start proc com.eclipsim.gpsstatus2 for broadcast com.eclipsim.gpsstatus2/com.eclipsim.gpstoolbox.monitor.GpsBroadcastReceiver: pid=636 uid=10121 gids={3003}
01-06 01:45:06.302: I/dalvikvm(636): Turning on JNI app bug workarounds for target SDK version 8...
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=557 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at android.os.StrictMode$AndroidBlockGuardPolicy.onWriteToDisk(StrictMode.java:1072)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteStatement.acquireAndLock(SQLiteStatement.java:226)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteStatement.executeUpdateDelete(SQLiteStatement.java:84)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteDatabase.executeSql(SQLiteDatabase.java:1899)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteDatabase.execSQL(SQLiteDatabase.java:1839)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteDatabase.setPageSize(SQLiteDatabase.java:1297)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:995)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteDatabase.openDatabase(SQLiteDatabase.java:962)
01-06 01:45:06.312: D/StrictMode(569): at android.database.sqlite.SQLiteDatabase.create(SQLiteDatabase.java:1080)
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:246)
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.onCreate(ApplicationsProvider.java:175)
01-06 01:45:06.312: D/StrictMode(569): at android.content.ContentProvider.attachInfo(ContentProvider.java:944)
01-06 01:45:06.312: D/StrictMode(569): at android.app.ActivityThread.installProvider(ActivityThread.java:4254)
01-06 01:45:06.312: D/StrictMode(569): at android.app.ActivityThread.installContentProviders(ActivityThread.java:4009)
01-06 01:45:06.312: D/StrictMode(569): at android.app.ActivityThread.handleBindApplication(ActivityThread.java:3963)
01-06 01:45:06.312: D/StrictMode(569): at android.app.ActivityThread.access$1300(ActivityThread.java:127)
01-06 01:45:06.312: D/StrictMode(569): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1196)
01-06 01:45:06.312: D/StrictMode(569): at android.os.Handler.dispatchMessage(Handler.java:99)
01-06 01:45:06.312: D/StrictMode(569): at android.os.Looper.loop(Looper.java:137)
01-06 01:45:06.312: D/StrictMode(569): at android.app.ActivityThread.main(ActivityThread.java:4441)
01-06 01:45:06.312: D/StrictMode(569): at java.lang.reflect.Method.invokeNative(Native Method)
01-06 01:45:06.312: D/StrictMode(569): at java.lang.reflect.Method.invoke(Method.java:511)
01-06 01:45:06.312: D/StrictMode(569): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
01-06 01:45:06.312: D/StrictMode(569): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
01-06 01:45:06.312: D/StrictMode(569): at dalvik.system.NativeStart.main(Native Method)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=489 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:247)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=485 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:258)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=482 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:261)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=478 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:266)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=475 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:271)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=341 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:277)
01-06 01:45:06.312: D/StrictMode(569): StrictMode policy violation; ~duration=338 ms: android.os.StrictMode$StrictModeDiskWriteViolation: policy=31 violation=1
01-06 01:45:06.312: D/StrictMode(569): at com.android.providers.applications.ApplicationsProvider.createDatabase(ApplicationsProvider.java:282)
01-06 01:45:06.382: W/MTP-usbux.SdCard(622): SD card enabled as mass storagae:true
01-06 01:45:06.482: I/ActivityThread(636): Pub com.eclipsim.gpsstatus2.poiprovider: o.㱽
01-06 01:45:06.512: D/wpa_supplicant(374): Line: 328 - start of a new network block
01-06 01:45:06.512: D/wpa_supplicant(374): wapi_key_type=0 (0x0)
01-06 01:45:06.512: D/wpa_supplicant(374): key_mgmt: 0x4
01-06 01:45:06.512: D/wpa_supplicant(374): priority=169 (0xa9)
01-06 01:45:06.512: D/wpa_supplicant(374): Line: 335 - start of a new network block
01-06 01:45:06.512: D/wpa_supplicant(374): priority=-10 (0xfffffff6)
01-06 01:45:06.512: D/wpa_supplicant(374): Line: 342 - start of a new network block
01-06 01:45:06.512: D/wpa_supplicant(374): priority=173 (0xad)
01-06 01:45:06.512: D/wpa_supplicant(374): Line: 349 - start of a new network block
01-06 01:45:06.512: D/wpa_supplicant(374): priority=174 (0xae)
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 174
01-06 01:45:06.572: D/wpa_supplicant(374): id=47 ssid='SMC'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 173
01-06 01:45:06.572: D/wpa_supplicant(374): id=46 ssid='Wireless'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 170
01-06 01:45:06.572: D/wpa_supplicant(374): id=1 ssid='merck_family'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 169
01-06 01:45:06.572: D/wpa_supplicant(374): id=44 ssid='McDonald's France'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 168
01-06 01:45:06.572: D/wpa_supplicant(374): id=2 ssid='Feeling'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 167
01-06 01:45:06.572: D/wpa_supplicant(374): id=5 ssid='Poupou_Wouwou_2'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 165
01-06 01:45:06.572: D/wpa_supplicant(374): id=42 ssid='freebox_chris'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 159
01-06 01:45:06.572: D/wpa_supplicant(374): id=41 ssid='wifirotho'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 158
01-06 01:45:06.572: D/wpa_supplicant(374): id=40 ssid='Washington Dulles WiFi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 157
01-06 01:45:06.572: D/wpa_supplicant(374): id=39 ssid='attwifi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 145
01-06 01:45:06.572: D/wpa_supplicant(374): id=38 ssid='JHGuestnet'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 144
01-06 01:45:06.572: D/wpa_supplicant(374): id=37 ssid='Smokey-guest'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 143
01-06 01:45:06.572: D/wpa_supplicant(374): id=36 ssid='CleverFlamingo-guest'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 140
01-06 01:45:06.572: D/wpa_supplicant(374): id=35 ssid='jcp wi-fi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 138
01-06 01:45:06.572: D/wpa_supplicant(374): id=34 ssid='westfield'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 137
01-06 01:45:06.572: D/wpa_supplicant(374): id=33 ssid='Assateague WiFi Hotspot'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 136
01-06 01:45:06.572: D/wpa_supplicant(374): id=32 ssid='Tidelands'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 134
01-06 01:45:06.572: D/wpa_supplicant(374): id=31 ssid='surfintown'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 133
01-06 01:45:06.572: D/wpa_supplicant(374): id=30 ssid='Mobile Hotspot E'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 132
01-06 01:45:06.572: D/wpa_supplicant(374): id=29 ssid='SIMON WiFi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 131
01-06 01:45:06.572: D/wpa_supplicant(374): id=28 ssid='City Dock Cafe'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 127
01-06 01:45:06.572: D/wpa_supplicant(374): id=27 ssid='Macysfreewifi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 124
01-06 01:45:06.572: D/wpa_supplicant(374): id=26 ssid='Mobile Hotspot A'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 118
01-06 01:45:06.572: D/wpa_supplicant(374): id=25 ssid='DCWiFi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 108
01-06 01:45:06.572: D/wpa_supplicant(374): id=24 ssid='National Archives I'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 107
01-06 01:45:06.572: D/wpa_supplicant(374): id=23 ssid='Target Guest Wi-Fi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 106
01-06 01:45:06.572: D/wpa_supplicant(374): id=22 ssid='guest'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 105
01-06 01:45:06.572: D/wpa_supplicant(374): id=21 ssid='Lowes-Guest-WiFi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 104
01-06 01:45:06.572: D/wpa_supplicant(374): id=20 ssid='Applebees in Bowie'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 103
01-06 01:45:06.572: D/wpa_supplicant(374): id=19 ssid='HJ339'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 95
01-06 01:45:06.572: D/wpa_supplicant(374): id=18 ssid='ResidenceInn_GUEST'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 92
01-06 01:45:06.572: D/wpa_supplicant(374): id=17 ssid='mycloud'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 91
01-06 01:45:06.572: D/wpa_supplicant(374): id=16 ssid='freebox_Chris_maison'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 87
01-06 01:45:06.572: D/wpa_supplicant(374): id=0 ssid='Poupou_Wouwou'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 82
01-06 01:45:06.572: D/wpa_supplicant(374): id=15 ssid='Subway.WiFi'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 78
01-06 01:45:06.572: D/wpa_supplicant(374): id=14 ssid='Wifi Box Riri'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 77
01-06 01:45:06.572: D/wpa_supplicant(374): id=13 ssid='Guest'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 74
01-06 01:45:06.572: D/wpa_supplicant(374): id=12 ssid='linksys'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 72
01-06 01:45:06.572: D/wpa_supplicant(374): id=11 ssid='CountryInn-2S'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 69
01-06 01:45:06.572: D/wpa_supplicant(374): id=10 ssid='Telekom_FlyNet'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 68
01-06 01:45:06.572: D/wpa_supplicant(374): id=9 ssid='Telekom'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 67
01-06 01:45:06.572: D/wpa_supplicant(374): id=8 ssid='Telekom_ICE'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 64
01-06 01:45:06.572: D/wpa_supplicant(374): id=7 ssid='WANADOO-14A8'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 49
01-06 01:45:06.572: D/wpa_supplicant(374): id=6 ssid='AP_Walbourg'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 35
01-06 01:45:06.572: D/wpa_supplicant(374): id=4 ssid='SFR_B7D0'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 33
01-06 01:45:06.572: D/wpa_supplicant(374): id=3 ssid='Wifi Gratuit Decathlon'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group 0
01-06 01:45:06.572: D/wpa_supplicant(374): id=43 ssid='LSTraining'
01-06 01:45:06.572: D/wpa_supplicant(374): Priority group -10
01-06 01:45:06.572: D/wpa_supplicant(374): id=45 ssid='FreeWifi'
01-06 01:45:06.602: D/wpa_supplicant(374): nl80211: interface wlan0 in phy phy0
01-06 01:45:06.602: I/wpa_supplicant(374): rfkill: Cannot open RFKILL control device
01-06 01:45:06.602: D/wpa_supplicant(374): nl80211: RFKILL status not available
01-06 01:45:06.612: D/dalvikvm(523): GC_CONCURRENT freed 391K, 6% free 7957K/8455K, paused 2ms+11ms
01-06 01:45:06.732: D/dalvikvm(307): GC_CONCURRENT freed 827K, 8% free 11785K/12743K, paused 3ms+36ms
01-06 01:45:06.772: W/ActivityManager(307): Unable to start service Intent { act=com.google.android.gms.analytics.service.START (has extras) }: not found
01-06 01:45:06.782: W/GAV2(636): Thread[main,5,main]: Connection to service failed 1
01-06 01:45:06.802: D/dalvikvm(498): GC_CONCURRENT freed 78K, 2% free 7543K/7687K, paused 2ms+4ms
01-06 01:45:06.862: D/dalvikvm(523): GC_FOR_ALLOC freed 45K, 7% free 8064K/8583K, paused 63ms
01-06 01:45:06.862: I/dalvikvm-heap(523): Grow heap (frag case) to 8.184MB for 262160-byte allocation
01-06 01:45:06.922: D/dalvikvm(498): GC_CONCURRENT freed 12K, 3% free 7951K/8135K, paused 2ms+3ms
01-06 01:45:06.932: W/Ads(636): No Google Analytics: Library Incompatible.
01-06 01:45:06.982: I/GAV2(636): Thread[main,5,main]: setting appName to GPS Status
01-06 01:45:07.002: W/GAV2(636): Thread[main,5,main]: Need to call initialize() and be in fallback mode to start dispatch.
01-06 01:45:07.022: D/dalvikvm(523): GC_FOR_ALLOC freed 0K, 7% free 8320K/8903K, paused 83ms
01-06 01:45:07.182: D/dalvikvm(498): GC_CONCURRENT freed 34K, 2% free 8383K/8519K, paused 2ms+34ms
01-06 01:45:07.232: D/dalvikvm(523): GC_FOR_ALLOC freed 410K, 9% free 8302K/9031K, paused 63ms
01-06 01:45:07.252: D/kernel(140): [ 41.178833] wl1271_sdio mmc0:0001:2: firmware: requesting ti-connectivity/wl1271-fw-multirole-roc.bin
01-06 01:45:07.532: D/kernel(140): [ 41.464782] wl1271: firmware booted (Rev 6.3.7.0.79)
01-06 01:45:07.542: D/dalvikvm(498): GC_CONCURRENT freed 83K, 2% free 8985K/9159K, paused 2ms+3ms
01-06 01:45:07.562: D/wpa_supplicant(374): netlink: Operstate: linkmode=1, operstate=5
01-06 01:45:07.562: D/wpa_supplicant(374): nl80211: Using driver-based off-channel TX
01-06 01:45:07.572: D/kernel(140): [ 41.501861] ADDRCONF(NETDEV_UP): wlan0: link is not ready
01-06 01:45:07.572: D/wpa_supplicant(374): nl80211: driver param='(null)'
01-06 01:45:07.572: D/wpa_supplicant(374): WAPI: Supplicant port status: Unauthorized
01-06 01:45:07.572: D/wpa_supplicant(374): Own MAC address: 84:00:d2:22:33:a7
01-06 01:45:07.572: D/wpa_supplicant(374): wpa_driver_nl80211_set_key: ifindex=21 alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
01-06 01:45:07.572: D/wpa_supplicant(374): wpa_driver_nl80211_set_key: ifindex=21 alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
01-06 01:45:07.572: D/wpa_supplicant(374): wpa_driver_nl80211_set_key: ifindex=21 alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
01-06 01:45:07.572: D/wpa_supplicant(374): wpa_driver_nl80211_set_key: ifindex=21 alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
01-06 01:45:07.572: D/wpa_supplicant(374): RSN: flushing PMKID list in the driver
01-06 01:45:07.572: D/wpa_supplicant(374): Setting scan request: 0 sec 100000 usec
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: Regulatory information - country=US
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: 2402-2472 @ 40 MHz
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: 5170-5250 @ 40 MHz
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: 5250-5330 @ 40 MHz
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: 5490-5600 @ 40 MHz
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: 5650-5710 @ 40 MHz
01-06 01:45:07.582: D/wpa_supplicant(374): nl80211: 5735-5835 @ 40 MHz
01-06 01:45:07.582: D/wpa_supplicant(374): WPS: Set UUID for interface wlan0
01-06 01:45:07.712: D/wpa_supplicant(374): EAPOL: SUPP_PAE entering state DISCONNECTED
01-06 01:45:07.732: D/wpa_supplicant(374): EAPOL: Supplicant port status: Unauthorized
01-06 01:45:07.732: D/wpa_supplicant(374): EAPOL: KEY_RX entering state NO_KEY_RECEIVE
01-06 01:45:07.732: D/wpa_supplicant(374): EAPOL: SUPP_BE entering state INITIALIZE
01-06 01:45:07.732: D/wpa_supplicant(374): EAP: EAP entering state DISABLED
01-06 01:45:07.742: D/wpa_supplicant(374): Added interface wlan0
01-06 01:45:07.742: D/wpa_supplicant(374): State: DISCONNECTED -> SCANNING
01-06 01:45:07.742: D/wpa_supplicant(374): Starting AP scan for wildcard SSID
01-06 01:45:07.762: D/wpa_supplicant(374): Scan requested (ret=0) - scan timeout 10 seconds
01-06 01:45:07.762: D/wpa_supplicant(374): RTM_NEWLINK: operstate=0 ifi_flags=0x1002 ()
01-06 01:45:07.762: D/wpa_supplicant(374): nl80211: Interface down
01-06 01:45:07.762: D/wpa_supplicant(374): Event 30 received on interface wlan0
01-06 01:45:07.762: D/wpa_supplicant(374): Interface was disabled
01-06 01:45:07.762: D/wpa_supplicant(374): State: SCANNING -> DISCONNECTED
01-06 01:45:07.762: D/wpa_supplicant(374): wpa_driver_nl80211_set_operstate: operstate 0->0 (DORMANT)
01-06 01:45:07.762: D/wpa_supplicant(374): netlink: Operstate: linkmode=-1, operstate=5
01-06 01:45:07.762: D/wpa_supplicant(374): EAPOL: External notification - portEnabled=0
01-06 01:45:07.762: D/wpa_supplicant(374): EAPOL: Supplicant port status: Unauthorized
01-06 01:45:07.762: D/wpa_supplicant(374): EAPOL: External notification - portValid=0
01-06 01:45:07.762: D/wpa_supplicant(374): State: DISCONNECTED -> INTERFACE_DISABLED
01-06 01:45:07.762: D/wpa_supplicant(374): RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
01-06 01:45:07.762: D/wpa_supplicant(374): Event 5 received on interface wlan0
01-06 01:45:07.762: D/wpa_supplicant(374): RTM_NEWLINK: operstate=0 ifi_flags=0x1043 ([UP][RUNNING])
01-06 01:45:07.762: D/wpa_supplicant(374): nl80211: Interface up
01-06 01:45:07.762: D/wpa_supplicant(374): Event 29 received on interface wlan0
01-06 01:45:07.762: D/wpa_supplicant(374): Interface was enabled
01-06 01:45:07.762: D/wpa_supplicant(374): State: INTERFACE_DISABLED -> DISCONNECTED
01-06 01:45:07.762: D/wpa_supplicant(374): Setting scan request: 0 sec 0 usec
01-06 01:45:07.762: D/wpa_supplicant(374): RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
01-06 01:45:07.762: D/wpa_supplicant(374): State: DISCONNECTED -> SCANNING
01-06 01:45:07.762: D/wpa_supplicant(374): Starting AP scan for wildcard SSID
01-06 01:45:07.762: D/wpa_supplicant(374): nl80211: Scan trigger failed: ret=-16 (Device or resource busy)
01-06 01:45:07.762: W/wpa_supplicant(374): wlan0: Failed to initiate AP scan
01-06 01:45:07.762: D/wpa_supplicant(374): Setting scan request: 1 sec 0 usec
01-06 01:45:07.762: D/wpa_supplicant(374): nl80211: Event message available
01-06 01:45:07.782: D/wpa_supplicant(374): nl80211_priv_driver_cmd MACADDR len = 4096
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='ssid'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='bssid'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='priority'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='scan_ssid'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wep_tx_keyidx'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wep_key0'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wep_key1'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wep_key2'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wep_key3'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='psk'
01-06 01:45:07.792: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='as_cert_uri'
01-06 01:45:07.792: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='user_cert_uri'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='user_key_uri'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wapi_psk'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:07.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='wapi_key_type'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='proto'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='key_mgmt'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='auth_alg'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='pairwise'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='group'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='eap'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='phase2'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='identity'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='anonymous_identity'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='password'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='client_cert'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='private_key'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=0 name='ca_cert'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:07.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='ssid'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='bssid'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='priority'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='scan_ssid'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wep_tx_keyidx'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wep_key0'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wep_key1'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wep_key2'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wep_key3'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='psk'
01-06 01:45:07.832: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='as_cert_uri'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='user_cert_uri'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='user_key_uri'
01-06 01:45:07.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wapi_psk'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='wapi_key_type'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='proto'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='key_mgmt'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='auth_alg'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='pairwise'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='group'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='eap'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='phase2'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='identity'
01-06 01:45:07.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='anonymous_identity'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='password'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='client_cert'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='private_key'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=1 name='ca_cert'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='ssid'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='bssid'
01-06 01:45:07.852: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:07.862: D/wpa_supplicant(374): nl80211: Event message available
01-06 01:45:07.862: D/wpa_supplicant(374): nl80211: New scan results available
01-06 01:45:07.862: D/wpa_supplicant(374): Event 3 received on interface wlan0
01-06 01:45:07.862: D/wpa_supplicant(374): Received scan results (0 BSSes)
01-06 01:45:07.862: D/wpa_supplicant(374): BSS: Start scan result update 1
01-06 01:45:07.862: D/wpa_supplicant(374): New scan results available
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 174
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 173
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 170
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 169
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 168
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 167
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 165
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 159
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 158
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 157
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 145
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 144
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 143
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 140
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 138
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 137
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 136
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 134
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 133
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 132
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 131
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 127
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 124
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 118
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 108
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 107
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 106
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 105
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 104
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 103
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 95
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 92
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 91
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 87
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 82
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 78
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 77
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 74
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 72
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 69
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 68
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 67
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 64
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 49
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 35
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 33
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group 0
01-06 01:45:07.862: D/wpa_supplicant(374): Selecting BSS from priority group -10
01-06 01:45:07.862: D/wpa_supplicant(374): No suitable network found
01-06 01:45:07.862: D/wpa_supplicant(374): Setting scan request: 6 sec 0 usec
01-06 01:45:07.862: D/wpa_supplicant(374): Checking for other virtual interfaces sharing same radio (phy0) in event_scan_results
01-06 01:45:07.862: D/wpa_supplicant(374): RTM_NEWLINK: operstate=0 ifi_flags=0x1003 ([UP])
01-06 01:45:07.862: D/wpa_supplicant(374): RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
01-06 01:45:07.862: D/wpa_supplicant(374): Event 5 received on interface wlan0
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='priority'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='scan_ssid'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wep_tx_keyidx'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wep_key0'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wep_key1'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wep_key2'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wep_key3'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='psk'
01-06 01:45:07.872: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='as_cert_uri'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='user_cert_uri'
01-06 01:45:07.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='user_key_uri'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wapi_psk'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='wapi_key_type'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='proto'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='key_mgmt'
01-06 01:45:07.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='auth_alg'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='pairwise'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='group'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='eap'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='phase2'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='identity'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='anonymous_identity'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='password'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='client_cert'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='private_key'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=2 name='ca_cert'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='ssid'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='bssid'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='priority'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='scan_ssid'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wep_tx_keyidx'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wep_key0'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wep_key1'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wep_key2'
01-06 01:45:07.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wep_key3'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='psk'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='as_cert_uri'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='user_cert_uri'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='user_key_uri'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wapi_psk'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='wapi_key_type'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='proto'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='key_mgmt'
01-06 01:45:07.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='auth_alg'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='pairwise'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='group'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='eap'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='phase2'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='identity'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='anonymous_identity'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='password'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='client_cert'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='private_key'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=3 name='ca_cert'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='ssid'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='bssid'
01-06 01:45:07.912: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='priority'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='scan_ssid'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wep_tx_keyidx'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wep_key0'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wep_key1'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wep_key2'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wep_key3'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='psk'
01-06 01:45:07.922: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='as_cert_uri'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='user_cert_uri'
01-06 01:45:07.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='user_key_uri'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wapi_psk'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='wapi_key_type'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='proto'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='key_mgmt'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='auth_alg'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='pairwise'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='group'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='eap'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='phase2'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='identity'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='anonymous_identity'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='password'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='client_cert'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='private_key'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=4 name='ca_cert'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='ssid'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='bssid'
01-06 01:45:07.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='priority'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='scan_ssid'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wep_tx_keyidx'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wep_key0'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wep_key1'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wep_key2'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wep_key3'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='psk'
01-06 01:45:07.972: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='as_cert_uri'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='user_cert_uri'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='user_key_uri'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wapi_psk'
01-06 01:45:07.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='wapi_key_type'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='proto'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='key_mgmt'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='auth_alg'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='pairwise'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='group'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='eap'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='phase2'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='identity'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='anonymous_identity'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='password'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='client_cert'
01-06 01:45:07.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='private_key'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=5 name='ca_cert'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='ssid'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='bssid'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='priority'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='scan_ssid'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wep_tx_keyidx'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wep_key0'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wep_key1'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wep_key2'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wep_key3'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='psk'
01-06 01:45:08.002: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='as_cert_uri'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='user_cert_uri'
01-06 01:45:08.002: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='user_key_uri'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wapi_psk'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='wapi_key_type'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='proto'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='key_mgmt'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='auth_alg'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='pairwise'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='group'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='eap'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='phase2'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='identity'
01-06 01:45:08.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='anonymous_identity'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='password'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='client_cert'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='private_key'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=6 name='ca_cert'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='ssid'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='bssid'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='priority'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='scan_ssid'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wep_tx_keyidx'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wep_key0'
01-06 01:45:08.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wep_key1'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wep_key2'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wep_key3'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='psk'
01-06 01:45:08.032: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='as_cert_uri'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='user_cert_uri'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='user_key_uri'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wapi_psk'
01-06 01:45:08.032: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='wapi_key_type'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='proto'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='key_mgmt'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='auth_alg'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='pairwise'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='group'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='eap'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='phase2'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='identity'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='anonymous_identity'
01-06 01:45:08.042: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='password'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='client_cert'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='private_key'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=7 name='ca_cert'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='ssid'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='bssid'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='priority'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='scan_ssid'
01-06 01:45:08.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wep_tx_keyidx'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wep_key0'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wep_key1'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wep_key2'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wep_key3'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='psk'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='as_cert_uri'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='user_cert_uri'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='user_key_uri'
01-06 01:45:08.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wapi_psk'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='wapi_key_type'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='proto'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='key_mgmt'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='auth_alg'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='pairwise'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='group'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='eap'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='phase2'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='identity'
01-06 01:45:08.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='anonymous_identity'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='password'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='client_cert'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='private_key'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=8 name='ca_cert'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='ssid'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='bssid'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='priority'
01-06 01:45:08.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='scan_ssid'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wep_tx_keyidx'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wep_key0'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wep_key1'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wep_key2'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wep_key3'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='psk'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='as_cert_uri'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='user_cert_uri'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='user_key_uri'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wapi_psk'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='wapi_key_type'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='proto'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='key_mgmt'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='auth_alg'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='pairwise'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='group'
01-06 01:45:08.092: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='eap'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='phase2'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='identity'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='anonymous_identity'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='password'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='client_cert'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='private_key'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=9 name='ca_cert'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='ssid'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='bssid'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='priority'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='scan_ssid'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wep_tx_keyidx'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wep_key0'
01-06 01:45:08.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wep_key1'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wep_key2'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wep_key3'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='psk'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='as_cert_uri'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='user_cert_uri'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='user_key_uri'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wapi_psk'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='wapi_key_type'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='proto'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='key_mgmt'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='auth_alg'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='pairwise'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='group'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='eap'
01-06 01:45:08.112: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='phase2'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='identity'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='anonymous_identity'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='password'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='client_cert'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='private_key'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=10 name='ca_cert'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='ssid'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='bssid'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='priority'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='scan_ssid'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wep_tx_keyidx'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wep_key0'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wep_key1'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wep_key2'
01-06 01:45:08.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wep_key3'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='psk'
01-06 01:45:08.132: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='as_cert_uri'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='user_cert_uri'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='user_key_uri'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wapi_psk'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='wapi_key_type'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='proto'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='key_mgmt'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='auth_alg'
01-06 01:45:08.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='pairwise'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='group'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='eap'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='phase2'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='identity'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='anonymous_identity'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='password'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='client_cert'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='private_key'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=11 name='ca_cert'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='ssid'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='bssid'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.142: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='priority'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='scan_ssid'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wep_tx_keyidx'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wep_key0'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wep_key1'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wep_key2'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wep_key3'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='psk'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='as_cert_uri'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='user_cert_uri'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='user_key_uri'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wapi_psk'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='wapi_key_type'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='proto'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='key_mgmt'
01-06 01:45:08.152: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='auth_alg'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='pairwise'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='group'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='eap'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='phase2'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='identity'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='anonymous_identity'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='password'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='client_cert'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='private_key'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=12 name='ca_cert'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='ssid'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='bssid'
01-06 01:45:08.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='priority'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='scan_ssid'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wep_tx_keyidx'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wep_key0'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wep_key1'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wep_key2'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wep_key3'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='psk'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='as_cert_uri'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='user_cert_uri'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='user_key_uri'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wapi_psk'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='wapi_key_type'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='proto'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='key_mgmt'
01-06 01:45:08.172: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='auth_alg'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='pairwise'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='group'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='eap'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='phase2'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='identity'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='anonymous_identity'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='password'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='client_cert'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='private_key'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=13 name='ca_cert'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='ssid'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='bssid'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='priority'
01-06 01:45:08.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='scan_ssid'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wep_tx_keyidx'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wep_key0'
01-06 01:45:08.192: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wep_key1'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wep_key2'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wep_key3'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='psk'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='as_cert_uri'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='user_cert_uri'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='user_key_uri'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wapi_psk'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='wapi_key_type'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='proto'
01-06 01:45:08.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='key_mgmt'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='auth_alg'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='pairwise'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='group'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='eap'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='phase2'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='identity'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='anonymous_identity'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='password'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='client_cert'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='private_key'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=14 name='ca_cert'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='ssid'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='bssid'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='priority'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='scan_ssid'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wep_tx_keyidx'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wep_key0'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wep_key1'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wep_key2'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wep_key3'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='psk'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='as_cert_uri'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='user_cert_uri'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='user_key_uri'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wapi_psk'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.212: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='wapi_key_type'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='proto'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='key_mgmt'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='auth_alg'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='pairwise'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='group'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='eap'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='phase2'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='identity'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='anonymous_identity'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='password'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='client_cert'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='private_key'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=15 name='ca_cert'
01-06 01:45:08.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='ssid'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='bssid'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='priority'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='scan_ssid'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wep_tx_keyidx'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wep_key0'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wep_key1'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wep_key2'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wep_key3'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='psk'
01-06 01:45:08.232: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='as_cert_uri'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='user_cert_uri'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='user_key_uri'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wapi_psk'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='wapi_key_type'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='proto'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='key_mgmt'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='auth_alg'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='pairwise'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='group'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='eap'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='phase2'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='identity'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='anonymous_identity'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='password'
01-06 01:45:08.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='client_cert'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='private_key'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=16 name='ca_cert'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='ssid'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='bssid'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='priority'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='scan_ssid'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wep_tx_keyidx'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wep_key0'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wep_key1'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wep_key2'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wep_key3'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='psk'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='as_cert_uri'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='user_cert_uri'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='user_key_uri'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wapi_psk'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='wapi_key_type'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='proto'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='key_mgmt'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='auth_alg'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='pairwise'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='group'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='eap'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='phase2'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='identity'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='anonymous_identity'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='password'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='client_cert'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='private_key'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=17 name='ca_cert'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='ssid'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='bssid'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='priority'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='scan_ssid'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wep_tx_keyidx'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wep_key0'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wep_key1'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wep_key2'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wep_key3'
01-06 01:45:08.272: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='psk'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='as_cert_uri'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='user_cert_uri'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='user_key_uri'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wapi_psk'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='wapi_key_type'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='proto'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='key_mgmt'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='auth_alg'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='pairwise'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='group'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='eap'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='phase2'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='identity'
01-06 01:45:08.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='anonymous_identity'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='password'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='client_cert'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='private_key'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=18 name='ca_cert'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='ssid'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='bssid'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='priority'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='scan_ssid'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wep_tx_keyidx'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wep_key0'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wep_key1'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wep_key2'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wep_key3'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.292: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='psk'
01-06 01:45:08.302: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='as_cert_uri'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='user_cert_uri'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='user_key_uri'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wapi_psk'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='wapi_key_type'
01-06 01:45:08.302: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='proto'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='key_mgmt'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='auth_alg'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='pairwise'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='group'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='eap'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='phase2'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='identity'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='anonymous_identity'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.312: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='password'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='client_cert'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='private_key'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=19 name='ca_cert'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='ssid'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='bssid'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='priority'
01-06 01:45:08.322: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='scan_ssid'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wep_tx_keyidx'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wep_key0'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wep_key1'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wep_key2'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wep_key3'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='psk'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='as_cert_uri'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='user_cert_uri'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='user_key_uri'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wapi_psk'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='wapi_key_type'
01-06 01:45:08.332: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='proto'
01-06 01:45:08.342: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='key_mgmt'
01-06 01:45:08.342: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='auth_alg'
01-06 01:45:08.342: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='pairwise'
01-06 01:45:08.342: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='group'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='eap'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='phase2'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='identity'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='anonymous_identity'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='password'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='client_cert'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='private_key'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=20 name='ca_cert'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='ssid'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='bssid'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='priority'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='scan_ssid'
01-06 01:45:08.352: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wep_tx_keyidx'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wep_key0'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wep_key1'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wep_key2'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wep_key3'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='psk'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='as_cert_uri'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='user_cert_uri'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='user_key_uri'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wapi_psk'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='wapi_key_type'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='proto'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='key_mgmt'
01-06 01:45:08.362: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='auth_alg'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='pairwise'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='group'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='eap'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='phase2'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='identity'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='anonymous_identity'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='password'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='client_cert'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='private_key'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=21 name='ca_cert'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='ssid'
01-06 01:45:08.372: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='bssid'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='priority'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='scan_ssid'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wep_tx_keyidx'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wep_key0'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wep_key1'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wep_key2'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wep_key3'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='psk'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='as_cert_uri'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='user_cert_uri'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='user_key_uri'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wapi_psk'
01-06 01:45:08.382: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='wapi_key_type'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='proto'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='key_mgmt'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='auth_alg'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='pairwise'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='group'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='eap'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='phase2'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='identity'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='anonymous_identity'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='password'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='client_cert'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='private_key'
01-06 01:45:08.392: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=22 name='ca_cert'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='ssid'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='bssid'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='priority'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='scan_ssid'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wep_tx_keyidx'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wep_key0'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wep_key1'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wep_key2'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wep_key3'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='psk'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='as_cert_uri'
01-06 01:45:08.402: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='user_cert_uri'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='user_key_uri'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wapi_psk'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='wapi_key_type'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='proto'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='key_mgmt'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='auth_alg'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='pairwise'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='group'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='eap'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='phase2'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='identity'
01-06 01:45:08.412: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='anonymous_identity'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='password'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='client_cert'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='private_key'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=23 name='ca_cert'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='ssid'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='bssid'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='priority'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='scan_ssid'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wep_tx_keyidx'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wep_key0'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wep_key1'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wep_key2'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wep_key3'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='psk'
01-06 01:45:08.422: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='as_cert_uri'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='user_cert_uri'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='user_key_uri'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wapi_psk'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='wapi_key_type'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='proto'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='key_mgmt'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='auth_alg'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='pairwise'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='group'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='eap'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='phase2'
01-06 01:45:08.432: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='identity'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='anonymous_identity'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='password'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='client_cert'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='private_key'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=24 name='ca_cert'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='ssid'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='bssid'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='priority'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='scan_ssid'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wep_tx_keyidx'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wep_key0'
01-06 01:45:08.442: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wep_key1'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wep_key2'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wep_key3'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='psk'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='as_cert_uri'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='user_cert_uri'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='user_key_uri'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wapi_psk'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='wapi_key_type'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='proto'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='key_mgmt'
01-06 01:45:08.452: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='auth_alg'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='pairwise'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='group'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='eap'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='phase2'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='identity'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='anonymous_identity'
01-06 01:45:08.462: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='password'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='client_cert'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='private_key'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=25 name='ca_cert'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='ssid'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='bssid'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='priority'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='scan_ssid'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wep_tx_keyidx'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wep_key0'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wep_key1'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wep_key2'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wep_key3'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='psk'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='as_cert_uri'
01-06 01:45:08.472: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='user_cert_uri'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='user_key_uri'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wapi_psk'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='wapi_key_type'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='proto'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='key_mgmt'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='auth_alg'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='pairwise'
01-06 01:45:08.482: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='group'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='eap'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='phase2'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='identity'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='anonymous_identity'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='password'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='client_cert'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='private_key'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=26 name='ca_cert'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='ssid'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='bssid'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='priority'
01-06 01:45:08.492: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='scan_ssid'
01-06 01:45:08.502: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wep_tx_keyidx'
01-06 01:45:08.502: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wep_key0'
01-06 01:45:08.502: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.502: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wep_key1'
01-06 01:45:08.502: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wep_key2'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wep_key3'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='psk'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='as_cert_uri'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='user_cert_uri'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='user_key_uri'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.512: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wapi_psk'
01-06 01:45:08.532: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='wapi_key_type'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='proto'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='key_mgmt'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='auth_alg'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='pairwise'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='group'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='eap'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='phase2'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='identity'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='anonymous_identity'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='password'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='client_cert'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='private_key'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=27 name='ca_cert'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='ssid'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='bssid'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.542: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='priority'
01-06 01:45:08.552: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='scan_ssid'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wep_tx_keyidx'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wep_key0'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wep_key1'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wep_key2'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wep_key3'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='psk'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='as_cert_uri'
01-06 01:45:08.562: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='user_cert_uri'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='user_key_uri'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wapi_psk'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='wapi_key_type'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='proto'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='key_mgmt'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='auth_alg'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='pairwise'
01-06 01:45:08.582: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='group'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='eap'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='phase2'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='identity'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='anonymous_identity'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='password'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='client_cert'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='private_key'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=28 name='ca_cert'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='ssid'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='bssid'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='priority'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='scan_ssid'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wep_tx_keyidx'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wep_key0'
01-06 01:45:08.592: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wep_key1'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wep_key2'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wep_key3'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='psk'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='as_cert_uri'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='user_cert_uri'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='user_key_uri'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wapi_psk'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='wapi_key_type'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='proto'
01-06 01:45:08.602: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='key_mgmt'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='auth_alg'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='pairwise'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='group'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='eap'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='phase2'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='identity'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='anonymous_identity'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='password'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='client_cert'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='private_key'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=29 name='ca_cert'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='ssid'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='bssid'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='priority'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='scan_ssid'
01-06 01:45:08.612: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wep_tx_keyidx'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wep_key0'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wep_key1'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wep_key2'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wep_key3'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='psk'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='as_cert_uri'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='user_cert_uri'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='user_key_uri'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wapi_psk'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='wapi_key_type'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='proto'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='key_mgmt'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='auth_alg'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='pairwise'
01-06 01:45:08.622: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='group'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='eap'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='phase2'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='identity'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='anonymous_identity'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='password'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='client_cert'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='private_key'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=30 name='ca_cert'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='ssid'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='bssid'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='priority'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='scan_ssid'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wep_tx_keyidx'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wep_key0'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wep_key1'
01-06 01:45:08.632: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wep_key2'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wep_key3'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='psk'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='as_cert_uri'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='user_cert_uri'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='user_key_uri'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wapi_psk'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='wapi_key_type'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='proto'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='key_mgmt'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='auth_alg'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='pairwise'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='group'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='eap'
01-06 01:45:08.642: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='phase2'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='identity'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='anonymous_identity'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='password'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='client_cert'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='private_key'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=31 name='ca_cert'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='ssid'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='bssid'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='priority'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='scan_ssid'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wep_tx_keyidx'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wep_key0'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wep_key1'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.652: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wep_key2'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wep_key3'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='psk'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='as_cert_uri'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='user_cert_uri'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='user_key_uri'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wapi_psk'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='wapi_key_type'
01-06 01:45:08.662: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='proto'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='key_mgmt'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='auth_alg'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='pairwise'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='group'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='eap'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='phase2'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='identity'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='anonymous_identity'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='password'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='client_cert'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='private_key'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=32 name='ca_cert'
01-06 01:45:08.672: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='ssid'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='bssid'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='priority'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='scan_ssid'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wep_tx_keyidx'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wep_key0'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wep_key1'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wep_key2'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wep_key3'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='psk'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='as_cert_uri'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='user_cert_uri'
01-06 01:45:08.682: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='user_key_uri'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wapi_psk'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='wapi_key_type'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='proto'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='key_mgmt'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='auth_alg'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='pairwise'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='group'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='eap'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='phase2'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='identity'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='anonymous_identity'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='password'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='client_cert'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='private_key'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.692: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=33 name='ca_cert'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='ssid'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='bssid'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='priority'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='scan_ssid'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wep_tx_keyidx'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wep_key0'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wep_key1'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wep_key2'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wep_key3'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='psk'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='as_cert_uri'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='user_cert_uri'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='user_key_uri'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wapi_psk'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.712: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='wapi_key_type'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='proto'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='key_mgmt'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='auth_alg'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='pairwise'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='group'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='eap'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='phase2'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='identity'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='anonymous_identity'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='password'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='client_cert'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='private_key'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=34 name='ca_cert'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='ssid'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='bssid'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.722: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='priority'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='scan_ssid'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wep_tx_keyidx'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wep_key0'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wep_key1'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wep_key2'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wep_key3'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.732: D/wpa_supplicant(374): EAPOL: disable timer tick
01-06 01:45:08.732: D/wpa_supplicant(374): EAPOL: Supplicant port status: Unauthorized
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='psk'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='as_cert_uri'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='user_cert_uri'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='user_key_uri'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wapi_psk'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='wapi_key_type'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='proto'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='key_mgmt'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='auth_alg'
01-06 01:45:08.732: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='pairwise'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='group'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='eap'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='phase2'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='identity'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='anonymous_identity'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='password'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='client_cert'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='private_key'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=35 name='ca_cert'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='ssid'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='bssid'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='priority'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='scan_ssid'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wep_tx_keyidx'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wep_key0'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.742: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wep_key1'
01-06 01:45:08.752: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.752: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wep_key2'
01-06 01:45:08.752: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wep_key3'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='psk'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='as_cert_uri'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='user_cert_uri'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='user_key_uri'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wapi_psk'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='wapi_key_type'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='proto'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='key_mgmt'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='auth_alg'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='pairwise'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='group'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='eap'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='phase2'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='identity'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='anonymous_identity'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.762: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='password'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='client_cert'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='private_key'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=36 name='ca_cert'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='ssid'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='bssid'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.772: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='priority'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='scan_ssid'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wep_tx_keyidx'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wep_key0'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wep_key1'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wep_key2'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wep_key3'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='psk'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='as_cert_uri'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='user_cert_uri'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='user_key_uri'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wapi_psk'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.782: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='wapi_key_type'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='proto'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='key_mgmt'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='auth_alg'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='pairwise'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='group'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='eap'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='phase2'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='identity'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='anonymous_identity'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='password'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='client_cert'
01-06 01:45:08.802: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='private_key'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=37 name='ca_cert'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='ssid'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='bssid'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='priority'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='scan_ssid'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wep_tx_keyidx'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wep_key0'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wep_key1'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wep_key2'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wep_key3'
01-06 01:45:08.812: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='psk'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='as_cert_uri'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='user_cert_uri'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='user_key_uri'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wapi_psk'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='wapi_key_type'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='proto'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='key_mgmt'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='auth_alg'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='pairwise'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='group'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='eap'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='phase2'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='identity'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='anonymous_identity'
01-06 01:45:08.822: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='password'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='client_cert'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='private_key'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=38 name='ca_cert'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='ssid'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='bssid'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='priority'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='scan_ssid'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wep_tx_keyidx'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wep_key0'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wep_key1'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wep_key2'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wep_key3'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.832: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='psk'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='as_cert_uri'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='user_cert_uri'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='user_key_uri'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wapi_psk'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='wapi_key_type'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='proto'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='key_mgmt'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='auth_alg'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='pairwise'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='group'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='eap'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='phase2'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='identity'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='anonymous_identity'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='password'
01-06 01:45:08.842: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='client_cert'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='private_key'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=39 name='ca_cert'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='ssid'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='bssid'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='priority'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='scan_ssid'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wep_tx_keyidx'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wep_key0'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wep_key1'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wep_key2'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wep_key3'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='psk'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='as_cert_uri'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='user_cert_uri'
01-06 01:45:08.862: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='user_key_uri'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wapi_psk'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='wapi_key_type'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='proto'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='key_mgmt'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='auth_alg'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='pairwise'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='group'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='eap'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='phase2'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='identity'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='anonymous_identity'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='password'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='client_cert'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='private_key'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.872: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=40 name='ca_cert'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='ssid'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='bssid'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='priority'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='scan_ssid'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wep_tx_keyidx'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wep_key0'
01-06 01:45:08.882: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wep_key1'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.882: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wep_key2'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wep_key3'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='psk'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='as_cert_uri'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='user_cert_uri'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='user_key_uri'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wapi_psk'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='wapi_key_type'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='proto'
01-06 01:45:08.892: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='key_mgmt'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='auth_alg'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='pairwise'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='group'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='eap'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='phase2'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='identity'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='anonymous_identity'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='password'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='client_cert'
01-06 01:45:08.902: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.912: I/GAV2(636): Thread[GAThread,5,main]: No campaign data found.
01-06 01:45:08.912: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='private_key'
01-06 01:45:08.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.922: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=41 name='ca_cert'
01-06 01:45:08.922: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='ssid'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='bssid'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='priority'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='scan_ssid'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wep_tx_keyidx'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wep_key0'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wep_key1'
01-06 01:45:08.932: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wep_key2'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wep_key3'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='psk'
01-06 01:45:08.942: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='as_cert_uri'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='user_cert_uri'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='user_key_uri'
01-06 01:45:08.942: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wapi_psk'
01-06 01:45:08.952: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='wapi_key_type'
01-06 01:45:08.952: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='proto'
01-06 01:45:08.952: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:08.952: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='key_mgmt'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='auth_alg'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='pairwise'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='group'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='eap'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='phase2'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='identity'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='anonymous_identity'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='password'
01-06 01:45:08.962: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='client_cert'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='private_key'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=42 name='ca_cert'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='ssid'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='bssid'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='priority'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='scan_ssid'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wep_tx_keyidx'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wep_key0'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wep_key1'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wep_key2'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wep_key3'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:08.972: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='psk'
01-06 01:45:08.972: D/wpa_supplicant(374): Do not allow key_data field to be exposed
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='as_cert_uri'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='user_cert_uri'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='user_key_uri'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wapi_psk'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='wapi_key_type'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='proto'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='key_mgmt'
01-06 01:45:08.992: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='auth_alg'
01-06 01:45:09.002: D/CustomizationProvider(505): openFile -- START uri=content://com.sonyericsson.provider.customization/settings/com.android.phone
01-06 01:45:09.002: I/CustomizationProvider(505): No configuration file: /system/etc/customization/settings/com/android/phone/custom_settings.xml
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='pairwise'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='group'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='eap'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='phase2'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='identity'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:09.012: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='anonymous_identity'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='password'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='client_cert'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='private_key'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=43 name='ca_cert'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='ssid'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='bssid'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='priority'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='scan_ssid'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wep_tx_keyidx'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wep_key0'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wep_key1'
01-06 01:45:09.022: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wep_key2'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wep_key3'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='psk'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='as_cert_uri'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='user_cert_uri'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='user_key_uri'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wapi_psk'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='wapi_key_type'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='proto'
01-06 01:45:09.052: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='key_mgmt'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='auth_alg'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='pairwise'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='group'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='eap'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='phase2'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='identity'
01-06 01:45:09.062: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='anonymous_identity'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='password'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='client_cert'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='private_key'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=44 name='ca_cert'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='ssid'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='bssid'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='priority'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='scan_ssid'
01-06 01:45:09.072: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wep_tx_keyidx'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wep_key0'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wep_key1'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wep_key2'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wep_key3'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='psk'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='as_cert_uri'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:09.082: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='user_cert_uri'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='user_key_uri'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wapi_psk'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='wapi_key_type'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='proto'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='key_mgmt'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='auth_alg'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='pairwise'
01-06 01:45:09.102: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='group'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='eap'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='phase2'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='identity'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='anonymous_identity'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='password'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='client_cert'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:09.122: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='private_key'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=45 name='ca_cert'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='ssid'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='bssid'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='priority'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='scan_ssid'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wep_tx_keyidx'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wep_key0'
01-06 01:45:09.132: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:09.142: D/dalvikvm(523): GC_CONCURRENT freed 218K, 5% free 8605K/9031K, paused 2ms+3ms
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wep_key1'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wep_key2'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wep_key3'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='psk'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='as_cert_uri'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='user_cert_uri'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='user_key_uri'
01-06 01:45:09.162: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:09.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wapi_psk'
01-06 01:45:09.182: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:09.182: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='wapi_key_type'
01-06 01:45:09.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='proto'
01-06 01:45:09.192: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='key_mgmt'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='auth_alg'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='pairwise'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='group'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='eap'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='phase2'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='identity'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='anonymous_identity'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='password'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='client_cert'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='private_key'
01-06 01:45:09.202: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:09.222: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=46 name='ca_cert'
01-06 01:45:09.222: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:09.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='ssid'
01-06 01:45:09.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='bssid'
01-06 01:45:09.232: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'bssid'
01-06 01:45:09.232: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='priority'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='scan_ssid'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wep_tx_keyidx'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wep_key0'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key0'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wep_key1'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key1'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wep_key2'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key2'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wep_key3'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wep_key3'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='psk'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'psk'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='as_cert_uri'
01-06 01:45:09.242: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'as_cert_uri'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='user_cert_uri'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_cert_uri'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='user_key_uri'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'user_key_uri'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wapi_psk'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'wapi_psk'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='wapi_key_type'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='proto'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='key_mgmt'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='auth_alg'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='pairwise'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='group'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='eap'
01-06 01:45:09.252: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'eap'
01-06 01:45:09.252: I/ActivityManager(307): Start proc com.sonyericsson.learningclient for broadcast com.sonyericsson.learningclient/.LearningClientListener: pid=670 uid=10093 gids={3003}
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='phase2'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'phase2'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='identity'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'identity'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='anonymous_identity'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'anonymous_identity'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='password'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'password'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='client_cert'
01-06 01:45:09.262: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'client_cert'
01-06 01:45:09.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='private_key'
01-06 01:45:09.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'private_key'
01-06 01:45:09.282: D/wpa_supplicant(374): CTRL_IFACE: GET_NETWORK id=47 name='ca_cert'
01-06 01:45:09.282: D/wpa_supplicant(374): CTRL_IFACE: Failed to get network variable 'ca_cert'
01-06 01:45:09.412: E/WifiConfigStore(307): Missing id while parsing configuration
01-06 01:45:09.422: E/WifiConfigStore(307): Missing id while parsing configuration
01-06 01:45:09.432: E/WifiConfigStore(307): Missing id while parsing configuration
01-06 01:45:09.432: D/dalvikvm(636): GC_CONCURRENT freed 320K, 6% free 6580K/6983K, paused 3ms+3ms
01-06 01:45:09.442: E/WifiConfigStore(307): Missing id while parsing configuration
01-06 01:45:09.452: D/wpa_supplicant(374): nl80211_priv_driver_cmd BTCOEXSCAN-STOP len = 4096
01-06 01:45:09.452: E/wpa_supplicant(374): Unsupported command: BTCOEXSCAN-STOP
01-06 01:45:09.452: D/wpa_supplicant(374): nl80211_priv_driver_cmd RXFILTER-ADD 3 len = 4096
01-06 01:45:09.452: D/wpa_supplicant(374): nl80211_priv_driver_cmd RXFILTER-START len = 4096
01-06 01:45:09.452: D/wpa_supplicant(374): nl80211_priv_driver_cmd RXFILTER-STOP len = 4096
01-06 01:45:09.452: D/wpa_supplicant(374): nl80211_priv_driver_cmd RXFILTER-REMOVE 2 len = 4096
01-06 01:45:09.462: D/wpa_supplicant(374): wlan0: ap_scan = 1
01-06 01:45:09.462: D/wpa_supplicant(374): nl80211_priv_driver_cmd SETSUSPENDOPT 0 len = 4096
01-06 01:45:09.462: E/wpa_supplicant(374): Unsupported command: SETSUSPENDOPT 0
01-06 01:45:09.472: E/WifiStateMachine(307): set suspend optimizations failed!
01-06 01:45:09.472: D/wpa_supplicant(374): nl80211_priv_driver_cmd POWERMODE 0 len = 4096
01-06 01:45:09.472: D/wpa_supplicant(374): global POWERMODE set to 0 (wanted 0), ret 0
01-06 01:45:09.472: D/wpa_supplicant(374): nl80211_priv_driver_cmd SETSUSPENDOPT 0 len = 4096
01-06 01:45:09.472: E/wpa_supplicant(374): Unsupported command: SETSUSPENDOPT 0
01-06 01:45:09.482: D/wpa_supplicant(374): wlan0: ap_scan = 1
01-06 01:45:09.492: D/WifiLocator(455): Too many no-location APs. Will not compute a location nor go to the server. hasLocation=0 noLocation=0 cacheMiss=0
01-06 01:45:09.502: D/wpa_supplicant(374): nl80211_priv_driver_cmd SETBAND 0 len = 4096
01-06 01:45:09.502: E/wpa_supplicant(374): Unsupported command: SETBAND 0
01-06 01:45:09.502: E/WifiStateMachine(307): Failed to set frequency band 0
01-06 01:45:09.772: D/dalvikvm(394): GC_FOR_ALLOC freed 1603K, 21% free 7009K/8839K, paused 31ms
01-06 01:45:09.852: I/ActivityManager(307): Start proc com.sonyericsson.statusswitch for broadcast com.sonyericsson.statusswitch/.StatusAppWidget: pid=686 uid=10086 gids={3002, 3001}
01-06 01:45:09.882: I/dalvikvm(686): Turning on JNI app bug workarounds for target SDK version 13...
01-06 01:45:09.882: D/BluetoothA2dpService(307): SEND INTENT SCMST SUPPORTED:false
01-06 01:45:09.882: D/BluetoothA2dpService(307): A2DP: onSinkPropertyChanged newState is: 0mPlayingA2dpDevice: null
01-06 01:45:09.892: D/BluetoothA2dpService(307): A2DP state : device: 8C:64:22:C2:13:88 State:1->0
01-06 01:45:09.892: D/BluetoothAdapterStateMachine(307): BluetoothOn process message: 52
01-06 01:45:09.902: D/BluetoothService(307): CONNECTION_STATE_CHANGE: 8C:64:22:C2:13:88: 1 -> 0
01-06 01:45:09.912: D/BluetoothA2dpService(307): A2DP: onSinkPropertyChanged newState is: 0mPlayingA2dpDevice: null
01-06 01:45:10.392: D/dalvikvm(523): GC_CONCURRENT freed 172K, 3% free 9080K/9351K, paused 2ms+7ms
01-06 01:45:10.642: I/ActivityManager(307): Start proc com.google.android.apps.maps for broadcast com.google.android.apps.maps/com.google.android.location.internal.NlpNetworkProviderSettingsUpdateReceiver: pid=702 uid=10044 gids={3003, 1015}
01-06 01:45:11.132: D/dalvikvm(702): GC_CONCURRENT freed 158K, 4% free 6760K/6983K, paused 2ms+12ms
01-06 01:45:11.422: I/ActivityThread(702): Pub com.google.android.maps.OfflineIndexProvider: com.google.googlenav.provider.OfflineIndexProvider
01-06 01:45:11.502: I/ActivityThread(702): Pub com.google.android.maps.SearchHistoryProvider: com.google.googlenav.provider.SearchHistoryProvider
01-06 01:45:11.512: I/ActivityThread(702): Pub com.google.android.maps.SuggestionProvider: com.google.googlenav.suggest.android.SuggestContentProvider
01-06 01:45:11.602: D/dalvikvm(523): GC_CONCURRENT freed 514K, 7% free 9451K/10055K, paused 2ms+6ms
01-06 01:45:11.622: I/ActivityThread(702): Pub com.google.android.maps.LayerInfoProvider: com.google.googlenav.layer.LayerInfoProvider
01-06 01:45:11.662: I/ActivityThread(702): Pub com.google.android.maps.TrafficAppWidgetProvider: com.google.googlenav.appwidget.traffic.TrafficAppWidgetProvider
01-06 01:45:11.762: I/ActivityThread(702): Pub com.google.android.maps.LocalActivePlacesProvider: com.google.googlenav.provider.LocalActivePlacesProvider
01-06 01:45:11.762: I/ActivityThread(702): Pub com.google.android.maps.StarredItemProvider: com.google.googlenav.provider.StarredItemProvider
01-06 01:45:11.802: W/GAV2(636): Thread[Service Reconnect,5,main]: Connection to service failed 1
01-06 01:45:11.802: W/ActivityManager(307): Unable to start service Intent { act=com.google.android.gms.analytics.service.START (has extras) }: not found
01-06 01:45:11.992: E/BluetoothA2dpService.cpp(307): onConnectSinkResult: D-Bus error: org.bluez.Error.Failed (Stream setup failed)
01-06 01:45:12.022: D/dalvikvm(702): GC_CONCURRENT freed 170K, 4% free 7032K/7303K, paused 2ms+2ms
01-06 01:45:12.372: I/Process(307): Sending signal. PID: 307 SIG: 9
01-06 01:45:12.392: I/ServiceManager(126): service 'backup' died
01-06 01:45:12.392: I/ServiceManager(126): service 'search' died
01-06 01:45:12.392: I/ServiceManager(126): service 'wifi' died
01-06 01:45:12.392: I/ServiceManager(126): service 'telephony.registry' died
01-06 01:45:12.392: I/ServiceManager(126): service 'clipboard' died
01-06 01:45:12.392: I/ServiceManager(126): service 'statusbar' died
01-06 01:45:12.392: I/ServiceManager(126): service 'diskstats' died
01-06 01:45:12.392: I/ServiceManager(126): service 'permission' died
01-06 01:45:12.392: I/ServiceManager(126): service 'wifip2p' died
01-06 01:45:12.392: I/ServiceManager(126): service 'cpuinfo' died
01-06 01:45:12.392: I/ServiceManager(126): service 'samplingprofiler' died
01-06 01:45:12.392: I/ServiceManager(126): service 'audio' died
01-06 01:45:12.392: I/ServiceManager(126): service 'bluetooth_a2dp' died
01-06 01:45:12.392: I/ServiceManager(126): service 'sensorservice' died
01-06 01:45:12.392: I/ServiceManager(126): service 'batteryinfo' died
01-06 01:45:12.392: I/ServiceManager(126): service 'package' died
01-06 01:45:12.392: I/ServiceManager(126): service 'meminfo' died
01-06 01:45:12.392: I/ServiceManager(126): service 'location' died
01-06 01:45:12.392: I/ServiceManager(126): service 'hardware' died
01-06 01:45:12.392: I/ServiceManager(126): service 'netstats' died
01-06 01:45:12.392: I/ServiceManager(126): service 'alarm' died
01-06 01:45:12.392: I/ServiceManager(126): service 'power' died
01-06 01:45:12.392: I/ServiceManager(126): service 'mount' died
01-06 01:45:12.392: I/ServiceManager(126): service 'dropbox' died
01-06 01:45:12.392: I/ServiceManager(126): service 'wallpaper' died
01-06 01:45:12.392: I/ServiceManager(126): service 'country_detector' died
01-06 01:45:12.392: I/ServiceManager(126): service 'notification' died
01-06 01:45:12.402: I/ServiceManager(126): service 'connectivity' died
01-06 01:45:12.402: I/ServiceManager(126): service 'network_management' died
01-06 01:45:12.402: I/ServiceManager(126): service 'device_policy' died
01-06 01:45:12.402: I/ServiceManager(126): service 'textservices' died
01-06 01:45:12.402: I/ServiceManager(126): service 'accessibility' died
01-06 01:45:12.402: I/ServiceManager(126): service 'window' died
01-06 01:45:12.402: I/ServiceManager(126): service 'bluetooth' died
01-06 01:45:12.402: I/ServiceManager(126): service 'activity' died
01-06 01:45:12.402: I/ServiceManager(126): service 'account' died
01-06 01:45:12.402: I/ServiceManager(126): service 'netpolicy' died
01-06 01:45:12.402: I/ServiceManager(126): service 'appwidget' died
01-06 01:45:12.402: I/ServiceManager(126): service 'devicestoragemonitor' died
01-06 01:45:12.402: I/ServiceManager(126): service 'content' died
01-06 01:45:12.402: I/ServiceManager(126): service 'usagestats' died
01-06 01:45:12.402: I/ServiceManager(126): service 'throttle' died
01-06 01:45:12.402: I/ServiceManager(126): service 'uimode' died
01-06 01:45:12.402: I/ServiceManager(126): service 'usb' died
01-06 01:45:12.402: I/ServiceManager(126): service 'entropy' died
01-06 01:45:12.402: I/ServiceManager(126): service 'input_method' died
01-06 01:45:12.402: I/ServiceManager(126): service 'gfxinfo' died
01-06 01:45:12.402: I/ServiceManager(126): service 'battery' died
01-06 01:45:12.402: I/ServiceManager(126): service 'vibrator' died
01-06 01:45:12.402: W/Sensors(523): sensorservice died [0x21afe8]
01-06 01:45:12.402: W/Sensors(498): sensorservice died [0x1d1aa8]
01-06 01:45:12.402: W/AudioFlinger(148): power manager service died !!!
01-06 01:45:12.402: W/System.err(523): android.content.pm.PackageManager$NameNotFoundException: Application package com.sonyericsson.advancedwidget.music not found
01-06 01:45:12.402: D/kernel(140): [ 46.338134] binder: send failed reply for transaction 5428 to 523:523
01-06 01:45:12.402: D/SurfaceFlinger(131): Release buffer at 0x78b30
01-06 01:45:12.402: I/ActivityThread(702): Removing dead content provider: settings
01-06 01:45:12.402: I/ActivityThread(686): Removing dead content provider: settings
01-06 01:45:12.402: I/ActivityThread(455): Removing dead content provider: settings
01-06 01:45:12.402: I/ActivityThread(569): Removing dead content provider: settings
01-06 01:45:12.402: I/ActivityThread(498): Removing dead content provider: settings
01-06 01:45:12.402: I/ActivityThread(481): Removing dead content provider: settings
01-06 01:45:12.402: I/ActivityThread(394): Removing dead content provider: settings
01-06 01:45:12.412: D/SurfaceFlinger(131): Release buffer at 0x5f490
01-06 01:45:12.412: D/SurfaceFlinger(131): Release buffer at 0x71030
01-06 01:45:12.412: D/SurfaceFlinger(131): Release buffer at 0x66388
01-06 01:45:12.412: D/SurfaceFlinger(131): Release buffer at 0x68738
01-06 01:45:12.412: E/installd(135): eof
01-06 01:45:12.412: E/installd(135): failed to read size
01-06 01:45:12.412: I/installd(135): closing connection
01-06 01:45:12.422: W/System.err(523): at android.app.ContextImpl.createPackageContext(ContextImpl.java:1430)
01-06 01:45:12.422: W/System.err(523): at android.content.ContextWrapper.createPackageContext(ContextWrapper.java:483)
01-06 01:45:12.422: W/System.err(523): at com.sonyericsson.advancedwidget.framework.AdvWidgetProxy.createAdvWidgetProxy(AdvWidgetProxy.java:304)
01-06 01:45:12.422: W/System.err(523): at com.sonyericsson.home.widget.AdvWidgetManager.getWidget(AdvWidgetManager.java:108)
01-06 01:45:12.422: W/System.err(523): at com.sonyericsson.home.widget.AdvWidgetManager.getWidgetView(AdvWidgetManager.java:84)
01-06 01:45:12.422: W/System.err(523): at com.sonyericsson.home.layer.desktop.DesktopController$20.run(DesktopController.java:2605)
01-06 01:45:12.422: W/System.err(523): at com.sonyericsson.util.DeferredHandler$Impl.handleMessage(DeferredHandler.java:62)
01-06 01:45:12.422: W/System.err(523): at android.os.Handler.dispatchMessage(Handler.java:99)
01-06 01:45:12.422: W/System.err(523): at android.os.Looper.loop(Looper.java:137)
01-06 01:45:12.422: W/System.err(523): at android.app.ActivityThread.main(ActivityThread.java:4441)
01-06 01:45:12.422: W/System.err(523): at java.lang.reflect.Method.invokeNative(Native Method)
01-06 01:45:12.422: W/System.err(523): at java.lang.reflect.Method.invoke(Method.java:511)
01-06 01:45:12.422: W/System.err(523): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:784)
01-06 01:45:12.422: W/System.err(523): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:551)
01-06 01:45:12.422: W/System.err(523): at dalvik.system.NativeStart.main(Native Method)
01-06 01:45:12.452: D/kernel(140): [ 46.385284] alarm_release: clear alarm, pending 0
01-06 01:45:12.452: D/kernel(140): [ 46.385314] alarm_release: clear alarm, pending 0
01-06 01:45:12.462: E/InputQueue-JNI(394): channel '2bf26620 StatusBar (client)' ~ Publisher closed input channel or an error occurred. events=0x8
01-06 01:45:12.462: E/InputQueue-JNI(394): channel '2bf5a810 TrackingView (client)' ~ Publisher closed input channel or an error occurred. events=0x8
01-06 01:45:12.462: E/InputQueue-JNI(394): channel '2c08b520 RecentsPanel (client)' ~ Publisher closed input channel or an error occurred. events=0x8
01-06 01:45:12.462: E/InputQueue-JNI(394): channel '2bf6f260 StatusBarExpanded (client)' ~ Publisher closed input channel or an error occurred. events=0x8
01-06 01:45:12.462: E/InputQueue-JNI(394): channel '2c107ce0 com.android.systemui.ImageWallpaper (client)' ~ Publisher closed input channel or an error occurred. events=0x8
01-06 01:45:12.462: I/Zygote(132): Exit zygote because system server (307) has terminated
: E/(): Device disconnected
What happened is that yesterday I let the battery drain before charging the phone. maybe the battery died and the phone refuses to start ?
What bothers me is that even on the charger for more than one hour the phone reboots ...
If you can get the phone to power off and stay off you can run a repair, do not try to run the update whilst it is in a bootloop as this will not work. Get it to stay off and then follow these steps:
1. Before you start you have to download the PC Companion software from http://www.sonymobile.com/gb/tools/pc-companion/
and install it on your PC.
2. Once installed on your PC, double-click the PC Companion icon on your desktop to start the update.
Note! For some models you will be prompted to do a backup prior to the update and then restore.
3. Install and open PC Companion then select Support Zone.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
What are your thoughts about this forum? Let us know by doing this short survey.
@aryanadonis
Hello same problem is with me too!
U activate bluetooth BOOM! u are in reboot loop then only reinstalling the whole firmware works to come out of loop and not only this u can re-welcome the loop again by clicking on Activate bluetooth buttons anytime . ITS totally a BUG in ICS 4.0.4 update . If u want to send/recieve files in bluetooth I can tell you two ways
1. Install Ginger Bread the outdated OS . lol
2. Swithoff your phone without switching on bluetooth first when you need a file to transfer.
Then before Powering it on keep pressing volume down button then press power ON.
Ur phone will vibrate abnormally and u will see SAFE MODE written in left hand side at bottom of screen.
Then Dismount Memory Card(Not neccesary).
Then switch bluetooth On .
Finish Send / Recieve Files
**DONT FORGET TO TURN BLUETOoTH OFF**
Mount MMC (if dismounted earlier).
REBOOT PHONE NORMALLY
This way u can avoid a reboot loop caused by crap bluetooth bug in Sony . Sony Should provide us new Update Bug free Update no matter its Jelly Bean or not. Atleast provide stable ICS.
I just received a brand new battery, i was suspecting a drained battery. But the brand new battery did not solve my problem.
My phone is also rebooting when in Safe Mode, I have no clue how to fix this !
