- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi, I have a VPCJ12M0E Desktop and Vaio care has just popped up with two updates:
Vaio care recovery - 31/3/2014 30267KB
Rescue Data(x86) Update Program 24/2/2014 22468KB
When I click update, I get:
Installation failed
Please wait a while, then try again.
And further still, when I click the links to the updates listed above I get the following pages respectively (404 not found!)
http://support.vaio.sony.eu/computing/vaio/downloads/info/en/EP0000321150.xml
http://support.vaio.sony.eu/computing/vaio/downloads/info/en/EP0000320626.xml
Can anybody please help? I had an issue like this before with an update that never seemed to get resolved, something to do with nividia graphics driver or something.
Neil.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Volksdevil,
This problem effects serveral models but if you try the direct download it should install.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000321150_9606/VPCJ12M0E
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Update:
I tried updating Vaio care recovery on it's own, which didn't work.
So I then tried updating Rescue Data(x86) Update Program on it's own, and that updated just fine.
So now I'm left with just the one update which still gives the same error:
Installation failed
Please help.
Neil.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Still having this issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Volksdevil
Can you please PM me your VAIO serial number, email address, contact phone number and a screenshot of the error message displaying the website link and the error message.
Thanks,
Drew
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Done, pm sent.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Volksdevil,
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That seems to have done the trick thank you, although I'd hope that VaioCare itself can take care of this in the future.
EDIT: Can I safely remove the download from my PC after having done the update? I like to keep it as clean as possible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi volksdevil,
There have been problems with Vaio Update and Vaio Care for many years, so although the applications should take care of updates if you do encounter problems then it is always worth investigating a direct download from the support site.
Yes you can safely remove the downloaded file once installed.
Rich
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Rich, I don't see anything in your reply there?
