cartune77
VPCZ21X9R raid problem
Hi. I have one problem with my laptop. Periodically I have see blue screen and after restart - no operation system - message. After second restart laptop work well some time. And again blue screen. If I have big work with data on disk, the problem will be more fast
1 REPLY 1
jumpsuit
Hi @cartune77 :slight_smile:
There could be a few possibilities as to why you are experiencing this.
Its possible the hard drive is failing but it may be something else.
Do you have anything plugged into a usb port when you are booting and getting the
no operating system message?
