Hello,
I'm an happy owner of an Xperia X Compact. This terminal is amazing, but since the last update (34.2.A.2.69) I'm experiencing some issues.
Especially during games (clash Royale) the phone is becaming very hot and the battery drop fast.
I never experienced this kind of behavior before. Let me know if there is a workaround or I can provide more detail information for help in the resolution.
Many thanks
The solution is to no update it! 😂
Try a repair on Sony pc suite or a factory reset from the settings menu. If that doesn't help, you'll have to wait to see if it normalises.
thanks for your reply.
I tried a factory reset but that seems of no use... At the moment in order to get a decent usage time I removed a lot of apps and all the games (not so important)
I will se if it normalize or maybe a future update will solve the issue. I belive in you dev team
This is very unlucky by the way
That's why I'm not updating from 6.0.1
The Xperia X Compact has Android 7.0 from the box.
Not necessarily. When I got mine it had marshmallow.
