M series netbook car charger question
holidaychicken
hi All,
hopefully not too much of a daft question, does anyone know if i can get a car charger for the M series netbook, ie,  VPCM13M1E, or if i left it on stand by with the lid down, would the battery last 8 hour+
thanks
rich912
Hi holidaychicken,
In-car chargers are available from a number of suppliers but these are not genuine Sony parts. You could try the following link but it will be necessary to give them a call as your model is not listed.
http://www.laptopshop.co.uk/laptop-car-adapters.htm
Alternatively an DC/AC power inverter, which are now fairly compact, used in conjunction with your standard power adaptor will do the same job at approx. the same cost.
http://www.amazon.co.uk/s/?ie=UTF8&keywords=inverter+car&tag=googhydr-21&index=aps&hvadid=8339502541...
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
Hi holidaychicken,
holidaychicken
hi Rich, thanks  very much for the replies, i didnt even know you could get DC/AC convertors which i think would be the better solution.and cheap too
thanks again :slight_smile:
rich912
You're very welcome holidaychicken :slight_smile:
WORST SERVICE EVER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Thalamus.
Champion
Hi annaabcdefg,
welcome to the Sony User Community Forum..:smileyhappy:
This is an old thread but can you give us more info on what you are having a problem with and maybe someone from the community will be able to assist you..:smileyconfused:
If you would prefer to speak directly to officail Sony support then you can locate the contact details by clicking on the following link - Contact Sony support
