KDL-40X2000
profile.country.CH.title
carmen.creus
KDL-40X2000
Hi all
I am aware that my TV is an ancient model (09/2007), but maybe despite someone has a hint how I get the sound working again or if I really do have to throw the device away.
I've worked through all the troubleshooting suggestions from the support side already...
Thanks in advance for any suggestion.
Best; C
carmen.creus
Thank you very much The_Black_Rose! I tried your solution out... Finally it was a software problem of the TV Profider... But you helped me by finding the manual.
Best; C
3 REPLIES 3
Pascale_F
Moderator
Hi carmen.creus,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Carmen.creus ,
If this is not hardware related, resetting the TV may help. I found the steps to reset this TV on page 32 of the manual here: https://www.sony.co.uk/electronics/support/res/manuals/2698/26986711M.pdf
Cheers,
The_Black_Rose
carmen.creus
Best; C
