Sony KDL829 W55 and Sky+HD box
DudySVK
 Hallo
How can i use my sony remote controller for sky+hd box? i want to use only one contoller. on my previous TV (controller) i had option to switch between TV,BD,PS3,HDbox etc... i cant see something similar on this controller...
or
how can i use sky+HD controller for sony TV?
thx for any answer.
2 ACCEPTED SOLUTIONS
Anonymous
Not applicable
Hi there
Merry Christmas!
This site tells you everything you need to know to get the Sky remote to work with your TV:
http://help.sky.com/articles/program-your-sky-remote-to-control-your-tv
Anonymous
Not applicable
Hi there
Not sure if I can assist on the bluetooth issue, however for the screen mirroring there has been some issues of compatibility between the S3 and Sony TV - But thats for NFC only.
There are a couple of apps on the Google Play store that can/may work.  The apps are called Smart Connect and NFC Easy Connect.  Give them a try anyhow.
Remember to put your TV in screen mirroring mode.
Edit : Oh, if you are trying to connect the S3 to the TV via bluetooth - It wont work.  Only Bluetooth mice work on the TV - nothing else.
3 REPLIES 3
Anonymous
Not applicable
Hi there
Merry Christmas!
DudySVK
Hallo and Marry christmas!
Thank you very much i just sort it out :slight_smile: i can see you are expert and may help me with my last issue. i have samsung S3 mobil phone and i cant connect with TV. screen mirroring and bluethoot are not working. is there any other way how to connect it?
thank you
Anonymous
Not applicable
Hi there
