Noise cancelling cutting out
markymark1961
Hi my new noise cancelling headphones WH-1000XM2. Suddenly a sound lime an airport tanoy sounds and the noise cancelling just stops working. I then reset then 5 - 10 mins it does it again. Is this the headphones or my Android phone (Oreo)?
3 REPLIES 3
IamNic
Hi @markymark1961,
that sounds like the adaptive NC is active.
Do you have the Headphones-App installed?
There you can deactivate this function.
- Nic
markymark1961
Thanks Nic
Mark
IamNic
Hi @markymark1961,
did that solve your issue?
- Nic
