Whats the difference ?
The 32EX723 is £749.99 and the 32EX724 is £799.99 but the specs are the same.
Hello. I believe (although not 100% sure) that the 32EX724 will have wireless built-in therefore not needing the UWA-BR100. I know the website says different but I believe this to be an error.
£50:smileywink:
It's probably a marketing ploy, you can't buy this product cheaper - If you cannot see a difference it's not worth the extra £50.
Hope it helps.
