Xperia SP hard reset problem
ugurkaya
Hi guys, I have got a problem with hard reset (volume up+power key combination). It does not work at all. I've waited pressing these buttons for about 1 minute and nothing happened. Also tried this when screen locked, when unlocked, when phone switched off. No change, no effect.
Tags (2)
23 REPLIES 23
BornBad
Thank you for suggesting the option to press the off button and restarting. It really helped. Thank you so much!!
AlokKar
Hello,
My phone is not restarting after I did soft reset. The phone is dead now. Tried option to hold Power butotn + Vol Up button for 1 min(approx) but didn't help. Also tried using soft reset(off button) at back of phone for 5 seconds but the phone wont turn on. Any suggestion or solutions are welcome
BR,
Alok
Ric3
Hi there
Xperia sp gone black
Used the off button, vibrates 3 times but won't restart
Used the volume+home, vibrates but won't restart..
And all this time the battery/notification light keeps flashing...
Removed sim and nothing..
Any idea anyone..?
Thanks
DN11
Kindly,my phone is not working,it has a reset problem,
Kindly advice
Danson
