My xperia neo V is getting restarted continuously after I turned on the bluetooth.
After going on through many threads, I understood I need to downgrade the firmware.
But the latest xperia companion couldn't recognize neo V device. It displays mobileInfo not found error.
Can someone help me to resolve my phone problem?
Not EMMA, go to the XDA forum and look for Xperiafirm or Flashtool.
The Xperia Neo V is no longer supported by Xperia Companion you can use flashtool or Xperifirm.
@uliwooly
Can you please share me the link for flashtool or xperifrm?
@Uliwooly
I downloaded the Emma Flash tool and when accessed my neo V phone it said the phone is locked and asked me to unlock bootloader.
I tried the steps given the page for unlock bootloader. However, I get stuck up at a step 2, which says I have to enable USB debugging in my Neo V. I am not able to boot my phone itself. How am I suppose to do it?:smileycry:
@uliwooly
Any suggestions?
@uliwooly
Thanks for the great help.
I downloaded the flash tool from www.flashtool.net and firmware file for sone neo v.
Now the boot loop problem is resolved.
Thanks again for the help.
