annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
WinDVD BD
profile.country.NL.title
wl_1967
Ontdekker
WinDVD BD
Hallo,
I can't reinstall WinDVD BD on my Sony VGN-AR51J Notebook. I need the firts installation that came with my notebook standard. I can't find it on the Sony Support site or on the Restore DVD's.
The updates on the Sony Support site does not work! I get error, that i need the a previous installation.
Anyone can help me on this?
WL
The Netherlands
3 ANTWOORDEN 3
profile.country.nl_GB.title
lucdevyn
Bezoeker
I have the same problem.
If you find any answer, thanks to forward the solution
Regards,
Luc Devynck
[email protected]
profile.country.nl_NL.title
Robbin.Vermeulen
Bezoeker
Dear wl_1967,
It's realy strange that the updates from the site didn't work. Maybe the Sony VAIO helpdesk knows an answer. You can call them at this number: 0900-0400278.
Kind Regards,
Robbin Vermeulen
wl_1967
Ontdekker
Hey Luc,
I think i found a solution. You can give it a try and it's easy.
http://anebg.net/2009/09/20/intervideo-windvd-bd-for-vaio/
I didn''t try it yet, because i am using another pc with also Blu Ray fuctions/options with Win7. I have 4 systems it home :laughing:
Tell me if this work for you, ok?
Regards,
Wl_1967
From The Netherlands - Amsterdam.
