connect to lap top
mrmccotts
connect to lap top
how do you get sound from a 503ex 37 tv when connected to apple macbook pro lap top
1 REPLY 1
Meestar
OK I am assuming you are connecting with a VGA cable? The problem is that this does not carry sound, so you need an additional cable from your Audio out of the Macbook to the Audio in of the TV - Probably under the 15 pin D-Sub VGA connector
Good Luck!
