Forget the connection and add it again.
Fogetting doesn't help here.. Some wifi routers like at home, do work normally, but at school when I got full rage on 4.1.2 now it says "connection rejected", no hard reset or closing wifi process and starting again helps.. Just one router, other seems to work fine like they did.
I have same problem with wifi Association rejected after v4.3 jelly beam. Others 3 devices from Samsung connect with no problem, so isin´t the router or cable internet.
Any resolution for this?
I´m from Brazil.
After Android update 4.3 9.2.A.1.199 My Sony Xperia TX Lt29i still have the same problem. "Wi-fi Association Rejected". I tryed change the ISSD name, channel, encriptation, password, factory restart, re-update dowload fix from Sony Companion, everything. Sony, any solution?
had the same issue on 4.3
solution: reflash 4.1.2 it's the best
@funfrankie wrote:
Is there a solution for this?
Is there any headway on finding a solution for this? Seems like reverting isn't working for some. Are they fixing all this messiness
in the next upgrade? Sending out a fix? Is it coming soon? Stopping support for lt30p ' s?
