Unable to load iPlayer
Freddie123
The iPlayer stopped loading on our Bravia KDL40W705C about a month ago - it will work perfectly via my iphone hotspot or from the laptop with an ethernet cable so defo not a wi-fi problem - have spent hours on the phone with Sony trying everything possible - Netflix and other apps all load properly. Router parental control also turned off.Any suggestions?
Sony says that it is a software problem rather than the tv but aren't apps  an itegral part of the tv?
Fed up!
2 REPLIES 2
Anonymous
Not applicable
Hi there
Unsure if you have tried - but try factory resetting your TV.  This can cure many issues.  If that doesnt work, can you test 5OD and see if that works?  (as its a UK based app)
Freddie123
thanks - Have done that - Sony now say they are working on the problem as it seems there are lots of us with the same problem - not sure if it's the TV or the BBC with a problem so am just having to wait
What is 50D?!!
