I have A KD 65A1 which i have installed flawless IPTV and 2 versions of Smarters IPTV to try they have both worked to a degree before but now not at all.
all versions of the iptv load up perfectly the display all available chanels but when i select one i just get the spinning loading type logo then it freezes
i have loaded the app on my iphone and used the same log in details and everything works perfectly
i have all the user permissions set correctly and the isp websafe is also off
i dont know what else to try has anyone managed to solve this problem ?
thanks in advance
Hi Jamie,
You could check the online help guide here for tips to get your apps up and running again. And maybe some other members will have some advice for you.
Best wishes,
Ed
