I used this method on my wife's Xperia SP, and I confirm it works! After cleanning the lens, the picture captured by Xperia SP is totally different! (I just used my fingernail scratch on the lens for 2 mins):smileyhappy:
thank you so much!
hey my phone is new and i want to remove this ant reflex thing !! but i tried everything and i cant !! what can i do ?
aha ok ! thank you so much !! so i should just wait!!
This really fixed my issues with the camera. I started thinking it was the latest firmware's fault for the horrible blurred and white oversaturation. I have a LensPen for my DSLR and will use it every now and then to keep the lens clean.
Thanks again for the tip.
