Phone is heating
Subhashbetal
Phone is heating
Phone temperature rises even in light usage, if u cant fix this temperature problem then plz fix that system default which force close the camera due to temperature.
3 REPLIES 3
CameronT
Champion
Hi @Subhashbetal, welcome to the community,
Do you experience this same issue in safe mode?
Subhashbetal
Not tried but i think in safe mode third party apps dont run. Only system apps will run, then what is the benifit of booting in safe mode phone will not heat but i cant use the phone properly in safe mode.
CameronT
Champion
@Subhashbetal,
In safe mode we can test if third party apps are causing the issue. If the problem does not happen in safe mode then we know it is a third party app causing the problem. If it does happen, then it will be something else. It is simply to eliminate what could potentially be the issue, for testing purposes only.
