It will damage your back case cover tho if you remove it very often, because it is very fragile (hooks)
i seriously love people like you. thanks
Hi
I tried this method but its useless for me...
But i am unable to reset my sony experia sp
My sony expira sp is going reboot again and again continuously.
First expira logo coming after that color layer and again rebooting....
I am worried...
Please help me...
hi ..did u get the solution..i m facing same problem
What problem pankaj?
Amit are you sure your phone isn't just receiving messages? When any message, chat notification or any important notification appears, the volume of the walkman will reduce nearly to 0 and then back up. Depends on whether you have left the phone on silent then you wont hear anything, otherwise you will hear the notification chime!
I have a problem like that. But now it's fine...
thanks 4 your post....:smileyyahoo:
Thanks very much, your information it's corret, I could reset my xperia sp.
