Auto brightness too low in dark
doogz
Anyone else finding that the screen is far too dim in auto mode if trying to use in dark? Slightly_frowning_Face
22 REPLIES 22
Uliwooly
Care to elaborate?
Just to make sure we understand
settings > display > adaptive brightness > on?
doogz
Yes that's the one. I'm sure on my old z3c you could set a minimum and it wouldnt go under that level.
Uliwooly
I don't have the Xperia X Compact nor the Z3C, I have the Xperia X and Z3 so I can't really test this.
Hardy66
Yes, I totally agree! It's the same experience I made.
Having the possibility to set a minimum low like with the Z3c would be better.
Didrik
Enthusiast
Hi @doogz,
I've just checked in an updated Xperia X Compact and there isn't any setting for this.
Hardy66
There hasn't been an explicit setting for this on the Z3c either.
But in the Z3c the brighness level set manually was treated as a minmum. Meaning in auto mode the brightness went up in sunlight, but even in darkness it would never go below that level.
In contrast to this the X Compact in auto mode overrrides any manual settings, you can see that it moves the slider automatically (the Z3c didn't)  and eventually down to the lowest possible level (far left). This setting however is very dim and makes the display hard to read in a dark room.
doogz
Is there a way to escalate this as a fault to support, as its a pain in the dark?
Didrik
Enthusiast
@doogz,
I can forward this as user feedback. You can also contact your Local support regarding feedback.
Kekeface
Tbh I miss the xperia Z "enable backlight"  option,  with the android updates that option was gone, along with a very comfy dark screen perfect for low light conditions. Also it wasted less battery.
