Does the new phones have no ANT+ anymore?
no, they dont have ant+ anymore
http://developer.sonymobile.com/downloads/whitepapers/xperia-x-performance-f8132-white-paper/
Hi @JummyZX,
It is correct that the Xperia X Performance does not support ANT+.
I'm sorry if you were led to believe otherwise.
It is sad as the whole range of xperia z has ant+ I skipped the Z5 in order to get a
better processor and camera with the x performance... in favour of the galaxy s7 edge...
Now I'm not that sure anymore. The x + performance range is a midrange device as of now I suppose.
I own dual band devices ant+ and BT(LE) as they are best with both in fitness...
Any change of ant+ coming back?
Valentijn Langendorff
@JummyZX wrote:It is sad as the whole range of xperia z has ant+ I skipped the Z5 in order to get a
With a huge selection of Bluetooth smartband, smartwatch and accessories and due the fact that Bluetooth is not a very mature standard you will see that many OEMs will slowly ditch ANT+ because the ANT+ is just a surplus considered that Bluetooth is gaining a de facto title of "standard" for many means of connections and communication between devices.
Sad... the XP has a broadcom chipst that is capable of ant+ according a developer...
