T2 ULTRA CAMERA ISSUES
GauravShintre
When I updated my mobile in kitkat my memory card desable and sefe to remove again and again also my camera has been failed to initialized. so what can i do?
Alexander1
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
First of all I would suggest that you remove your SD card, restart your device and put the SD card back in. Then go to settings > apps > all > camera > clear data. Restart your device again and see if it works better.
4 REPLIES 4
Alexander1
Champion
GauravShintre
Thank you for Solution.
My camera was ok. But External Memory Problem is still there. when I share any file in my memory card through WI-FI Direct my memory card is remove again and again.
So, What can i do for fix theme?
Ajeet1
When I updated android 5.1.1 lollipop my phone front and rear camera is not clear. And also the camera pixels clarity is worst. Please give any suggestion related to front and rear camera.
Rekhaanvi
 My video recording is not working.
Please suggest
