Double image problem on sony bravia kdl40hx723
flynnoutdowns
My tv has suddenly decided to show a double image.   I've turned it off and disconnected it from the power supply and then restarted after 5 minutes but no effect.   I've made sure I didn't have it in 3D mode, any suggestions?
3 REPLIES 3
Sean_Mc
Moderator
Hi there,
Can you try resetting the TV which should resolve the issue for you.  More details on how to perform this here.
Let me know how you get on?
Best wishes,
Sean Mc
flynnoutdowns
Hi Sean,
I did a reset before posting but to no avail.
Thanks for your suggestion.
John.
Sean_Mc
Moderator
Hi John,
I would recommend getting in touch with the support team for further assistance here
Best wishes,
Sean Mc
