I have had the above machine for a couple of months and have noticed that the fan seems to run fairly constantly and fairly loudly.
Also frequently I have problems starting from sleep mode either if the screen has been closed, or it goes into sleep mode. In the later the fan is running very fast and loud.
I have to hold the power button down to turn off, before restarting.
Any help much appreciated as it is very annoying on what is otherwise a superb machine
The temperature is also running very high
Temp1 71C
Temp1 51C
Core0 48C
Core1 56C
