Translation via Google translate:
Good morning sony
I bought a sony xperia X smartphone in dual version F5122, very enthusiastic for all its FEATURES, but at the time of having it in my hands check in the section of screen lock and I did not find any option of fingerprints !!!.
Checking online I saw that in the United States market this had been disabled, but I have bought it in Lima Peru in a Coolbox store to be exact.
I wanted to know if there is any way to enable this sensor, thanks
Buenos dias sony,
adquiri un smartphone sony xperia X en version dual F5122 , muy entusiasmado por todas sus CARACTERISTICAS, pero a la hora de tenerlo en mis manos revise en la seccion de bloqueo de pantalla y no encontre ninguna opcion de huellas dactilares!!!.
Revisando por internet vi que en el mercado de estados unidos este havia sido inavilitado, pero yo lo he adquirido en Lima Peru en una tienda Coolbox para ser exactos.
queria saber si ay alguna forma de habilitar este sensor, gracias
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
It's about the software customization of the phone, if it has the US version then the fingerprint sensor will be disabled by default. The way to enable it is to flash another version of the software other than the US one. But this process might void your warranty (depending on the warranty terms).
I want to enable the fingerprint sensor, as or who could perform this process:
