Xperia ion hard bricked
oyhens
I need help with my xperia ion lt28h..
After installing a .zip (Smooth ion) through CWM Recovery, my phone restarted n booted up normally to the lock screen. After i unlocked the screen, it went blank so I pressed the power button and the normal power off button (and some others) appears, so i power off the phone and it went to a boot loop.
I tried pressing the Volume up + power button and connecting it to flashtool by pressing the volume down button and inserting the usbto flash a new firmware but nothing appeared on flashtool Slightly_frowning_Face
I tried the Volume up + power button again and again and still nothing.. I then pressed Volume up + power button again but longer and received 2 or 3 vibrations (i can't remember) and now the phone is just Dead. No Screen,No LED light, nothing :'(
I tried charging it for 2+ hours and tried connecting it to my pc to see if it does anything but apparently nothing happens.
Somebody please help me :'( This is my only phone and I have no other Slightly_frowning_Face
Xperia ion LT28h
Firmware: 6.0.F.0.72 (LT28i 's Firmware)
Bootloader: Unlocked
And Rooted with Busybox installed
I know this is not the exact place to ask for help, but i'm really desperate Slightly_frowning_Face
57 REPLIES 57
chammacki
dredn1
http://forum.xda-developers.com/showpost.php?p=37562298&postcount=301
maybe thats the solution ill try it tonight
chammacki
solution please usb jig will help me?
kgross
I have somehow bricked my phone, xpiera ion
the first few days it was boot looping, only to the black right before the sony logo, so i put it on a new wall charger and let it charge for a few days where it was a solid red led light, without response to any combo of buttons. i got home yesterday and the red led had gone off, still no response. i want to try to flash it or something, but i don't really need to use the phone again, i just want to get ALL my picutres and contacts off of it.
I am silly and didn't back it up, well, i started the day before it broke. I got half the picutres.
what can i do? I own a Mac, if that makes a difference.
Brahm
Same is happening to my phone
Charging to red light
Then phone tries to boot but unsuccessfully
This is happening automatically again and again
I have waited whole day but led is not green or off
Please help
Markqq
I am going to use this thread. I think I bricked my Sony Xperia Ion LT28h when I tried to install CyanogenMod 11. I did everything as descbired in the guide (as far as I believe) untill it told me to turn off the phone. After that it said I need to press power + volume up button at the same time, the phone started and I saw some texts and logos untill it basicly shut down again (I felt 3 times vibrating so I believe it did hard reset?). After that nothing happens. Whatever I try to press or do, power + volume up/down combinations, nothing happens, it is just dead. I tried to put it in wall charger but nothing happens. PC/Flashtool actually recognizes the phone but I can't do anything. There isn't any led lights.
Note: The screen is not totally black, there's some kind of backround light all the time on..
What sould I do rather than wait and hope? Thinking_Face
Idris92
hi, currently having the same problem but mine's charging the problem is it's stuck on bootloop i think, it only goes to AT&T logo then that's it, it restarts again, kinda pissed off about it, i updated it using pc companion. whenever i connect it to the pc it show its charging then the led turns off.. how am i supposed to reflash it if it doesn't even connect to the computer? please help it's an Xperia Lt28at
sonma
please help
deepakB
Visit sony service centre.
They might solve it.
