Hi there,
My PC isn't visable to my PC but is visable on my ancient laptop (both Windows 7).
All that happens on the PC is that the phone charges - no messages, I've tried four USB cables and turned all phones settings off & on several times but no difference.
Help Please
(If I need to download/install anything, can I have an "idiots guide" please)
Hi @Ageingdj,
What operating system is your PC using? Try installing Xperia Companion, restart the PC and try again.
Hi Cameron,
I'm running Windows 7 and reinstalled the Companion a dozen times.
I've also downloaded the driver from the Sony site but it refuses to install.
Is there a online version of the theme creator?
Thanks
Paul
Try turning on USB debugging on your phone.
To do this please go to Settings > About Phone, tap on the build number several times until it says "You are now a developer".
Then, go back to Settings and a new option called 'Developer options'. In here, turn on 'USB Debugging'.
Hi Cameron,
I've done all this, deleted the companion and then installed the software from my phone (which proves the PC can see the phone).
Windows Explorer now shows a "CD drive (F:)" with "Sony PC Software" and three files.
And still the software dosn't see the phone! (I'm not bothered with the Companion but what I want is the Theme Creator).
What do I do now please?
Thanks
Try the following:
