Xperia T2 Ultra / T2 Ultra Dual Lollipop issues and feedback
Uliwooly
This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
213 REPLIES 213
Raken_G
I had problem with external USB, please bring support NTFS Format for external storage, and make sd card not unmounted when external USB storage inserted.because it make device hanging. *in lolipop external USB storage ruining my phone*
HIMALAYA10
First of all we don't have multi -user support which was a main feature of lollipop.Second whule pulling down notificatio tray in D5322 (Dual Variant) ,we don't have any wifi and mobile signal icon instead there is a strange key sign i don't know why ???Solve these bugs they does matter to me and to all xperia lollipop dual sim costumers
pasha1993
I have the same issue after upgrading to lollypop, speakers stops working just listen some distortion sound. Sound on handsfree is perfect but external speakers not working
Xperiencemship
I love this phone but its just sad to see that Asphalt 8 runs okay only. Frame rates are mostly 25-29 mist of the time and its just too lonely I think increasing GPU Clock will work. It just hurts too see the T2 Ultra that is mostly used for Entertainment lacks a little Fire Power to make some games atleast run at 30fps average. Please the GPU power please just a little increase Sony thank you. I love the device too. 500MHz for the win please.
Khervey16
Sooo slow! Sudden freeze
Battery draining so fast
Camera gone bad, so bad
We need a new update please...
I love Sony products so can Sony fix this.
dr_habibi
After fully clean PCC instal of lollipop
1.better and larger battery's lifetime
2.Awfuly Sound break during sim 1 calls exist too....important
3. Lag and sometime hang in run apps and get slow very soon after update
The second make me angry about my decision which i bought a sony brand product for the first time despite of advise of others to buy a Samsung note 3 or 4
Crisgdo
Some games have a bad( Lara croft: Relic Run and Peggle Bluster), bad performance. While in kitkat the same games have a nice performance. When I turn off connection these games gets a good performance.
And I hate that appearance button "close all" apps. Please, fix it. And it's visible that the device is lagging sometimes. 😕
Hope sony fix this issues, because T2 ultra is a very good device and I would recommend it to any one. 😕
s4alon
@Rickard
Perhaps you could help us enlighten this one problem.
At first i didn't even think that is possible.
But if other guys post that., than it's true.
Sometimes when playing with game and "got a bad reception" it's lagging alot.
And strangely the game I played doesn't require internet connection.
Same things happen at chatting apps.
Lagging when I try to switch apps, and openning it.
Ksharma
Dear Sony when you are giving lollipop 5.1 update to xperia t2 ultra dual
Crisgdo
And I forgot to say that front camera take green pics sometimes. It's weird! :S
Ok, Sony, you can make the frontal camera better. I can do this with fv-5 camera app in the play Store.
