My phone alarms are only vibrating, not making any sounds. All of the settings are correct and this is a new problem, also the alarm appears to work in safe mode. How can I fix this? Android 7.1.1
Hi @Varx,
I'm sorry to hear this. If your alarm is working as normal when you have your device in safe mode it is most likely one of your downloaded apps that is causing your alarm to behave this way as these are disabled in safe mode.
I would recommend that you make sure all of you apps are updated, you can do this if you go to: Google Play Store > Tap the 3 lines to the left > My apps & games > Update all.
If you are still experiencing the same behavior after updating your apps, I recommend that you go through your apps one by one until you find the one or ones causing this behavior.
Keep me posted how it goes.
